If someone has blocked you from accessing the domain roblox.com you can try a couple things. Try accessing the secure version of the site: https://www.roblox.com/Landing/Animated
If that doesn't work, try using a proxy service. This will work unless your administrator has blocked access to the proxy service:
A WAN is a wide area network. basically what allows you to connect to the internet. RJ45 is your phone line going to the DSL modem/routers internet port.
If all your lights appear to be working fine and your internet light shows activity i would do a double check to make sure your NIC is connected and not limited. Also make sure all your filters are in place on all the phone lines in the house except the line running to the dsl box.
There should be a Reset button on the router somewhere. hold the reset button in while router is powered on fro about 10 secs, failing that hold the reset button in while powering on and off.
once the router is booted you should be able to find the wireless device from you pc and connect to it, if that doesnt work you need to hard cable to it, there should be instructions how to use the web interface of the router.
most likey http://192.168.1.1 or http://192.168.0.1
Hi, it seems that these sites have been blocked on your network. Try using a proxy software.
Download ultrasurf from ultrasurf.co.
It work for me.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
