Question about SIS741GX-MN Motherboard
As soon as Windows xp home began to load....
Sis SIS741GX-MN Motherboard I just bought worked fine. I have a LCD monitor as soon as I got to the part of win xp home where it begins to install file, the screen went into colorful vertical lines and my MB speaker started beeping 2 twice then quiet and 2 twice and so on.
Rick
[email protected]
  • 1 more comment
  • Obenour Aug 10, 2008
    Thanks Map9966, I did make an error in my explaination it is 3 beeps and a pause which I think is a mb fatal signal.
    Do you agree?
    Thanks much!
    Obenour
    Hey thanks much, but I made a mistake. There is 3 beeps and a pause! I located some error beep data and it says 3 beeps and pause is bad motherboard. Do you agree?
    Thanks map9966
    Obenour
  • Obenour Aug 12, 2008
    I changed the memory and made sure they were tight and it did not seem to make any difference.
    Obenour
    President:
  • 2,351 Answers
Hi Obenour,
Two beeps than a short pause than two beeps again repeating means. A memory parity error has occurred in the first 64K of RAM. The RAM IC is probably bad. Best thing to do is download a memory testing bootable software for a floppy disk. This program works out side of windows. It will test you're memory.
http://www.memtest.org/
You'll need display for this. If you have more than one bank of memory installed, remove all but one. Check your manual & see which DIMM slot the memory should be in as a single DIMM. If you only have one DIMM replace it. Test you're monitor on another system or laptop. (Checking it on another system, verify’s its good).
Monitor display good! Than check video card (If you added an 8x AGP card). Remove & reseat the card. Check again for good display. Still no decent display? Windows will not install file correctly with bad memory. You will not receive clear display on your monitor.
Posted on Aug 09, 2008
    Sergeant:
  • 395 Answers
If you have SATA hard disk - do not set AHCI mode in BIOS for IDE - use compatible mode.
Check memory is fitted correctly and is correct type.
  • Steve Si
    Steve Si Aug 10, 2008
    3 beeps is bad memory - is memory loose?
SOURCE:
Where we can get display drivers
You can download the drivers from the following link; http://www.asrock.com/mb/download.asp?Model=K7S41GX&o=XP
This is not a SiS motherboard but the drivers will still function. The chip-set is the same as the SiS MB,(741GX + SiS 963L) North bridge and South bridge chipset.
Happy holidays!
Mike
Dec 17, 2009 | SIS741GX-MN Motherboard
Cpu
If functioning correctly, your motherboard will support the following types and speeds of CPU's
  • Supported Processors:
  • AMD Athlon XP/Sempron/Duron
  • Socket A processors
  • 200/266/333 MHz FSB
So likely it tops out at Athlon XP3000+ /333MHz
or
Sempron 3000+ socketA/462.
May 31, 2009 | SIS741GX-MN Motherboard
SIS741GX-MN
drivers of t series main board intel 945g chpset
Nov 03, 2008 | Computers & Internet
K7S&41GXMG-6L-SIS-741GX socket A motherboard
You should be able to get everything you need HERE
Aug 02, 2008 | SIS741GX-MN Motherboard
VGA Drive
Hello there.
For windows 2000, Windows XP, Windows ME: Click here
This is a zip file which requires Winzip or Winrar to open. Then you can run the setup file to set up the VGA drivers for your system. Please note that you may need additional drivers, you can download these from www.sis.com/download/ but if you post back we can assist you futher.
Hope this helps.
Jun 16, 2008 | SIS741GX-MN Motherboard
No audio
i need to help.
my motheboad have audio problem,
i need audio device for install.
sis mother board, 5595 chip
Jan 30, 2008 | SIS741GX-MN Motherboard
SIS741GX-MN Motherboard Logo
148 people viewed this question
Top Sis Computers & Internet Experts
Thomas F. Schneider
Bart Fonteyne
robert roberts
Are you a Sis Computer and Internet Expert? Answer questions, earn points and help others
