Question about Beko 24 in. D3731F Free-standing Dishwasher
BEKO DE 3430 dishwasher
How can I clean the filter completely, I have lost the manual and cannot source one online.
Thank you
  • Abon Sep 18, 2008
    Thank you I will try that one.
  • Anonymous Feb 08, 2009
    need to clean filter
    Genius:
  • 1,122 Answers
Run it empty with baking soda and vinegar,this should clean everthing,mike
Posted on Sep 12, 2008
Miele lost suction
The thing about vacums is they all suck! Ok, now that I've completed my comedic exercise...You didn't provide a lot of detail. I'll assume it turns on...have the filters been changed lately because some models have filters that if not clean...will restrict air flow when dirty or clogged. You may have to take it apart and Vacuum cleaners are not overly complicated. If you go online you may find a maual on your model which show where all the important screws are that have to be removed to open the thing up. of course..make sure it's unplugged before you try opening it up. If the motor spins and the filters are OK, it could be the motor is just spinning freely and not actually turning the wheel that creates the vacuum. So you'll have to try and see if the blower wheel is spinning free or if it's solidly connected to the motor. If the blower wheel isn't connected to the motor solidly...there's your problem....the motor is spinning but not turning anything. Best thing to do is look up the model online and find the schecmatic/manual/parts manual for it. Seeing that will give you a better idea of how the thing is constructed and what might be causing the problem. Also, if you take it apart, mark the screws/bolts so you put them back in the right holes.
Oct 14, 2014 | Vacuums
Tip
Fed up having to buy new filters for your vacuum?
Over the years I've lost count of how many companies stop selling replacement filters for their long deceased production vacuum models or that filter replacements are becoming increasingly difficult to source. There are usually universal "microfilter" replacements which are easy enough to find and cut to size, but if you can't be bothered to do that, there are ways around to renew your existing filter even if the manufacturer or the user manual states that the filter cannot be washed.
You see, any filter can actually be washed - if it is a single cloth filter - as opposed to a micro pleated section of many layers sewn together. If you have such a filter, a single cloth filter which the user manual says cannot be washed, this is a blatant lie. Remove the motor filter as normal (usually found at the bottom where the paper bag goes) if it is embedded with dirt and wash under a hot tap of water with either household washing up liquid or soap. Once the filter has been completely cleaned, place the filter into a pillow case and chuck into an electric dryer on a low heat. Instead of waiting 24 hours normally for a filter to dry to room temperature, you'll cut your waiting time by a day simply by allowing the gentle heat from the electric dryer to circulate around the pillow case which holds your vacuum cleaner filter. Once the filter is completely dry to the touch and does not feel damp in any way, install back into the vacuum cleaner.
I have also done this with HEPA paper filters which apparently are not washable according to the manual, and to stop the plastic cartridges from bouncing off the walls of your electric clothing dryer/tumble dryer put an extra towel or cloth into the pillow case to minimise damage. What is then revealed is a new, dry and clean filter which can be used again instead of spending lots of money trying to source a new one.
At the same time, if your vacuum cleaner has a soft bag, take it off and put it into the washing machine to give it a clean lease of life - but you won't need to put it into a pillow case to dry in the electric dryer - simply chuck the bag in to ensure it gets dried properly before putting it back onto your vacuum cleaner.
on Nov 16, 2007 | Sebo Automatic X1 Bagged Upright Vacuum
Need manual for lumina bread maker xmb1089product no.8016.i lost mine
Hi William: I believe this product is distributed by Aldi in Australia and New Zealand. I have been in contact with Aldi in the USA and they are not able to provide manuals. There also does not seem to be a free source of the manuals online. I did see one comment that if you visit your lcoal Aldi outlet they will make arrangements to get a manual to you.
However if a store visit is not possible, I have located one source online that for a fee is able to provide the Owner's Manual for the Lumina XBM1089 Bread Maker:
http://www.tradebit.com/filedetail.php/125929962-lumina-xbm1089-owners-manual-recipes
I trust this is helpful. Thank you for using FixYa!
Nov 22, 2011 | Kitchen Appliances - Others
Hi, I lost my cs9900 owner's manual and now it's
The filters just pull out of the ends of the compressor
You can clean the filters with Soapy water or mineral spirits
Here is the link to the owners manual
Most SHERWIN WILLIAMS paint stores can order the filters for you
or you can order online from here
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 03, 2011 | Air Tools & Compressors
Changing the filter on a Steamworks G-1030ST iron.
Not 100% sure, but I think you press and hold steam button for a few seconds.
Dec 13, 2009 | Sierra Online, Inc. Arcanum: of Steamworks...
1996 Plymoth Voyager chugs when cold
plymouth voyager
Don't waste your money on unnecessary sources and unwanted repairs. Get this manual online under $10-15 and get complete guide on whether to repair or not, service it, and how to repair etc
Jan 28, 2018 | 1995 Plymouth Voyager
How do I use the self-cleaning option
According to the manual for IS series Mr. Coffee for programmable models:
1. Prepare one batch of Mr. Coffee coffeemaker cleaner. Pour the mixture into the water reservoir. Remove the water filtration disk from the machine.
4 cups or 20 oz. of undiluted, white household vinegar may be used as a substitute for the cleaner.
2. Place an empty paper filter or permanent filter into the filter basket and close.
3. Place the empty decanter back in the unit, centered on the warmer plate.
4. Press SELECT button until the red CLEAN indicator light is illuminated. For your convenience the cleaning cycle is automatic. The entire cycle will take 45-60 min to complete. During the cleaning your coffeemaker will:
  • Slow brew approx. 3 cups of cleaning solution.
  • Pause for 30 min (the CLEAN light will remain on to alert you that the process is active). At the end of the pause period your coffeemaker will beep.
  • After 30 mins your coffeemaker will brew the remainder of the cleaning solution.
  • When complete, the CLEAN light will turn off and your coffeemaker will automatically beep and shut off.
5.Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean fresh water.
7. Place the empty decanter back on the coffeemaker, centered on the warmer plate.
8. Remove and discard the filter used during the cleaning cycle and replace it with a fresh paper filter. If a permanent filter was used during cleaning, remove it and rinse it thoroughly before replacing it in the filter basket.
9.Begin brewing and allow the full brew cycle to complete.
Repeat steps 6-9 one more time.
Nov 23, 2007 | Mr. Coffee FTXSS23GTF Coffee Maker
Manual for Oure Ion Advanced
the clean filter light will reset itself once the filter is completely clean. Try dust off the areas where the filter is inserted into as well.
Oct 30, 2007 | Brookstone Pure-Ion UV Air Purifier
Beko 24 in. D3731F Free-standing Dishwasher Logo
772 people viewed this question
Top Beko Dishwashers Experts
Shekar Avadhani
Eric Taylor
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
