Wireless working very slow
My wireless is working very slow almost impossible to work.
I update the wireless driver & BIOS didn’t help.
Data:
Wireless router: Edimax BR-6216mg I’m using WPA
Laptop: Dell vostro 1510 windows XP Pro.
Network adaptor on the laptop: Dell wireless 1395 WLAN Mini-Card
I have another laptop at home and I have no problems there.
What should I do?
  • 1 more comment
  • Yoav Shilon
    Yoav Shilon Aug 09, 2008
    The network is secure WPA
    The Signal is excellent
    If I connect the laptop directly to the router it is working excellent
  • Yoav Shilon
    Also i have another laptop that uses same wireless and it working perfect
  • Anonymous Dec 01, 2008
    Same deal here. I have 2 other notebooks that connect without issues, but my Latitude D530 is extremely slow.
    Scholar:
  • 56 Answers
Hey there
You are not getting this problem due to any BIOS and wireless driver.
as you said that you are not getting any problem with your another system.
Checkout for the range you are working in. else it wont be that much effective.
Sometimes it happens that your driver misplaced or changes its parametetr in registry without awaring you.
So first repair your wireless network
else secondly repair ur XP PRO.
this will surely help you to have a good speed with ur network.
Gimme your acknowledge
Thanx.
Romy
Posted on Aug 09, 2008
  • 19,396 Answers
Check that your network is secured with a key, unsecured networks are easily hacked and can get very slow.
  • 5 more comments
  • Ginko
    Ginko Aug 09, 2008
    First ensure that your Wireless is secured, unsecured network can be used bay anybody and often get slow for this reason.
    Also check and ensure that your computer is connecting to your own network, and is not connecting automatically to some nearby unsecured wireless network.
    Many spyware and virus software can also slow down the network, see if your antivirus is working, use Spybot - software .to check if you have spyware.
    Last thing, ensure that is not a browser problem, download an alternative browser like Opera or Mozilla to test the system.
  • Ginko
    Ginko Aug 09, 2008
    It is true that bios have nothing to do with this, sometimes old drivers can give troubles.
    You should read and test what had been already posted first, network can get slow for many reason, check all the tings posted already. Check also if you have a firewall, if net get faster disabling firewall on the laptop.
    If all this does not work you may have an IP conflict, a faulty router or wireless adapter, or another network problem.
    To troubleshoot this you will need to access to router, reset and reconfigure.
    Check first what already posted, eventually download spybot and opera, refusing all solutions after you quick read them is not of any use this is supposed to be a troubleshooting session, not a questionary.
  • Ginko
    Ginko Aug 09, 2008
    By the way, most common reason for slow network is spyware, worms etc. This often are not recognised by common antivirus, trusted antispyware are spybot and free Avg Antispyware, you should scan PC with something like this.
    Many free antispyware are in truth viruses , do not download this kind of software from untrusted source. The two mentioned above are clean. Do a spyware scan first, and see if speed improves after cleaning.
  • Ginko
    Ginko Aug 09, 2008
    then check for malaware, as suggested, does not matter if you have norton, macafee, or similar, many trojans pass through them.
  • Ginko
    Ginko Aug 09, 2008
    If you have an usb wireless adapter, try also disabling laptop internal wireless and using USB adapter, to test network. If speed is OK with new adapter then there is a problem between your router and your laptop's wireless adapter, usually an IP conflict.
  • Ginko
    Ginko Aug 09, 2008
    About static IP, you can use it to test your network, but many internet service providers does not support static IP, this means in some case internet does not work if you use static. If you set IP to static, ensure you get back to dynamic settings after testing.
  • Ginko
    Ginko Aug 09, 2008
    Try also the following,
    Download Opera Web BrowserIf network is ok with different browser than it was an Internet Explorer problem.
  • 1,879 Answers
>Download(while hard-wired) & try another browser (Firefox)
>Check if you have Internet Security Suite installed, temporarily disable it.
    Sergeant:
    Champion:
  • 327 Answers
Welcome to fixya
i would try to update the ip on the laptop to see if your haveing any type of conflict with other ips on the wireless network
goto msdos promt and ther this
type in ipconfig hit enter
then type in ipconfig/release hit enter
then type in ipconfig/renew
this might take a few min but it also will also renew your ip and might clear up any problems
hope this helps you out have a good day
    Master:
  • 521 Answers
It is definately due to the netwok of your wireless system at that particular range you are getting the problemas you said its working properly on the other system. try changing the direction of your machine and wireless system and then see.
    Novelist:
    Scholar:
  • 125 Answers
Are you using the windows wireless manager to manage the wireless on this other system? If your not you should consider using that by going into the wireless network manager by clicking on the wireless connect in the bottom corner of your screen. Click on view wireless network. Then click on change advanced settings. Click on Wireless network tab. Make sure the top box has a tick on it beside the USE WINDOWS TO CONFIGURE MY WIRELESS NETWORK SETTINGS. Then click apply and ok and restart system. See know how it connects. You might need to enter you WAP key, I use WEP on about four laptops at home with perfect connection through my D-link hub with adsl modem.
    Brigadier General:
  • 6,966 Answers
A few suggestions for you to try:
  • use static IP address on the Dell 1395 in the Dell Vostro 1510;
  • I beg to differ on the use of the WEP or WPA, experience has shown that they do cause a lot of lag and repeat requests. Perhaps you may be better off with MAC filter;
  • download, install and run/save DrTCP. A nice tutorial on its use;
  • Download and install NetStumbler. Use it to determine free channels and force your system to use that.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • 6,487 Answers
If that's the case we you need to do here is try updating the driver of your wireless adapter since the other wireless computer is working fine and alos that computer is working fine when wired to the router,, So wire that computer to the router and update the driver of it, if still the same problem you can also try adjusting the wireless channel fo your router if its on 6 try channel 11 and 1 because sometimes you need to adjust wireless settings on the router to make all wireless devcie work properly..
