SOURCE: Error code on DCR-TRV530 - C:32:10
Try taking out the battery and plugging in the charger with no battery. That did it for me.
SOURCE: "Re-attach the power source" but tape is stuck, door open
I had the same problem. First, depress the reset button, located on the camera body (where the LCD screen closes over it). It is hard to see at first. It is important that the camera be set to the OFF position. When the camera is whirring after the reset, then hit the EJECT button so the tape comes out. Take the tape out and insert it back. That's it. My camcorder worked fine and let me record or plaback once I followed those steps.
Vic
SOURCE: Reinsert cassette
I've been researching this for hours. I have the same problem. Took it to a repair shop today that would charge me $250 to replace the whole tape mechanism. Finally, I tried the whack trick. I gave the camera a good firm smack on the right side, and voila, now it works! I'm going to tranfer everything to DVD ASAP!
SOURCE: HDR-HC1 Sony camcorder- reinsert the cassette error message
Bill,
The problem is with the S-reel. Take the tape out, remove the battery, and give it a slight bump. This usually fixes the issue for a couple of weeks. I haven't heard of any permenant fixes. I took my cam into circuit city (before they closed) twice for the same issue. Very frustrating when you don't know what the issue is.
First you would need to check the connectors on the charge cable and if its still not charging, then do a hard reset which means totally power the device down and then power it up and then try and charge again. Your charging cable might be defective. You can remove the battery go to bottom of device, remove memory card, then use a small screwdriver. But I would first try the first two steps because removing the battery on this device would require you to dissemble the whole device
