Question about Solis Palazzo Espresso Machine
Solis 983-40P Palazzo
The display indicates that no water in water tank but there is water! I removed everything, put back and filled with water but the problem is still there. Please help - or provide with local repair store phone number - Michigan
Thank you!
There is a float in the water tank (small rectangular shape) in the tank that raises to the top of its guide when there is suffcient water in the tank. There is a proximity sensor in the machine that turns on the red "no water" light if it does not detect the float. Ensure it is free to move. There is no flow meter in the machine.
Posted on Aug 30, 2008
  • 515 Answers
Try to make a cup of water to see if it gets in ready position.
If you have a magnet in the water tank, make sure that flow up when you fill the water tank with water.
If the problem still are ther i think you have to replace the flow meter in the machine.
Posted on Aug 11, 2008
Container leaking water
Ther is tank seal that is at the base of the machine where the tank goes on . it will dry up , waer out and leak overtime.
Apr 20, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
Indicator showing a water droplet sign on the left lights up red. What does that means? How to solve the problem?
could be one of two things
the machine is asking to be primed or ventilated , where you turn the hot water on till the light goes out.
or is asking for tank to be filled. There is a magnet float in water tank sometimes it stops floating making the machine think there is no water. to check fill tank with water and look to see if float is floating it will be grey/black in bottom corner of tank
Feb 07, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
Solis palazzo espresso maker / water tank problem
Did you push the water button, before you opened the knob? When you finished descaling did the lights change? On any compact machine you need the let the pump stop on its own. Then go to the next part, rinsing. Again letting the machine stop on its own. Pump will stop and the lights will change. Once the machine has finished rinsing. You will have a steady water light and a blinking green light. Put your tank back on with fresh water, then push the water button(far right), then open the knob for water. The red light should go out, and the machine will heat again.
Dec 22, 2009 | Coffee Makers & Espresso Machines
The needs water LED is flashing yet I filled the
Your sensors are playing with you. As long as you know there is coolant, drive it for a bit. The sensors may reset themselves. But before doing that, On the back top of the engine there is a ground strap. Not a huge one, only about 1/4 in wide. It is attached to the engine and the body of the vehicle. When they come loose or have a poor connection, everything in the car goes its own way. So, give it a chk first thing. Good Luck, Ned
Oct 31, 2009 | Solis Palazzo Espresso Machine
Steam/water valve leaks water, only fills coffee to 50%, help? I have completely removed steam valve assembly to clean and reassemble. Leak persists, suspect o-rings?
If your water valve is cream or black colored, you need a new manifold. They will get hair line cracks if you steam, but don't cool them down after steaming by running cold water through them. If you have one of the new brass(silver) manifolds it could be your O-rings but i doubt it.
Oct 07, 2009 | Solis Palazzo Espresso Machine
Need to buy water tank of solis pallazzo coffee maker
The only importer of solis I know of is, they will have the parts needed.
May 29, 2009 | Solis Master 5000 Espresso Machine
Solis Palazzo Descaling (?) Problem? Please Help!
He has the first part correct, but when you rinse the machine with fresh water the machine needs to quit on its own and you will know this when the descale light is off, but you will have a flashing green light and a steady red light over the water drop. Refill the water tank, the close the steam knob and then open it again. This will clear the red light and then the machine will start heating. IMPORTANT on any automatic machine is when the water tank is off the machine don't do anything with the beans. A chip of bean in the water receptacle can be a big problem for the machine.
Jan 28, 2009 | Solis Palazzo Espresso Machine
The machine is still stuck in the descaling cycle. You must open the steam valve and let all the liquid drain from the tank. This takes approx. 45 min. because it comes out intermittenly. After this is complete all the front buttons will flash. Close the steam valve, rinse the tank, then fill it with fresh water. Open the valve again and let all the water drain from the tank again. This time it will only take a couple of minutes. After it has completed close the valve and the machine will return to normal operation.
May 29, 2007 | Solis Palazzo Espresso Machine
Solis Palazzo Espresso Machine Logo
110 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
