Question about LG BG8000ER Air Conditioner
Heat load calculation
What is the Procedure of Heat Load Calculation
Plz define the Right Formula
Thanks.
Here are a few ways to calculate your BTU's.
Get ready to use that algebra you thought you'd never use.
1 Ton = 12000 BTU's
400cubic feet per minute (CFM) = 1 Ton on standard ac units (300 is an absolute minnimum)
BTU's air heat = difference in temp. ( ∆T ) x 1.08 x CFM
∆T = BTU's / (1.08 x CFM)
i.e. 65F entering your unit and 93F air leaving on a 12000BTU unit.
∆T = 28
CFM = 400
28 x 1.08 x 400 = 12096BTU's
Another way...
Electric heat calculations.
BTU's = KW (killowatts) x 3413
Watts = Volts x Amps (single Phase) Most Homes))
Watts = Volts x Amps x Phase (this is for three phase units.)three wires and a ground))
120 volts 30 amps single phase (common)
120 x 30.0 x 1 = 3600 or 3.6KW 3.6 x 3413 = 12286BTU's
Posted on Nov 14, 2008
How many cc is equival in horsepower
You can't.
There is no formula to convert Cubic Centimeters to Horsepower. It doesn't work that way.
Apples and Oranges.
CC's are a unit of volume and horsepower is a calculation of work load. Only a dyno would be able to tell how much horsepower a given displacement will/would make.
You could have 2 identical CC engines and have totally different HP outputs.
Feb 15, 2015 | Garden
How do I convert 306 cc,s to horsepower
You can't. There is no formula to convert Cubic Centimeters to Horsepower. It doesn't work that way. It is like comparing Apples and Oranges.
CC's are a unit of volume and horsepower is a calculation of work load. You could have 2 identical CC engines and have totally different HP outputs.
Now if your had the engine's torque values like 6.5 FT LB @ 3050 rpm then you can convent that.
Feb 02, 2015 | Miscellaneous
How to calculate volume
Each specific solid (shape) that has some regularity has a formula which can be used to calculate its volume. If it has no regularity the calculation will be more complicated.
For a right rectangular prism with dimensions L, W, H the volume is L*W*H. For a right circular cylinder with radius r and height H, the volume is Pi*r^2*H.
Once you know the formula, it is an easy matter to use the calculator to evaluate the volume.
Oct 27, 2013 | Office Equipment & Supplies
I would like to know how many square feet a Model # BRCQ0421BD Serial # 990905429 Coleman Central Air Conditioning Unit will cover. The unit supply is 208-230V 1 PH 60 Hz 10.8 RLA 97 LRA.
The Old Rule of Thumb is 400 square feet per ton, but you really need to do a heat load calculation to be safe. A lot of windows on the west or south side of the house will really increase your load and you may need a lot larger unit. Insulation also changes your load so you may be able to cool a larger area. You may be able to get the Heat Load Calculation Form either online or from Johnstone supply. They are on the internet.
Aug 07, 2012 | Coleman Heating & Cooling
WHen I run a load calculation for a heat pump-do I use the heating or cooling load for size?
Dont get a heatpump unless you have a lot of time and money to devote to a constant pain in the ***. Keep it simple electric heat or gas heat you will thank me later.
Jul 18, 2011 | Heating & Cooling
Formula to calculate rating of capacitors in airconditioners
It's not fixed formula, but as per basic rule, easy method tocalculate for motor capacitor. (2650 X full load amps) divided by supply voltage(mentionedin capacitor)= MFD. (Plus or minus 10% to 15%) Ex: 1 Tr which gives full load amps of 6 amps (2650 X 6)=15900 divided by 240(VAC)volts=66.25MFD (10% to 15% plus or minus) You can fix 56.32 mfd or 76.18mfd So, you can go in between 56.32 mfd and 76.18 mfd. If you calculate of 440VAC capacitor, it will be 36 mfd. Hope, it will be helpful . Thanks.
Jan 25, 2011 | Amana PTH123B25AJ Heat Pump Air...
Describe the constant 1.08 in out side air sensible load , for heat load calculation we are considering load due to out side air infilteration for that calculation we consider this factor what it is...
Constant 1.08 is a percentage of outside air being brought into a building or space you want to cool.
Most public or commercial building hvac use a outside air damper to allow fresh air to come in,allowing this air in will cause a constant load or heat.say its 92.f outside this 92.air will constantly be coming in and will need to be cooled.
Hope ive helped.
Jan 21, 2010 | LG BG8000ER Air Conditioner
Is the calculator suppossed to have "DEG" in the bottom right hand corner? I am trying to enter the numbers for the compound interest formula and I keep getting "Syntax Error" Is it because of the...
The DEG indicator on the screen is a reminder to the user that the ANGLE unit is in degrees. You can change the angle unit to Radian or Grads. That does not have any incidence on other calculations. It only affects the computation of trigonometric functions : sine, cosine, tangent, arc cosine, arc sine and arctangent. So if you have syntax error in the calculation of the interest formula, I can assure you it has NOTHING to do with the angle unit.
I do not see the formula you are trying to use, so I cannot be sure what you are doing wrong.
  1. Possible wrong usage of the regular minus sign instead of the change sign (-) or (+/-)
  2. Missing right parenthesis
  3. A right parenthesis is inserted at the wrong place.
  4. Incorrect use of the power function
I suggest you write the correct formula on paper and enter it step by step. A step is defined by an operation: multiplication, division, power. Start with the content of parentheses and work toward the outside. The last result is always the one stored in Answer memory (Ans).
Dec 23, 2009 | Texas Instruments TI-30X-IISTK Scientific...
Calculation of CFM discharge from an opening of a duct collar
There's a thumb rule in A/C air distribution. At 1 TR load, the air supply is about 400 CFM and the ideal diffuser size is 16" x 16" with an effective flow area of about 70%. Branch duct size for this outlet should be around 12" x 12".
Jun 20, 2009 | Carrier Heating & Cooling
LG BG8000ER Air Conditioner Logo
2,973 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
