Question about Refrigerators
I have a samsung RS21DCSV/X FRIDGE FREEZER.THE FREEZER WORKS PERFECTLY.BUT THE FRIDGE WILL ONLY COOL TO 13 DEGREES
    Brigadier General:
  • 6,966 Answers
Initially, pls check the:
  • thermostat and its setting for the fridge part;
  • check if the fan is spinning to draw cold air from the freezer towards the fridge portion;
  • check if any food stuff is blocking the fan/vent;
  • on instances where a large number food stuff has just been placed inside, it may take some time for the temp to go down;
  • see if you have a turbo cool and enable it.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 09, 2008
Samsung Side by side Fridge not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 10, 2010 | Samsung RS2556 Side by Side Refrigerator
Samsung side-by-side fridge freezer model RS21DCSV. Freezer is fine. Temperature keeps changing in fridge varying from 5-14 degrees and water has stopped coming out of dispenser. Have checked and...
these side by sides use an auger motor in the fridge to open and close according to the temp demand. If its eratic, either the auger is icing up at the outlet possibly due to product being to close to the outlet. On occation i have had to replace them due to being faulty.(to check, adjust the temp. and notice if there is any change on the auger.)
Sep 17, 2009 | Samsung RS2556 Side by Side Refrigerator
Model rs21dcsv freeze is working but fridge is not working
CHeck to see if there is ice built up on the back wall of the freezer. If so you have a defrost problem. Manually defrost it then take the back wall out of the frezer and check ohms on the heater if heater is ok then replace just the defrost timer and thermostat. If heater is bad replace all three.
Nov 18, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung twin cooling fridge/freezer model Rs21dcsv Fridge temp control led display digit flashing and fridge not at right tempreture
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Jul 31, 2008 | Refrigerators
Fridge freezer samsung model no sr-s2028cvw
fridge side should only be around 36 to 40 degrees freezer side around 0 to10 below
Apr 13, 2008 | Refrigerators
RS21DCNS
as a rule of thumb mfgs say give the unit 24 hrs to stablize where are you gettings the readings the fridge or freezer sides freezer readings run from -8 to -10 the fridge should run 34to38
Jan 31, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
167 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