Hope that helps...........
  • Mark Gil
    Mark Gil Aug 09, 2008
    Did you already update the driver of the wireless adapter on that laptop that you're having problem? if not try updating it first..
  • 876 Answers
Make sure that your virus control setting for network is ON so that it will notify you if someone else is using your connection.
Update your Virus control and do a complete scan.
What does your system have running in the background? How many little icons are there in your right hand corner. A lot of proggys that are running on start up can slow you down immensely.
Clean out your cookies-Tools>internet options>general>cookies,etc.
Do you have registry cleaning software? If so use it.
Does your other laptop have more power?
If you are not sure about the strength of your virus/spyware control, go to www.trendmicro/housecall.com for a free checkup.
Or to www.comodo.com
Do you have a lot of games installed?
Check all this out and let me know if I can answer any questions.
  • 781 Answers
Check the reception for the place you are as some places have poor reception by moving 5 or 10 metres may help
Wireless button, won't come on. Stays the orange color.
This could be caused by one of the following issues:
WLAN is disabled in the BIOS. Check BIOS that WLAN is enabled. Update to the latest BIOS if not already:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-87201-1&lc=en&dlc=en&cc=us&os=4062&product=3934480&sw_lang=
Update Wireless drivers to the latest.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-78054-1&lc=en&dlc=en&cc=us&os=4062&product=3934480&sw_lang=
Update HP Wireless Assistant, try turning it on/off via Wireless Assistant
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-76368-1&lc=en&dlc=en&cc=us&os=4062&product=3934480&sw_lang=
If all these do not work, contact HP to replace switch cover which controls the wireless button, power button, mute, volume. Does the mute and volume buttons work?
Mar 09, 2011 | HP Pavilion dv6-1122us Notebook
I have toshiba l500 i changed windows vista to windows 7 now its wireless not working
First thing to do is to Go to the Toshiba Support site, ... navigate to the driver support page for your specific laptop model, ... then download and install the WI-FI drivers for your wireless card that are Windows 7 compatible. That should get your wireless working, ... UNLESS your wireless feature has been shut off in the BIOS. If that's the case, you'll need to enter the BIOS when booting the laptop and turn the wireless feature on.
While your downloading the Wi-FI drivers from the Toshiba site, you should also download the latest BIOS update IF it's a newer build than the one surrently installed in your laptop. Also download and install the motherboard chipset.
I'm pretty sure your problem should be taken care of if you follow those steps.
disaksen
Jan 12, 2011 | Computers & Internet
Do I need two wireless network adapters? I looked in the device manager folder in network adapters and there are 2... Intel (R) Pro/1000 PL Network Connection #2 and Intel (R) Pro/wireless 3945ABG...
You should have only 1 wireless adapter, the other 1 is the ethernet adapter. If you experience low signal strength even after updating the drivers, you need to customize wireless settings on the router.
You need to change the wireless mode to "802.11b and 802.11g" or "802.11g", whatever you have in your router. If this is the same with all wireless networks, wherever you go, then its an issue with the adapter, you should get a replacement.
Feb 05, 2010 | Intel PRO/Wireless 3945ABG Network...
HP Pavillion wireless won't work
First, look thru HP Health check and download all recommended.
Second, go to HP site, download and reinstall WLAN driver and HP Wireless assistant software
Third, download at the same site HP WinFlash BIOS Update and update BIOS (READ and FOLLOW INSTRUCTIONS VERY CAREFULLY)
Reboot.
If you are lucky ;-)  WLAN will now works - try to switch it on by WLAN switch.
WBR, Planet
Jul 18, 2009 | HP Pavilion tx1000z Notebook
Fn+F8 hotkey dose not work but the remain FX go fine
Another Alternative is to check your BIOS to see whether or not your Wireless is turned on, if it is not pressent in your BIOS then update your BIOS Driver on the Internet to ver 1.4, Double check your version Compatabillity. Next if the adapter driver is installed, follow the following intructions: start -> settings -> control panel -> system -> hardware -> device manager -> now look for the wireless adapter, see if it is operational or marked with an error -> if it is marked check that it is configured for automatic, and also the resources. Set the configuration manually if so. restart the system.
1) Resource conflict = change resource settings
2) No adapter = check if the adapter is enabled (Y) then see if there is any conflicts (y) correct the settings e.g. resources and see if windows shows that the device is enabled (N) try to enable this device. If (N) then goto BIOS settings to correct it.
Hope this helps
May 24, 2009 | Toshiba Tecra M6-EZ6611 Notebook
Acer Aspire 7730 UNABLE TO GET WIRELESS CONNECTIVITY
you need to try
1) check bios aetup screen thereis setting wireless enable/disable
and check xp control panel--system--device manager wireless driver no yellow triangle mark( which need update driver)
2) check wireless switch at laptop frront or right side, set to "on" to make sure the wireless light not on. if wireless indicate light still black means your wireless card out of works, check wireless card by open small back cover clean pins and reinstall it again
3) finally you might need change a wireless card.
Feb 06, 2009 | Acer Computers & Internet
Wireless not connecting
wireless network model F5D6020 DRIVERS DONLOAD
Nov 22, 2008 | Belkin 802.11b Wireless Notebook Network...
HP DV6315ca wireless not working
if you dont see it in the device manager , then you have an item listed as yellow /unknown device ,that is the wireless and needs the driver installed.
if you see neither then you may have disabled the wireless in the bios.
Mar 31, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
1,027 people viewed this question
David Payne
David Payne
