Question about Kyocera Mita FS-1920 Laser Printer
Kyocera printer problem
I have a kyocera fs 1920 printer which is printing a line done the middle of the page..i think it needs a clean
  • 1 more comment
  • Anonymous Nov 06, 2008
    yes i have had the same problem with both a brother and the kyocera FS-3800 is it possible this is what happens at the end of the drums life?
  • Anonymous Mar 25, 2014
    It still prints on A4 but on the printer display it says envelope mode
  • Anonymous Mar 31, 2014
    Kyocera 9500 pages are streaked
    New Friend:
  • 48 Answers
First I would recommend cleaning the printer. When you change the toner there is sheet of paper that comes with the toner cartridge that explains how to properly clean the printer. If you do not have that handy, there is a panel on the left hand side of the printer that you need to open. Once the panel is open you will see the waste toner bottle; leave it in place. Above and to the right of the waste toner bottle will be a green nob. Pull this green nob slowly in and out three or four times. This will clean the charging wire. Next underneath the green nob there should be a piece that looks like a rectangular box when you pull it out. I believe it is green as well. This is the charger grid. With each toner you should have gotten a small slate blue box with a plastic lid that has a piece of felt under the plastic lid. Remove the lid and this should slot in under the long, rectangular charger grid. Move this back and forth three or four times and than remove the slate blue box. Gently push the charger grid all the way back in and close the access panel.
If this does not fix your problem I would recommend getting service from wherever you purchased the printer as you may have damaged the drum.
Let me know if you have any further questions.
Henry
Posted on Aug 15, 2008
Hi, just wanting to know how to clean an imaging unit on a Kyocera FS-1920
open 2 screws at the top cover remove the cover take a soft wipe comes with the unit or any soft clothe and wipe gentle
Jul 21, 2011 | Kyocera Mita FS-1920 Laser Printer
Whenever our Kyocera Fs-720 printer prints it leaves dark splotchy smudges all the way down the page, any suggestions?
Your printer probably is due for a maintenance clean, which can be done by a certified printer technician.
May 28, 2010 | Kyocera FS-720 Laser Printer
A black line is printing 6.5cm from the right side of the page
Clean the main charge, this is a step that is suppose to be done when replacing the toner but most people don't. The instructions to do this is in your users manual. If you dont have the manual go to www.gfbm.net to download one. Also make sure the cleaner is placed all the way back to the right when done or it will effect your prints.
Feb 16, 2010 | Kyocera Mita FS-1020D Laser Printer
My kyocera fs mita 1920 some dose not print or the message of add tonner come out while tonner was their why it do that?
remove the toner ... shake it well and re fix it and check ..... remove the drum unit and clean it ........ for more details please post your comment
Dec 29, 2009 | Kyocera Mita FS-1920 Laser Printer
We print to the printer through a windows driver but have to push go each time to print the page.
not required to press the go button . if the printer is in of line at that time you give print means you have to press the go button... to know the printer status.... if the ready light is on .. printer is online ... ready light off the printer is offline....... use correct printer driver for avoid junk print.....
Oct 15, 2009 | Kyocera Mita FS-1920 Laser Printer
Kyocera fs-1920 (call service 6400:0040085) help!
the printer will require a need new fuser unit or a new power supply.
let me know if you need more help
Oct 24, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Problems with Kyocera Mita FS-1920
Make sure that your paper sizes match in the control panel of the printer in Windows. It will not only cause the duplex not to work but could cause jamming problems as well. When printing in duplex mode, make sure it is turned on.
Jul 23, 2008 | Kyocera Mita FS-1920 Laser Printer
Call Service issue
Hi sunny82 ,
I think You have defective laser unit,but first try to clean it.
Sep 23, 2007 | Kyocera Mita FS-1920 Laser Printer
Kyocera Mita FS-1920 Laser Printer Logo
812 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
