Question about Brandt Microwave Ovens
MICROWAVE D9023EFL BRANDT MODEL
HELLO!
MY BRANDT OVEN DOES'NOT HEAT WITH MICROWAVE PART BUT OK WITH RESISTORE PART .
I THINK THAT DIODE IN THE DISCHARGE CIRCUIT IS BURNED .I AM LOOKING FOR DATA SHEET OR EQUIVALANTE CURRENTLY IN MARKETS OF THE FOLLOWING REFERENCE : T4512H
THANK YOU FOR LETING HEATING RAPIDLY MY PIZZA
  • Brandt Master
  • 9,098 Answers
Brandt is overhauling their Web site, so i would call 0870 240 8095 for parts.
If you are not in the UK, please let me know.
Posted on Aug 12, 2008
Jvm1650 it appears that when the mag attempts to kick on right after it starts it begins to really growl or groan ( extremely deep loud hum) and does not heat
Diode is open replace diode (it,s not a bleed resistor it,s a diode can only be checked with a meter with a voltage of more than 9v should read continuity in one direction only
Jan 24, 2012 | GE JVM1650 1000 Watts Microwave Oven
How to replace fuse in magicchef MVPII microwave.wont heat.
If your microwave isn't heating, I don't think it is a fuse problem or issue. Investigate these three areas if your microwave won't heat
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
Testing a diode
NOTE: Before you test your diode, make sure your microwave is unplugged, and that you discharge the microwave's capacitor.
Whether it is shorted or open, a defective diode will most likely show some sign of defect. Defective diodes will usually emit an electrical burning smell, signifying its defectiveness. Also, it may have split in two, or it may exhibit a burned crack, or possibly even a blistered spot.
A shorted diode is indicated by a loud humming noise from the high voltage transformer, and no heat produced when a cook cycle is initiated. Whereas little or no heat produced in your microwave, with an absence of a humming noise is indicative of an open diode. In either case, the diode has to be replaced.
With your microwave unplugged, and your capacitor discharged, use extreme caution to remove the lead that leads to the capacitor. You can leave the ground connection attached. The side of the diode that goes to the ground is usually marked with a dot, stripe, or arrow. Set your ohmmeter to R x 10,000 or higher. Touch the positive meter probe to the anode and the negative meter probe to the cathode to measure the resistance across the diode terminals. Remember that the cathode is on the side that goes to the ground, which is often marked by a dot, stripe, or an arrow.
A normal diode, that is a non-defective diode, will read anywhere from 50,000 to 200,000 ohms. Differences in microwave make and model account for this large range in resistance readings.
Reverse the meter probes and measure resistance while touching the positive probe to the cathode and the negative probe to the anode. Reversing the probes like this should result in a reading of infinity. Unless a bleeder resistor is present. The presence of a bleeder resistor would produce a reading of the value of the resistor.
High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating. Test your microwave's magnetron. Replace it if it is defective.
Testing a magnetron
NOTE: Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitor.
There are two tests to conduct in order to determine whether or not a magnetron has become defective. If you receive results other than what are detailed below, you will have to replace your microwave's magnetron. Each test is described for you here:
TEST 1: Locate your magnetron and label each of the wires attached to it so that you know which wires are to be replaced where. Set your ohmmeter to the lowest resistance scale. Take a resistance measurement between each of the magnetron's terminals by touching each probe to one terminal each. Reverse the probes and take a second resistance measurement. Each measurement should read less than one ohm.
TEST 2: Set your ohmmeter to its highest resistance scale. Touch one of the meter's probes to a magnetron terminal. Touch the other probe to the metal magnetron housing. Take special caution to not touch the two probes together. This could result in an inaccurate reading. This test should produce a reading of infinity - indicating an open circuit.
Read the tips on the below links on how to replace your microwave oven's diode and how to discharge the capacitor.
http://www.fixya.com/support/r7088355-replace_microwave_ovens_diode
http://www.fixya.com/support/r7088317-discharge_microwave_ovens_capacitor
I hope the above is helpful.
Regards.
Nov 13, 2011 | Maytag MMV5186A Microwave Oven
Don't heat consistantly micro or conv--sympthems-- no oven light no heat --occasionally ok--- ser. #113806
Hello there,
The problem could be from the power diode. A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
Also a capacitor could be faulty. A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating or working intermittently. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Finally, the magnetron could be faulty. A defective magnetron is the third possible cause of why your microwave is not heating. Test your microwave's magnetron. Replace it if it is defective.
You will have to test them and replace the faulty component amongst the three factors.
Hope this helped.
All the best.
Elect_Comp
Oct 31, 2011 | Sharp R-1870 Convection/Microwave Oven
Sharp r-957 everything appears ok but not heating/cooking
Power Diode
Testing a diode
Magnetron
Testing a magnetron
Regards.
Oct 27, 2011 | Sharp R-930AK Convection/Microwave Oven
Heats up barely 2 oz water lukewarm in 60 seconds. JE1140/JES 1142 microwave. HV Diode appears open. Should it look open one way and conduct the other as a normal silicon diode on a meter ? Magnetron...
Probably bad magnetron, GE uses the worse mags OM75P is Junk. They go out frequently. And they charge a LOT for them. Find a place called Global MicroParts. They are in Texas. www.allapplianceparts.com They may sell wholesale only, Im not sure. But their parts work great and last.
Aug 18, 2017 | GE JE1140 Microwave Oven
The oven is not heating the food
Power Diode
Testing a diode
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Testing a magnetron
Good luck.
Mar 19, 2011 | Panasonic NN-S255 Microwave Oven
GE Spacemaker microwave works but does not heat. Model # JVM1440WD003.
Investigate these three areas if your microwave won't heat and you hear a loud buzzing or humming noise:
Power Diode
Testing a diode
Magnetron
Testing a magnetron
Take care.
Feb 15, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Does not heat up food everything else is OK i think that the rack touch the door when i was using it
Double check and make sure that the rack did't scratch the paint inside the cavity. Could be two possible reasons for it not to heat. Could possible be the magnetron or the diode. Normal when the magnetron goes bad, the microwave will still sound almost normal, bit just wouldn't heat. when the diode goes bad the microwave tends to make a humming sound when turned on
Feb 12, 2011 | Whirlpool MH3184XP Microwave Oven
Microwave won't heat, light ,clock works the microwave just won't heat the items in it.
hELLO THERE
when a microwave quits heating but every thing else is ok normally
investigate these 4 areas
Investigate these three areas if your microwave won't heat but you hear a loud buzzing or humming noise:
microwave_diode.jpg Power Diode
picturena.gif High Voltage Capacitor
microwave_magnetron.jpg Magnetron
Nov 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My Model NN-9859 microwave blew a fuse. I replaced the fuse and it blew again.I tested what I think is a diode HVR-1X4 ( from the main capacitor to earth) with a multimeter and it appears open circuited....
The component described is a resistor rather than a diode and is how the capacitor is grounded (to the chassis). It is possible to replace this, however it is a high voltage resistor (rather than your regular carbon film or wirewound ones).
The cost for the part will be around £5 ($7-10) and can usually be purchased from specialist electronic component supplies such as RS or CPC - your local microwave repair shop may even have some there!
Mar 20, 2010 | Microwave Ovens
Microwave Ovens Logo
826 people viewed this question
Top Brandt Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Chuck
Are you a Brandt Microwave Oven Expert? Answer questions, earn points and help others
