Question about Acer Computers & Internet
Since upgrading windows XP to service pack 2 my Acer Travelmate 290xci the bluetooth and wifi doesn't work. The view networks doesn't do anything and no networks are detected
  • 3 Answers
The bluetooth and wifi of your laptop is not working after you upgrade your system to windows xp this is due of driver problem you need to instal the updated driver/software of your bluetooth and wifi that is compatible for windows xp....
Posted on Aug 09, 2008
SOURCE:
Acer travelmate 4000
You'll need to select a wifi network to connect to. Also, bluetooth doesn't work that way, bluetooth is used to connect 2 devices to share files, it does NOT give you access to the internet
Jan 27, 2014 | Computers & Internet
I have the acer5715/5315 series abd it crashed. I had it fixed and the guy put windows 7 so now none of my acer programs work. How can I get these to work with windows 7
Operating System Windows XP Professional with Service Pack 2
Windows XP Home with Service Pack 2
Windows Vista Home Premium
Windows Vista Home Basic
Windows Vista Starter
1. Before upgrading to windows 7, you must check the specification of your acer aspire 5315.
2. Windows 7 is better than windows vista but if you are really wanted those acer programs to work. You have to downgrade your operating system from your previous operating system.
Nov 15, 2010 | Acer Aspire 5315 Notebook
I was given an acer travelmate 4230 which used to have vista but now has xp pro. I installed acer bluetooth drivers and software, but a popup tells me that the hardware could not be found. where in the...
On the Acer site, the list does not show a bluetooth.
TravelMate 4230 Series Specifications Part Number: TravelMate4230 TravelMate 4230
Feature Description Model PN CPU RAM HDD Optical LCD LAN OS TM4230-6128 LX.TES06.008 C2DT5500 2*512 120 8X Supermulti. 15.4 802.11abg XPP PT TM4230-6240 LX.TES06.012 C2DT5500 2*1G 160 8X Supermulti. 15.4 802.11abg XPP FR TM4230-6254 LX.TES06.006 C2DT5500 2*512 120 8X Supermulti. 15.4 802.11abg XPP FR TM4230-6327 LX.TES06.036 C2DT5200 2*512 120 8X Supermulti. 15.4 802.11abg XPP ES TM4230-6433 LX.TES06.005 C2DT5500 2*512 120 8X Supermulti. 15.4 802.11abg XPP EN TM4230-6434 LX.TES06.011 C2DT5500 2*1G 160 8X Supermulti. 15.4 802.11abg XPP EN TM4230-6704 LX.TFF06.089 C2DT5200 2*512 120 8X Supermulti. 15.4 802.11abg XPP EN TM4230-6760 LX.TES06.007 C2DT5500 2*512 120 8X Supermulti. 15.4 802.11abg XPP ES TM4230-6822 LX.TES06.030 C2DT5200 2*512 120 8X Supermulti. 15.4 802.11abg XPP PT TM4230-6909 LX.TES06.034 C2DT5200 1*512 120 8X Supermulti. 15.4 802.11abg XPP PT Part Number See models above Processor / Speed Intel® Core™2 Duo processor with Intel® EM64T support:
T7200/T7400/T7600 with (4 MB L2 cache, 2/2.16/2.33 GHz, 667 MHz FSB) or
T5500/T5600 with (2 MB L2 cache, 1.66/1.83 GHz, 667 MHz FSB) Core Logic Chipset Intel® 945PM/GM Express System Bus Speed 667 FSB RAM / Max RAM 512 MB of DDR2 533/667 MHz memory, upgradeable to 4 GB using two soDIMM modules (dual-channel support) Video Subsystem Intel® Graphics Media Accelerator (GMA) 950 with up to 224 MB of shared system memory, supporting Microsoft® DirectX® 9.0, PCI Express® LCD Properties 15.4" WXGA TFT LCD, 1280 x 800 pixel resolution Hard Disk Drive 80GB or higher CD-ROM Drive 8X DVD-Super Multi double-layer drive Battery, Primary 44W 4000 mAh Li-ion battery pack (6-cell) with up to
2.5-hour battery life or
71W 4800 mAh Li-ion battery pack (8-cell) with up to
4.5-hour battery life
(varies by model) Sound Subsystem Intel® High Definition audio support
Two built-in Acer 3DSonic stereo speakers
Built-in microphone
Sound Blaster Pro™ and MS Sound compatible PCCard Support 1Type II PCCard slot Pointing Device Touchpad Peripheral Subsystem 4 USB 2.0 ports, 1 VGA port
Headphones/speaker/line-out jack, Microphone/Line-in jack
5-in-1 card reader (SD, MMC, MS, MS PRO, xD)
Acer OrbiCam™ integrated 1.3 megapixel CMOS
(selected models) Modem 56K ITU V.92 PPT approved, Wake-on-Ring ready Ethernet 10/100 Fast Ethernet, Wake-on-LAN ready
Intel® PRO/Wireless 3945ABG (dual-band tri-mode 802.11a/b/g) Dimensions / Weight 14.09" x 10.43" x 1.15/1.41"
6.09 lbs (with primary battery) AC Power 100-240V AC AutoSensing Adapter
Environment
    Shock
    Operational/Non-Operational
5 G max. pulse / 40 G max. pulse
    Vibration
    Non-Operational
5-27HZ, 0.16" p-p, 2g peak, 27-500HZ
    Temperature
+5ºC - +35ºC / -20ºC - +50ºC
    Humidity
10% - 90% / 10% - 90%
    Altitude
10,000 ft / 40,000 ft Operating System Windows XP Professional with Service Pack 2
(varies by model)
Apr 07, 2010 | Acer TravelMate 4230-6499 Notebook
I just bought a 2nd hand acer travelmate c110 and does not have anything so i installed a windows xp service pack 2. my question is i cannot use the touch screen is there any driver for it?
