Question about Panasonic SC-AK24 CD Shelf System
F61 do this problem have a solution?? thank you
    Brigadier General:
  • 6,966 Answers
To my knowledge, an F61 error is a blown fuse. A workaround is to replace the fuse with the same value but specify slow blow.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 09, 2008
    Problem Solver:
  • 15 Answers
F61 is an error code. If you are seeing it, it means the fuse isnt blown. CHK the power supply for correct voltage coming from regulators there, CHK dry joints in power supply and audio output board, CHK sound output IC but mostly the sound output is the problem. The last resort is the system control.
Posted on Aug 10, 2008
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
Error f61 in panasonic sht540
The abnormalities an output or power supply circuit of POWER AMP.
In normal operation, when DCDET2 goes to "L" (Low) (Not during POWER OFF condition), F61 appears on FL Display and PCONT goes to "L" (Low).
This is due to speaker output has DC voltage or fan is not working.
May 28, 2010 | Panasonic Audio Players & Recorders
I WHAT IS FULT OF F61 IN SA-AK177
HELLO
F61 means a protection code which normally means there is a fault with the audio output IC. Check all your cables for shorts etc, and try hooking it back up. If the error is still there you'll have to put it in for service.
ALL THE BEST!
Sep 01, 2009 | Panasonic Audio Players & Recorders
My panasonic turns on but shows the letter f61 what does that mean?
F61 just means 'power fault'
Generally a fault with either audio power amp ic (IC 501) or power supply ic (IC 502).
May also be the fan if it has one make sure it is clean and can spin freely.
Hope this helps. Thanks
Sep 13, 2008 | Panasonic Televison & Video
Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
Jul 15, 2008 | Panasonic Home Theater System System
Panasonic Sa Ht 70 Problem F61
Hi, F61 usually means that the unit has some sort of DC error internally. One of the amplifiers could have failed. The HT70 is an older unit and dry joints around the voltage regulator and power amplifier is also very common. Also check that the fan is in good order.The unit will most likely have to be checked by a professional tech.
Jul 12, 2008 | Panasonic Home Theater System System
Panasonic home cinema model sa-ht75 . shows f61 disconnet output ic ,still shows f61
F61 error codes could either be IC501 or the regulator (IC502) in the power supply section.
For reference, pls view these two (2) posts here and here of similar concern on other models.
Other possibilities are:
1. fan not turning;
2. cold solder;
3. looses connections;
4. one of the other components/systems hooked up to the power supply is causing a fault (tuner, disc player).
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Apr 26, 2008 | Televison & Video
CODE F61
F61 tells you its a power source problem according to the manual. to all F61 error it is very likley that the str470-050a reg legs desolderd and have broken away from the main body of the regulator giving you the f61 and shut down.
Jan 12, 2006 | Technics SCEH790 CD Shelf System
Panasonic SC-AK24 CD Shelf System Logo
327 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
