When my Computr is on, it goes off after ten minutes. Please can you help.
  • 3,051 Answers
Need to check your system standby time in controle panel then click on display and at the bottom you should see power options click on it it has different settings your computer can do for the monitor to turn off the harddrive to turn off ext ect and there is a advanced option for the system hibernation which will also turn off your computer after so long if it is not set right good luck
Posted on Aug 09, 2008
    Genius:
  • 2,985 Answers
M any possible causes.
Over heating is one - Cleam out rthe inside with a vacuum cleaner and a soft brush if very dusty- make sure the machine of disconnected from power. care fully remove all dust and much from processor fins and fan bladed - also any case fans.
Try that fisrt then come back if still in trouble
Runs ten minutes then goes dead
could be (vapour lock) check the tank vent, try popping the fuel cap and see if it starts
Apr 09, 2014 | Stihl Garden
Hi, I have a Toshiba 40XV551D TV and it won't switch on. No picture, no sound and all I can see is blinking red LED. Any clue how to fix this? Please help.
Try unplugging it for ten minutes TEN MINUTES not ten seconds, Then plug it back in and see what happens. If that doesn't work, you're are gpoing to have to have it looked at by a tech.
Oct 29, 2013 | Televison & Video
My mr heater mh9b won't stay lit. The pilot flame starts acting wierd and making noise after ten to fifteen minutes of being lit and then goes out completely. It can be re-lit but goes out again in a...
my mr heater mh9b won't stay lit. The pilot flame starts acting wierd and making noise after ten to fifteen minutes of being lit and then goes out completely. It can be re-lit but goes out again in a bit. Any suggestions?
Nov 17, 2009 | Mr. Heater MH9B Ceramic Utility
2002 Monte Carlo Security system has shut car down completely unable to start car
the process takes about thirty minutes. in three ten minute key cycles. here is how you do it . make sure that the battery is fully charged. step on parking brake pedal and leave it down this will keep the head lights off. turn the key and try to start it then leave it in the on position. you have to leave the key in the on position for ten minutes. you will see the security light on. after the ten minutes the light will go off then turn the key to the start position. turn the key all the way back to the off position and count to three. then try to start it and leave the key in the on position for another ten minutes till the security light goes out. you have to do this same process three times to reset the security system. sometimes you get lucky and it will start after the first ten minute cycle.
Oct 31, 2009 | 2002 Chevrolet Monte Carlo
Why is does my 1997 dodge dakota's headlights flicker on and off.
UNDER THE HOOD ,,DRIVERS SIDE, BLACK BOX,, ARE CIRCUIT BREAKERS,,, 50 amp breaker goes to headlamps,, 50 amp goes to blower motor, switch those breakers around and problem is solved...
Jan 25, 2009 | 1997 Dodge Dakota
XBOX 360
I will play Madden 08 for about ten or fifteen minutes and then the screen will come up and say "Disc is unreadable and it won't play again.
Dec 12, 2008 | Microsoft Xbox 360 Console
When my computer is on for about ten minutes it goes off. Please can you help.
It sounds like your power supply is about to fail. Luckily, this is a cheap and simple part to replace. Hope this helps...
Whym
Aug 09, 2008 | Computers & Internet
RCA HD61LPW42 runs for an hour then pic goes out for a minute and comes back
sounds like another crappy color wheel issue, just like my samsung hln617w.
Aug 04, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Toshiba satellite goes dead
Assuming this is not hibernating and your harddrive is not set to shutdown after a certain idle time, it could be this is an overheating problem. Check that the extraction vents are'nt blocked and that the fan area is well ventillated. If necassary gently hoover around all ventillation slats. Some laptops have the ability for the user to turn off the fan for certain usage, just check in your management settings that it's turned on, unless you know it is on' and it cuts in or stays on.
Jan 10, 2007 | Toshiba Satellite 4300 Notebook
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
