Question about Philips Magnavox 55P9271 55" Rear Projection Television
Magnavox big screen color issues
It started this morning the colors are tripled(red, blue, green) I did the manual convergence and fixed it, until hubby turned it off and voila, its screwy again, I dont know what I did this morning to fix it, I cant figure out what the blue and red convergence things are when they put up more than one "t" to align. Please help!
  • jeremytimbs Dec 05, 2008
    my green an red an blue is off it got messed up from the remote getting played with i need help how to fix the crosses to line up
  • jszoo4 Dec 17, 2008
    I have aligned all of the +'s and it wont move the shadow of the colors. Blue is the worst. Please help me and tell me what else I can do to make the picture better.
    Thanks alot
SOURCE:
  • 586 Answers
SOURCE: My TV set, an 2004
    Actueally convergence controls by the two IC's called STK.And surely these ic's getting malfunctioning.Therefore you have to change it (Both two IC STK) with the same part number.
   This will surely resolve the issue.
   Thanks
Posted on Nov 20, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Warped Picture, Separated colors
You have a convergence problem.  Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors.  Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors,  etc. Everything you need to fix it yourself.
Posted on Nov 28, 2008
SOURCE: Magnavox 51" Model # 51MP392H/17 Color problems
YOU NEED TO REPLACE THE COOLANT IN THE LENSESAND CLEAN THE SMALL PICTURE TUBES AND PUT IN NEW FLUID. BE EXTREMELY CAREFUL NOT TO GET FLUID ON THE CUIRTBOARDS IT WILL FRY THEM.
Posted on Jan 07, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Red CRT board not working. Blue seems to be going also.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 16, 2009
welcomejee
  • 10594 Answers
SOURCE: cannot converge colors on screen
This happens when convergence out ICs become defective.
Replace convergence ICs on D board to get correct picture. This qualified TV tech job.
Thanks.
Posted on Sep 06, 2009
My big screen tv shows only red green and blue. the colors are separated. what is wrong with it
the convergence circuit needs repair. You can get the convergence repair kit from www.tvrepairworld.com which contain the parts and the CD with instructions.
Sep 22, 2010 | Philips Magnavox 9P6034C 60" Rear...
I was given a big screen Magnavox TV model #38346033. I don't know how to clean the screen. Also the screen has red, green and blue that needs to converge and I don't know how. I don't have the remote or...
Hello linda, hi, I dont think the remote or manual can help the color issue problem, the tv needs to be looked at by a qualified technician. If the TV is a tube type, there are magnets on the neck that needs alignment, this alignment is done while the TV is ON. so high voltage risk are likely. keep out and call service.
Jun 15, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Convergence adjustment
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Using your original remote go-to the settings menu then goto the convergence section.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 30, 2010 | RCA P52926 52" Rear Projection Television
Triple colored ghosts
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Sony KP-43T90 43" Rear Projection...
My big screen tv looks 3d and red green blue are off
  • Screen looks 3D
Mar 06, 2010 | Sony KP-51WS500 51" Rear Projection...
Color shadowing on screen
I had similar symptoms about a year ago. Also came on sudden. The red convergence chip had burned out (poor heat sinking on this model Hitachi). Replacing the color convergence chips fixed it. ($50 for parts.) First, however, have you tried the "magic focus" function? That's explained in the manual, which is available online IIRC, but I'd have to look for the link if you need it.
Mar 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Cannot converge colors on screen
Thanks.
Sep 06, 2009 | Sony KP-51WS500 51" Rear Projection...
Every thing on the screen is triple
Your symptoms sounds like a damaged convergence IC’s.
There are two and sometimes three very large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
Most of the time you can just correct the convergence through the television menu. All that needs to be done is line up the blue and red to the green. If the colors do not move then there may be faulty components in the convergence circuit.
You may want to consult a Television Repair Technician, I would estimate the repair at around $350.00 - $400.00, depending on the repair rates in your area.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jul 01, 2009 | RCA P52926 52" Rear Projection Television
My magnavox TV look like in 3d. what can I do to fix it? it shows letters and picture in three colors. red, green and white
You may want to consult a Television Repair Technician, or repair this yourself. If you want to tackle this yourself, let me know, I can give you some direction for the repair
Jun 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Open Questions:
Philips Magnavox 55P9271 55" Rear Projection Television Logo
85 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
