Question about Intel D865GBF Motherboard
Power cut problem
Dear sir,
whenever i plug off my crt monitor(while processing is going on),and then plug on my crt monitor it gets RESTARTED automatically.
i have "intel d865gbf" motherboard.
Please give me solution of this problem as earlier as possible.
    Brigadier General:
  • 6,966 Answers
Based on your description, it is highly probable that you have something loose in the motherboard connections. Foremost to check would be:
  • the video card (if an add-on);
  • memory sticks;
  • any other add-on cards;
  • the board screws;
  • the back of the board (might be nearly touching the backing plate).
If on the other hand, you are referring to "plug off-on my crt monitor" to the power cord of the monitor to the back of the PSU, then have your PSU checked or replaced.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 13, 2008
MAG LT1919W Wide screen flat panel monitor
check for a different cable problem sir
if no the leave the monitor plugged off from wall power for one night and check if it works
Aug 03, 2008 | Mag Innovision Computers & Internet
I have LG 700E 17'' CRT monitor.While i start my pc,there will be a big sound coming from the monitor.You may think it may be a common sound comes in monitor but it's not a small and common sound. When...
suraj2567, Get rid of that very power hungry CRT type monitor LG700E!!! It's that, or get a new 1400 to 1500 va UPS. Then you won"t be able to yank and **** the output of the UPS around anymore when you turn on your old CRT monitor!!! Also check the status of the OLD SLA battery inside the UPS you are using. If it is more than 3yrs old, it might need to be replaced due to degraded capacity to supply surge current when it is "online" during a power outage in your area...
louie12fix or 12fixlouie hope this helps you bye for now.
Nov 09, 2009 | Computers & Internet
How to reformat
To reformat the Computer :----------------------------------------- To get the computer to a Factory State then follow the instructions with the help of the Compaq Recovery CD.
  • First backup all data, files, folders to a Diskitte.
  • Second, off the computer.
  • But before Switching off the computer, insert the Recovery CD into your respective Drive, then power off.
  • Then power on and your computer and switch on with the Power Button. After the System's booting, the Compaq recovery menu is displaced.
  • Then press Enter.
  • The process will take minutes.
  • Then after the Computer Ejects the CD, take it out and press Enter.
  • They process will soon end and you have to follow the common Guidance from the Computer to completely reformat the computer.
Thank you Sir, Have a nice day.
Sep 27, 2009 | HP Compaq FS7600 17" CRT Monitor
Monitor screen went blank after changing resolution
Try unplugging the monitor and then restart, and then go back to default settings.
Jan 30, 2009 | Samsung 793S 17" CRT Monitor
Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Oct 20, 2008 | Compaq MV 540 15" CRT Monitor
Whenever system restart , led blinking, no display
15" Monitor warranty period 1 year from mfd date.
17" Monitor warranty period 3years from mfd date.
Aug 22, 2008 | LG Studioworks 45 14" CRT Monitor
Monitor Compaq Perisio 7540 (screen goes Dark) complicated
THERE MUST BE A PROBLEM WITH THE VIDEO PROCESSING CIRCUIT LOCATED AT A PCB CIRCUIT ATTACHED AT CRT BASE. THERE MUST BE SOME DRY SOLDER OR A FAULTY BASE CONNECTOR WHICH CONNECTS THIS CIRCUIT TO CRT.
YOU CAN ALSO TAKE A TRY JUST AFTER PRESSING THIS CIRCUIT FIRMLY TOWARDS CRT BASE.
MAIL ME UR RESPONSE @ VISHWAS_4U@REDIFFMAIL.COM
Jun 23, 2008 | Computers & Internet
Monitor LG FLATRON E700SH
Sir,
I hve read all above statement which shown as above. but in my case monitor take time to ON and display the screen, its take at least 45 minutes to start up and display the window screen. So please to send me solution about my Query.
Thank's
Feb 21, 2008 | LG Flatron Ez T910BU 19" CRT Monitor
Monitor
-Turn off both computer and monitor
-unplug monitor from computer(still plugged into power supply)
-turn on computer and monitor(monitor is still unplugged)
-After computer is on for about 30 sec. plug monitor into computer
-turn off both monitor and computer(now connected together)
-turn on monitor then computer and should be good to go!!!
Mar 25, 2007 | Sony CPD E230 17" CRT Monitor
Intel D865GBF Motherboard Logo
46 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
