Hi i have a wirless router DG834G and am trying to connect to my server BT but dont seem to be able to do that
  • 3 Answers
Can you be more specifiec, your email is lack of details thanks
Posted on Aug 09, 2008
I have adg834g router supplied by BT. I have since changed my ISP to Post Office who supplied me with another router. My phone lines run right through the house but the wireless signal is poor at one end...
I understand that you would like to extend the wireless coverage in your home with the DG834G. I would suggest you to configure DG834G as an access point to extend the coverage of your post office router using the below steps:
1. Connect a computer directly to DG834G on any of the four LAN ports.
2. Access the router's GUI by typing http://192.168.0.1 or http://www.routerlogin.com.
3. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
4. Click on wireless settings in the left hand side menu Under Setup.
5. Change the network name SSID to some other name.
6. Select security options as 'WEP (Wired Equivalent Privacy)'.
7. Set the 'Authentication Type' as 'Automatic' and Set the 'Encryption Strength' as 64-bit.
8. In Key 1 type a 10 digit number.
9. Apply the settings.
Click on LAN IP setup from the left menu.
1. Change the IP address of the router from 192.168.0.1 to a free IP address in the range of the Post office router.
2. Also disable the DHCP of the router by unchecking the box for 'Use router as DHCP Server'.
3. Click apply and click ok for any popup message that arise.
4. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, turn off the router and restart the computer.
Now, connect the two router in the following way:
1.Connect Ethernet cable from the Lan port of the Post office router to the Lan port of the DG834G
2. Powercycle both the routers and your computer
3. You may connect other computers' directly to DG834G or wirelessly as per your requirement.
I hope this information allows you to resolve this issue.
Regards
Anand
Mar 12, 2011 | NetGear DG834G Router
I have a Netgear DG834G v4. Wireless connection is fine, ISP is fine and Internet via wireless is perfect. Nothing via the LAn ports seems to work. Both XP and Win 7 machines see Lan as an undefined...
DHCP SERVER in Router and DHCP server in Wireless Conflicting - Set WI Fi DHCP router leases to say 192.168.0.10 to 192.168.0.100 and default gateway as 192.168.0.1 and on the router set the router's ip address to 192.168.0.1 make the Wi Fi router address 192,168.0.2 . Set in the router the DHCP address leases to 192.168.0.101 - 192.168.0.254 and default gateway 192.168.0.1 or deactivate one of the dhcp servers and rely on one dhcp server like the routers and then deactivate the wi fi's dhcp server.
Jul 28, 2017 | NetGear DG834G 54 Mbps 802.11g Wireless...
Have wireless broadband on home computer with Netgear dont have network key which I need to connect new laptop to wireless broadband Bt of no help and cannot give me a no fo Netgear either even though Bt...
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Dec 19, 2009 | NetGear DG834G Router
Got a new mobile phone and trying to connect it with my wirless through WLAN ..but then my phone is asking for a pre-shared key for wlan and i do not know it
goto router log in page and in wireless settings remove encryption ,apply it then try connecting your device again.
Sep 28, 2009 | NetGear DG834G Router
I connected my netgear wirekess router succesfull however after i installed the wirless dongle it comes up saying i am connected with a limited service and wont alloy me to go on line please help if u can
repair the connection by right clicking the wireless connection and choosing Repair. if that doesn't work then you should try to disable and then re-enable the connection. try adding the IP address of router to you list of DNS servers for the wireless connection.
Jun 23, 2008 | NetGear DG834G 802.11G Wireless ADSL...
My netgear modem router DG834G
hello!
-- do you have other wireless computer on the network?
-- what is the model number of the wireless adapter that you are using?
-- have you check if the wireless settings on your router are still configured correctly?
-- can you get online if you are directly connected to the router?
Apr 07, 2008 | 3Com SuperStack 3 RAS 1500 Base Unit...
Netgear DG834G v3 Installation
connect the yellow (or blue?) ethernet cable to your computer, this should connect to the router (router should be ON)
Now, in internet explorer type 192.168.0.1 (this should be the defualt gateway for the router on default settings.
Now you're into the router, there should be a setup wizard button in there.
See if you can set it up using that
Regards
Tony
Feb 28, 2008 | NetGear DG834G Router
Cant connect to cable
Hi Snuggles,
Make sure your networking permissons are setup properly, on the Vista. Since it varies with what version Vista you have, try this link.
http://windowshelp.microsoft.com/Windows/en-US/default.mspx
Great help site for Vista. Click on the Network tab, follow the info to setup your networking, and if you are still having issues, got to the troubleshooting. Please make sure you doing your setup with a cable, too, not over the wireless.
Good luck
Jan 10, 2008 | NetGear DG834G Router
Acquring network conections
do you know who set up your router im guessing its not you as you dont have your wep key if you do have it its easy if you dont you need to connect to your router with a cable to get the wep key once done you mat need to set up your ip address on your laptop it should be 192.168.0.2 with a sub mask of 255.255.255.0 and a default gateway of 192.168.0.1 and a primary dns server of 192.168.0.1
any more help just ask
Oct 29, 2007 | NetGear DG834G Router
Computers & Internet Logo
David Payne
David Payne
