Installing Hiotachi Deskstar 400gb hard drive
I have installed a Hitachi Deskstar 400gb hard drive I have windows xp the hard drive shows up in device manager and the drives are fine but when I click on my computer it doesn't show up. There is .no settings on the hard drive to set it to slave.Any advice please
Thank you
  • 3,051 Answers
In order to set it to slave you first needs to make sure the cable that u hoodked up to the hard drive is the slave not secondary then boot the computer to the bios and then under the ide section section you need to ensure that the hard drive is recognized as primary slave it will show the hard drive as a primary or a secondary that will let you you that u have the cable hooked up to the harddrive right if not usee the other connector on the same cabel and repeat the bios settings i know it sounds hard but it really is not good luck !!!!
Posted on Aug 09, 2008
How to format/install SATA 2TB hard drive (BARRACUDA) in Gateway GT5098E, Win XP Media Center Edition 2005?
Windows XP doesn't support SATA. You will need to use a program such as Nlite to integrate sata drivers into a new Windows XP disc. Once you have a disc with sata drivers just boot to the disc and follow the prompts to format the drive.
Jan 04, 2013 | Gateway "HITACHI DESKSTAR 0S02861 2TB...
Windows xp not install heng problwm more restart
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Nov 24, 2010 | Hitachi Deskstar® T7K250 160 GB SATA Hard...
My computer has two Hitachi hard drives. I had a corrupted Windows XP operating system that went nuts and when I was re-installing WinXP it stopped part way through and stopped. Dropdown window said and...
These are quite an old hard drive and they are probably pass there due date, unfortunately the only way is to replace the faulty drive, I have had these problems and after changing to the later SATA versions I have had no problems since.
You can still buy these type of hard drives but they are getting expensive now as the newer versions are the normal fitted type and the cost for the same size can be half the price. Once they become faulty they really just need to be thrown away.
Hope this helps.
Oct 19, 2010 | Hitachi Deskstar P7K500 HDP725050GLAT80...
Hitachi Deskstar P7K500 HDD keeps unmounting within Windows....
1. Right click on My Computer > Manage;
2. On the new window click on Disk Management, on the right side, right click in the USB Volume and chose "Change Drive Letter and Path..."
3. In the new window click on "Add..." to assign a letter to your USb drive.
Best Regards
Jun 24, 2009 | Computers & Internet
I added an SATA HD to a system whose C and D drives are a WD 400GB PATA HD. The Hitachi 750GB drive has no jumpers for master/slave. After boot-up the system sees it but assigns no E or other letter...
  • Right Click [My Computer] and click Manage
  • Click Disk Management on the left side
  • Inspect the drives listed. The new drive may need to be formatted for the operating system to recognize it and assign it a letter.
  • To format the drive, right click the drive with no letter, and click Format. Choose your format (Preferred NTFS), and quick format the drive so that windows recognizes it.
Mar 10, 2009 | Hitachi Deskstar 7K1000 750 GB SATA Hard...
Cannot see drive letter for deskstar 7k250 in usb enclosure winxp
Add a letter for this HDD in "control panel\performance and maintenance\administrator tools\computer manager=ment\disk management"
Feb 16, 2009 | Hitachi Deskstar® T7K250 250 GB Hard Drive
What to do with unreadable but recognised hard disk segate 400GB
Your Windows Xp bootable CD should have an option called "Format his file system using FAT32" while installing the OS. Use the option to format it. The only prob is that it creates only a single partiotion. After installing windows you can re-partition using a third party software such as Partition Magic(please note that it will not affect your windows installation as you can first re-size the windows drive to a lower capacity and then partition the un-allocated space.
Nov 29, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
Trying to get data off an IDE drive from a dead system
this MS link will help you configure it so you can read it
Oct 27, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Hard drive
hi dear
use a cd booting
in command prompt c:\
type c:\fdisk /mbr
to fix your master boot record\
and make your partiiton active.
after that installing your windows XP
Mar 15, 2008 | Maxtor Hard Drive
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
