Question about Microsoft Windows XP Home Edition
Sound problem I can't hear any sound in my computer and i cant adjust the sound volume in the control panel. I was removing some programs and i dont know eexactly what i have remove because the language of the computer is in korean. Is there any way to change the language of the computer in English? How? or how can i fix up the sound problem of my computer? please send me a detailed way how. I'm in South Korea right now. Please help!
  • Anonymous Aug 09, 2008
    no sound
  • ramarihancy Apr 17, 2009
    i removed some programs and i think i remove the sound device progrom well i don't know, but that what i think i did?
    President:
  • 1,952 Answers
Ur driver must be lost..better format ur drive and reinstall ur audio drive software
Posted on Aug 09, 2008
    Sniper:
  • 110 Answers
sound problem - 8d63985.jpg if audio shows ? mark that sound driver nor install
Green power light not on and cant hear? The plug is in the correct part of the Hardrive but nothing. There were brand new. I think I dont know how to set them up right on my computer PC..settings and all.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 14, 2011 | Kinyo PS-107 Computer Speakers
Well i cant hear nothing thats it. i think i move something while i was trying to make all the speakers on my pc and now i dont know what to do.plzzz. help.
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume adjustment you will need to right click on the volume icon depending on your operating system select adjust volume
if his does not fix the problem"
Jul 20, 2011 | Logitech X-530 5.1 Speakers
I cant hear
First right click my computer then click properties then hardware then device manager and expand the sound video and game controller and see if the driver is marked with yellow question mark or marked with red X then you will have to reload the drivers and if you dont see any audio drivers then switch of the computer press del and enter bios and enable the audio device then click the volume control in theoolbar and check wether mute is clicked if clicked remove them and adjust volume slider to high
May 30, 2011 | Compaq Computers & Internet
My built in mic is not working properly,when I call somebody hear me but I don't hear him!
If the other person can hear you then YOUR microphone is working fine.
The reason may be that his microphone is faulty (solution below)
Otherwise:
  1. Make sure the volume is turned up on your speakers (and if using external speakers they are plugged in / turned on) . To increase volume go to Control Panel, Sounds & Audio Devices and adjust the slider on "Device Volume" . Also click on "Loudspeaker Volume" and adjust the sliders there as necessary.
  2. Can you hear other sounds (like playing music or videos)? If yes then you need to adjust the audio settings for your calling program (skype or whatever). Launch the appropriate program Click on Tools and ' test audio properties' on the program tool-bar. Follow the instructions on the screen.
  3. Try plugging in headphones and see if you can hear better on them.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In the Sounds & Audio Devices Properties window locate the SOUND PLAYBACK box and click the VOLUME button. Make sure that there is not a tick (check-mark) in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Also make sure that the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it.
Feb 09, 2011 | Toshiba (P000257700) Microphone
Audio controler problem cant hear any voice from my pc
the drivers might have been corrupted by something foreign or you might have got a virus run your antivrus program
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 08, 2011 | Intel D845GVSR Motherboard
Cant hear sounds
if you mean that you cant get any sound on your computer
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 07, 2010 | Insignia 2.1 Speaker System (3-Piece)
Cant hear sound
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 29, 2010 | Toshiba Audio Players & Recorders
DOESN'T HEAR ANY SOUND
hope this helps
Nov 19, 2010 | HP Computers & Internet
I dont have audio i cant hear any sound at my pc
Things you can check:
speakers on and connected, volume on
sound control in the OS, start it in control panel to adjust volume
Aug 13, 2010 | Computers & Internet
Connecting my microphone to the computer
Go to your computer start menu. Then to control panel, then system sound /audio devices. Locate the master audio control. There should be a slider for Mic. Adjust this volume until you hear your voice. Depending on your computer built in soundcard the volume/quality will vary. You might consider a external soundcard.
Oct 03, 2008 | Audio Players & Recorders
Microsoft Windows XP Home Edition Logo
76 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