Go on acer's website and look for that particular model where you will get a list of downloads available for this model.You should be able to find the driver for this touchscreen and install it.If this does not work then you may have a hardware fault.
Dec 13, 2009 | Acer TravelMate C110 Tablet PC
Windows vista to windows xp sp2; the VGA and wireless don't work
uninstall the wireless driver and then reinstall it again and then install the vga driver and do the wireless configuration from the router page,and then try and install the wireless driver of xp and also install the vga driver of xp.......good luck.....
pls rate this solution
Feb 16, 2009 | Microsoft Windows Vista Home Premium with...
Acer wifi
Most Acers use an IPN2220 Wireless card. If yours does and your router is using WPA or WPA2 (TKIP or AES) security then you'll need to update the driver by searching for it manually using the Custom button (Hardware) in Windows update (instead of Express). This driver is not part of XP service pack 2 or 3. In my experience if you don't update to the newest common form of home wireless security (WPA2 AES) then the older formats seem to become unreliable in the way you describe
May 10, 2008 | Acer TravelMate 3260-4874 Notebook
Acer 2300 travelmate laptop
Try this:
  1. Press Windows Button & Pause/Break to go to the System Properties (or right click on My Computer and choose Properties, but the other way is more fun.)
  2. Choose Device Manager.
  3. Expand the Universal Serial Bus controllers section
  4. Right click and choose Properties of one that says something about PCI bridge (I forget the exact name and after you fix the problem, this item goes away. If you aren't sure, you try step 5 and 6 on all of the USB items in that list.)
  5. Click on the Driver Tab (it's kinda slow loading).
  6. If the driver information on top says "Not found" or "Not installed" then click Update Driver... and let it look for the driver itself (I didn't need the XP CD but that might be because I keep a copy of it on my hard drive just incase. You might need it, I don't know.)
  7. After it finds the driver, click Okay and USB should start working immediately - no reboots needed!
May 05, 2008 | Acer TravelMate 2300 Notebook
Acer TravelMate 4020 Blutooth
does not have ! Look at the "communication" tab
Acer TravelMate 4020 Notebook Specification:
Operating System Linux BE (Basic Edition) Platform Intel® Pentium® M processor 725 (2MB L2 Cache, 1.6GHz, 400MHz FSB)
- Intel® 915GM Express Chipset
- Intel® PRO/Wireless 2200BG Network Connection 802.11b/g Memory 256MB DDR2 SDRAM, upgradeable to 2GB Display 15.4" WXGA TFT LCD, 1280 x 800 pixel resolution Graphics Intel® 915GM integrated 3D graphics, featuring Intel® Graphics Media Accelerator 900 and up to 128 MB of shared memory, supporting Microsoft® DirectX® 9.0 and dual independent display Audio Audio system with built-in speakers
MS Sound compatible
Built-in microphone Storage 60GB ATA/100 HDD Optical Media Drive DVD/CD-RW Combo Drive Communication Modem: 56K ITU V.92 modem
LAN: 10/100 Mbps Fast Ethernet
Wireless LAN: integrated Intel® PRO/Wireless 2200BG network connection Size & Weight 364 (W) x 279 (D) x 33.9/38.9 (H) mm (14.3 x 11 x 1.3/1.5 inches)
2.95 kg (6.48 lbs.) Power ACPI 1.0b power management standard
32.6W Li-ion battery pack (4-cell), battery life: 2.5 hours Special Keys & Controls 88-/89-key Acer FineTouch™ keyboard with 5-degree curve, inverted "T" cursor layout, international language support, 2.5 mm (minimum) key travel
Touchpad with 4-way scroll button
12 function keys, four cursor keys, two Windows® keys, hotkey controls, embedded numeric keypad
Four easy-launch buttons: Internet, email, Empowering Key, one user-programmable button
Two front-access LED-buttons: WLAN, Bluetooth® I/O Ports Three USB 2.0 ports
PC Card slot (one Type II)
External display (VGA) port
Headphones/speaker/line-out port
Microphone/line-in jack
Ethernet (RJ-45) port
Modem (RJ-11) port
DC-in jack for AC adapter Software Optional Items Li-ion battery pack
65 W AC adapter
256/512 MB or 1 GB DDR2 533 soDIMM memory modules
External USB floppy disk drive Warranty 1 (one) year International Traveller's warranty (ITW) Price
Jan 21, 2008 | Acer TravelMate 2300 Notebook
Wireless problem on acer travelmate 290
I feel that you have Windows XP with Service pack 1. Am I correct? If so, please install Service pack 2 for xp and your problem will be resolved. let me know. PC Expert [email protected]
Sep 23, 2007 | Acer TravelMate 290 Notebook
Computers & Internet Logo
131 people viewed this question
Ekse
Alun Cox
