Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Konica minolta B250 scan to HDD problem
Try to create user box at the machine, but it refuse to register the number.
only have 1 public box, which is default when u install the HDD.
help needed.
  • 167 Answers
What number are you trying to give the box? It needs to be a three digit number I believe.
Do not try to go in sequence, just give it a number like, 111, or 222, this will be sure as not to conflict with any exsisting boxes.
Posted on Aug 11, 2008
What's your question? my konica minolta c451e printing machine showed me an error code p21, what could that mean and it is not printing any image but black-green shade
P-21 - Color regist test pattern failure
• The number of points detected in the main scan direction is more or less than the specified value during main scan direction registration correction.
• The number of points detected in the sub scan direction is more or less than the specified value during sub scan direction registration correction.
P-21: Color regist test pattern failure
Relevant parts:
• Transfer belt unit
• PH unit
• Printer control board (PRCB)
Step/Action:
1/ Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2/ Change the image transfer belt unit if the transfer belt is damaged.
3/ Change the PH unit.
4/ Change PRCB.
(See Service Manual, pages 599, 603):
http://www.imcopexamerica.com/service-books/Bizhub/Color/bizhubC451_C550_C650FieldSvc.pdf
See also here:
Konica Minolta Bizhub c451 Reparacin de Fotocopiadoras YoReparo
Thread Problemas na C451 7 21
May 31, 2015 | Konica Minolta Office Equipment & Supplies
Konica Minolta Bizhub C252 FTP Scanning Problem
I'm not sure what you want to do, but I have installed various BizHub machines.
User ID, is exactly what it is... Used to monitor and manage individual users.
Which OS is the machine you want to scan to?
Depending on machine, I will hint Konica Minolta FTP Utility...
Mar 04, 2014 | Office Equipment & Supplies
Bizhub c450 scans multiple pages to separate scans
hi im lorenzo and i have been fixing konica minolta machines for about 2 years well lets catch to the case.
If you still have problems or cant change to multiple scan.
1.you have to get in the simulation mode because machine doesnt know if the HDD installed is in.
*simulation utilty/counter =details stop 00 stop 01
2. ONCE YOUR IN LOOK FOR SYSTEM 2 AND CLICK ON HDD YOUL SEE THAT HDD IS NOT INTALLED SO CLICK INSTALLED AND THEN EXIT END AND REBOOT THE PRINTER AND TRY TO SCAN AND IT WILL WORK
THUMBS UP IF IT WORK FOR YOU
Jul 18, 2012 | Konica Minolta bizhub C250 All-In-One...
How to scan to smb with konica minolta bizhub 250
create a folder on the pc you want to scan to and share the folder on the network. This must be done or the printer will not see the folder. Then register a new SMB user on the bizhub and direct it to that pc's IP and the shared folder.
Jul 23, 2010 | Konica Minolta bizhub C250 All-In-One...
How do i set up a scan box on my konica, i have my i.p address already konica minolta bizhub c252
How to setup scan to hard drive on a c250 with standard controller:
1. Enter the ip address in your web browser.
2. Click on the file tab and then the create box under the mailboxes.
3. Input a mailbox number and password that you select in the proper fields.
4. Click on create and after the browser returns to the previous screen you can create another mailbox or log out.
5. After all mailboxes have been created you click on the scan tab to set up a one-touch key.
6. Select the index number you wish to set the one touch key under and then click on an open box. (box with --- In it).
7. On the destination screen that opens select scan to hdd and click on the next box.
8. Name the mailbox with the name you want on the machine display in the destination name field.
9. Select the mailbox name or number for the location using the drop down menu.
10. Click on create to finish creating the mailbox and making it available as a one touch key.
Nov 02, 2009 | Konica Minolta bizhub C250 All-In-One...
Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
Mar 30, 2009 | Konica Minolta bizhub C351 All-In-One...
Cannot create same user box on second machine
The only way that would be happening is if the box esists.
Are there any boxes already created?
Are you working from Panle or Web Connection. Web conection will easily list all boxes stored on machine.
Log in as an Admin to really see what is going on.
Aug 29, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta 250 Bizhub scanning Operations
You need to create a "one-touch"
This can be done in the Admin Screen without having to enter a code.
Better yet is to just yype the IP address into your browser and create them there.
The copier will need an email address in order to send them and you may need to log out and then back into the 250 as an "Admin".
Jul 21, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
309 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
