Question about HP LaserJet 3055 All-In-One Printer
Scaning assembly cable shorted by miss handling & printer does not starts
Printer does not starts
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Then you may have a blown up printer interface card...if it's turning on, and cable is disconnected, and still does not work, then it's time for a repair or new printer.
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
VS Handbarke handle Assembly Stuck Brake handle
if you can get under the car the rear brake cable has an adsjutmet thread up near the gearbox ... you can slacken off rear cable
something tells me you need
a new handbrake assembly or its short cable
or the rear discs and calipers checked for wear or sticking slides
Oct 08, 2016 | Cars & Trucks
Trailing cable burns
The smoking and melting cable are the result of a short cicuit.
The problem is going to be determining which end the short is occuring on. It most likely is the carriage end of the cable that is the culprit. Most likely you will need to replace the carriage assembly and of course the trailing cable as the new one may have also been damaged.
You may need to use your fingers to check if the top of the carriage assembly (where the cable connects) is also getting hot (warmer than normal).
C7769 60376 DesignJet 500 800 Print head carriage assembly C7769 69376... Trailing Cable for HP DesignJet Plotters Wide Format Printers
Jan 29, 2014 | HP DesignJet 500 InkJet Printer
ERROR CODE 6A00 on my pixma mp830
6A00 is when the purge assembly jams up. On the 830 cleaning usually doesn't help and you need a new purge assembly. The purge assembly is the unit on the right where the printhead parks. Once in a great while there's a paper scrap caught there, but mostly the pump binds up and you need it replaced. Only about $29.00 for the part.
Feb 24, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Handle unhooked
spring and metal hook should have a metal cable to it and the handle with handle depressed cable pulls back hook [safety/shut off] which lets mower start
Oct 07, 2009 | Black & Decker 19" Electric Lawnhog...
My kodak printer wont let me see my scaned docoments
Make sure that the printer and computer are connected together with USB cable.Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software and click on scan pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals for proper instructions for scanning.
May 11, 2009 | Kodak ESP 5 Printer
Not scaning
Hi m Harsh,
Try this, Go to start -- printers & faxes & delete all the files there except the basic fax .................
m sure this will work...........
byeeeeeee......
Apr 27, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Adriatik
can't find home position. either the scanner assembly needs to be replaced, or the engine control board is defective. my guess is scanner assembly. good luck!
Aug 22, 2008 | HP LaserJet 3330 All-In-One Printer
Scaning Problem
Change the usb cable. just buy a better one, i think is a DS usb cable, no longer than 2 mt
Nov 20, 2007 | Canon PIXMA MP830 All-In-One InkJet...
WON'T SCAN
Did you have things apart far enough to mess with the scanner.  The scanner should move to one side when it first goes on, and then trip a sensor (home position sensor).  Also, the scanner is probably belt or cable driven.  Check to see that the belt is somewhat tight, and that the gears and pulleys leading to the scanner motor are in place and not broken.
Oct 27, 2007 | Lexmark X3470 All-In-One InkJet Printer
Error code
hi,
this is a problem in scaning lamp,check the cable which is connected from scaning lamp to pcb is damaged or discontinued ,so replace it but the fault will be rectified replace the pcb,then contact service dealer
Oct 16, 2007 | Toshiba e-Studio 161 Copier Copier
HP LaserJet 3055 All-In-One Printer Logo
22 people viewed this question
Ben Johnson
