Question about ON-Q Home 8-PORT Internet Firewall Route Router (F7559)
Hi We've just change service providers and I need to change the password of my Netgear wgt624v2 router the site hhtp//192.168.0.1 doesn't seem to be working?? Any ideas Kelly
Trying to hock router to modum not working
Posted on May 08, 2009
No internet no conepta
Posted on Oct 17, 2008
    Novelist:
    Scholar:
  • 125 Answers
To change the password, you might need to plug in your ethernet able to your computer and then your router. Then try 192.168.0.1 to again connect to router.
If you are using wireless the password of the router doesn't need to change. You will though need to set your new modem to be ale to connect to your network.
Posted on Aug 09, 2008
6ya staff
SOURCE:
Not able to browse the sites using Netgear DGN2000 router...
May be good to disable all additional settings. e.g. firewall or Port forwarding. I am assuming that you are able to authenticate (connect with user id + password) as you mentioned youtube works fine. So in that case, there shouldnt be a basic issue but more of a port forwarding or nat. Also check your laptop for any setting changes or personal firewalls.
Try pinging local gateway, then DNS then any international website. Based on that you can focus on the problematic area.
Apr 07, 2014 | NetGear DGN2000-100NAS Router
Hi i've forgotten the password i set for my router about 18 months ago, so i can access wifi on my ipod touch, i've tried to reset and restore to factory settings using the button on the back,...
Since you reset the router, the username and password were set back to its default values as well. For Netgear, the username and password is: Username = admin Password = password
Aug 29, 2011 | NetGear WNR2000 Wireless Router
I am trying to install a netgear cg814wg wireless router manually. I am going to http://192.168.1 but its aking for username and password. I have tried admin for the username and 1234 and password for the...
You can try resetting your netgear router to default settings. the reset is button located on the rear panel of your gateway to reset all settings to their factory defaults.
Here's the router default configurations settings:
User login URL: http://192.168.1.1
User name (case sensitive): admin or superuser
Login Password (case sensitive): password
You can also check and download your router manual & user guides here:
http://documentation.netgear.com/cg814wgv3/enu/202-10297-01/pdfs/FullManual.pdf
Good luck,
Ryan
May 26, 2011 | NetGear CG814M Wireless Cable Modem...
Netgear router WGR614 - dleteing blocked site with just letter
STEP 1: Logging on to router page
1. Open up the Internet Browser says Internet Explorer, Mozilla Firefox, Netscape Navigator, Safari, etc.
2. Put http://www.routerlogin.com in address box.
3. Put the default login info while prompt i.e. ‘Username: admin’, ‘Password: password (unless you changed it)’
Steps 2 : On the left hand site u will see block sites..
-- Just delete the intial Y there
-- apply and save the changes
And ur issue will be resolved
Dec 29, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
I have no installation manual for the wgt624
You can download a manual from the Netgear website.
You'll need the full model and version number of your router. If you're not sure of this, take a look at the base of the router, where there should be a label with this information (for example, WGT624v4, or WGT624v2.)
Then visit this page and click the link to the Support Page for your model number:
http://kbserver.netgear.com/products/WGT624.asp
Links to the downloadable installation guides/manuals are usually on the left-hand side. Good luck.
Nov 30, 2008 | NetGear WGT624 Wireless Router
PROBLEM CONNECTING
check on netgear's website but if i remember correctly your router, wgt624v2, isn't compatible with vista. i had to buy a new updated router, wtg624v3, last year for that reason.
hope this helps...
Sep 23, 2008 | NetGear WGT624 Wireless Router
Wireless router
If you have a computer wired to the router, Try this steps.
1.Open a browser and then go to http://192.168.1.1
2. Username admin and password is password
3. You should be able to access the router's utility page then and get the wireless settings of the router.
Once you get the wireless settings of the router, just connect to the name(SSID) you set up and then connect to it.
Apr 25, 2008 | NetGear WGT624 Wireless Router
Can't get internet access through NetGear DG834G Router
You have to configure your router...
If your ISP provided you with IP Address, enter the assigned IP address, subnet mask, gateway IP address anbd DNS IP address for your broadband router.
If you connect to the Internet using an xDSL Modem and your ISP has provided you with a Password and a Service Name, then your ISP uses PPPoE to establish a connection. You must enter the required information.
Hope this could help..
Mon =)
Nov 15, 2007 | NetGear DG834G Router
Open Questions:
Canon printer tEcH SupPoRt pHoNe nUmBeR{-l855*22l~4867}Washington USA Canon printer tech Support Number +1{85522l4867}}USALogin Repair service center to resolve all Canon printer customer service phone Number products. Canon printer ROUTER is an American multinational company which was founded by Michael Canon printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Canon printer ROUTER support number, and selling of computer-related services and products. Canon printer ROUTER Tech Support Phone Number Recently, Canon printer ROUTER has been named the number Canon printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, Canon printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a Canon printer ROUTER Service Tag or a Canon printer ROUTER Get Canon printer ROUTER Technical Support Phone Number and Customer Services. Canon printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 23, 2019 | Canon Computers & Internet
See all ON-Q Home 8-PORT Internet Firewall Route Router Questions
ON-Q Home 8-PORT Internet Firewall Route Router (F7559) Logo
221 people viewed this question
Top ON-Q Home Computers & Internet Experts
Ekse
Marvin
Marvin
Are you an ON-Q Home Computer and Internet Expert? Answer questions, earn points and help others
