My guess is that the website your are trying to visit is very outdated. In the past some websites built their sites to only work on certain web browsers. Since the message says IE5, the site is probably only compatible with IE5 and maybe IE7.
You may try contacting the website owner as it will be tough to find those older versions of the browser. If you can provide more details about the website, I'd be happy to help further troubleshoot.
It sounds like your video card isn't powerful enough for the game (I would suspect). Re-post your system specs and what game you are trying to play and someone can look specifically at your system vs. the game requirements.
That error message usually occurs when using an unsupported third party charger. An example would be if you bought a cheap "knock off" charger that doesn't supply the correct voltage to the phone. These messages can sometimes occur in error when using an official or supported charger.
If you're sure you're using a supported charger, there is something you can try to fix this error. First, unplug the charger from the phone and the power outlet. Turn off the phone and then remove the battery. Wait about 15 seconds and insert the battery again. Turn on the phone, and plug in the charger to the power outlet and the phone. The phone should now charge.
If it's still not working, you'll need to try to get a new charger. Sometimes, if the phone is still in warranty, you can get the charger replaced for free if it is defective.
The battery could be worn out and needs replacing or the charging circuit in the phone is faulty or the charger is faulty. Try another Sony charger to determine if it is faulty. Then try another battery. If none of these work then it may be cheaper to get a new phone on another plan..
if your phone is tellimg you unsupported it will not charge i would think its a sony ericsson or may be nokia if you update your phone software it should solve that problem. hope this helps
brother this is ur charger proublem change ur charger only original charger work in it ur proublem will solved then hardware fault in charging ic idrish 911
My Nokia 2310 suddenly switched off. It didnt switch on again. I tried putting the battery(of problem phone) into another cellphone, the battery works fine. I tried to charge the problem phone, but is not showing any activity upon inserting the charger jack. Other phones are getting charged using the same charger.
