Question about Panasonic Vacuums
Trying to replace the mains cable on uproght cleaner mc e468,but having great trouble getting the plastic covers off
First remove handle
single screw rear of cleaner and slide handle horizontally rearwards
remove access cover (2 screws) for electrical connections and switch
Posted on Mar 10, 2009
Panasonic mc e468
My guess is it has plastic teeth that latches on somewhere, use flathead screwdriver gently to see if it'll budge. Normally the bottom is where it detaches, start there.
Jul 14, 2014 | Vacuums
How to rewire a panasonic vacuum cleaner
Once you have taken the handle off and the front plastic cover below the handle at the front and above the bag/bucket holder, you gain access into the power cable and switch connections.
One wire will disconnect easily, the other won't, so instead of trying take this wire out of its connection where many others are from the switch and the motor, cut it on the mains lead before it enters the connection and reconnect the new mains lead wire with a **** or block connector, the other should connect normally with a spade connecter,making sure its will take the amperage of the v/cleaner
Hope this makes sense!
Sep 18, 2009 | Vacuums
Removing cover to motor
You will have to access the motor by removing the entire bottom brush housing and tilting the vac motor shaft out of the housing. Once released you will have a main body and brush housing.
There are visible motor housing screws in the lower portion of the main housing and if I recall there may be twoscrews inside the bag chamber as well
Sep 09, 2009 | Panasonic MC-V5209 Vacuum
Electrolux z4494 vacuum cleaner mains cable wont stay out
Opened up case as follows:
- Open lid of bag chamber. Remove lid by gentry prising the hinge arms slightly further apart so the hing unclips from the body.
2 deeply recessed screws now accessible at rear edge of bag chamber - undo.
Prise out large button of on/off switch to reveal another screw - undo
Prise out large button of cable retract to reveal another screw - undo.
Cover now lifts off.
Inside I found the brake wheel had fallen out of its plastic bracket. The plastic bracket is hinged, and moved my pressing one end with the big button, which lifts the wheel away from the cable drum. Gently prised the bracket arms apart and put the brake wheel back in.
Solved it - but don't know why it happened, or whether it is likely to happen again.
Sep 01, 2009 | Electrolux Vacuums
The 10 amp thermal fuse on my Panasonic MC-E468 vacuum cleaner has blown. Unfortunately the red ink has worn off exactly where the temperature rating is printed so even with a magnifying glass cannot make...
It appears the fuse is not available separately. Standard retail price for the complete unit is £9.00 including VAT. We can supply at that price plus postage and packing at cost, which would probably be no more than £2.50.  If this is of interest to you, please reply with an email address where I can contact you direct.
Apr 14, 2009 | Vacuums
Panasonic MC-E468 vacuum cleaner loss of suction
HI If the cleaner is loosing suction make sure to check all inspection tubes and the dirt channel hoses after the spinning brush. Also check the main hose for any clogging. One of the worst faults of this model is clogging hoses. Hope that helps you.
Feb 27, 2009 | Panasonic MC-E583 Bagged Upright Vacuum
Filters for panasonic vacuum cleaner MC-E468
Hi! Sometimes really hard to remember which of these models is which, so please forgive me if this is not a complete solution.  I'm pretty sure you will find there are two filters.  The first is a foam filter, and is located at the bottom of the bag compartment.  It pulls out to the front, and is washable (of course it must be completely dry before re-use).  The second (and here I'm on less secure ground) is a HEPA filter, and is located behind a removable panel on the front of the bag compartment door.  The HEPA filter is not washable, but rarely if ever needs to be changed unless the machine has been used for vacuuming a lot of extremely fine dust. I hope this helps, and I value your feedback. Please remember to rate my response.  Good luck!
Feb 24, 2009 | Panasonic Vacuums
Parts for Mcculloch MC 1275 steam cleaner
You can find your parts on amazon. take a look here Amazon com Mcculloch MC 1275 parts. I hope this was helpful. cheers
Nov 15, 2008 | McCulloch MC1275 Steam Vacuum
Panasonic Vacuum MC-E450UK
Panasonic MC-E 450UK upright vacuum cleaner.
Just had this problem myself...........easy to get at it when you know how.
Panasonic UK wouldn't help me so I spent some time working it out..........here it is.
Remove the hose from its mounting storage at the rear (called hose clip) where the main body of the vacuum cleaner meets the base of the handle assembly. Remove the screw at the rear of the handle assembly which is behind where the hose 'was' situated and is located inside the deep recess.
Using the soft part of your clenched hand as a hammer, knock the base of the handle assembly at the front and it will slide backwards off the main body of the vacuum cleaner. Don't be scared, give it a thump and keep moving it backwards with a few more knocks.
Next remove the two screws at the front which hold the mains cable and on/off switch cover in place.
Finally looking from the rear once more, lift the plastic 'lug' at the top of the cover and which is part of the cover. This will now allow you to release the cover and pull it forward.
There you go! Told you it was easy!
Watch out for the funny little spring at the front behind the cover in the tiny plastic tube where it connects to the small rubber tubing as it could possibly try to escape.
You now have complete access in order to cut the intermittent part of the cable out and remove it from the 'choc' block.
Happy fixing!!
Jack.
Apr 07, 2008 | Vacuums
Vacuums Logo
412 people viewed this question
Top Panasonic Vacuums Experts
Jim Parker
Jim Parker
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
