Question about Refrigerators
Our Whirlpool Frost Free (WBM35MW- freezer on top) fridge has been having problems. When door is opened (either fridge or freezer door) the alarm starts beeping immediately. We have pressed the alarm button and nothing appears to help. Any ideas?
  • ra_ra69 Sep 21, 2008
    I have the same problem - every time the fridge or freezer door is opened the alarm starts - any idea why this?
  • 263 Answers
SOURCE: Whirlpool Frost Free 460 door open alarm
http://www.repairclinic.com check how to repace it with the schematic diagrams you'll see how
Posted on Jan 01, 2008
22yooper
  • 828 Answers
SOURCE: When I come home the
Could be warning you that the condenser coil is in need of cleaning. Under front by toe plate or in the back under fiber cover. Vacuum out all dust and make sure the air circulation fan is running when the compressor is in operation.
Posted on May 15, 2008
SOURCE: fridge freezer
there is a fan inside freezer behind back panel. if pipework behind panel is covered with ice, it will prevent air circulation and the fridge is affected first
take back panel off and check for ice build-up and that the fan is working
Posted on Jun 23, 2008
ginko
  • 19396 Answers
SOURCE: WBM35MW: Beeping
Try first unplugging the fridge for ten minutes, this will drain power from circuits and can solve some problem of this kind.
If it did not work you have an electronic problem, probably a wire making contact or a faulty control board.
You can buy replacements here.
Or call the number listed on your user manual if you need to call a repairman.
Posted on Sep 13, 2008
SOURCE: liebherr frost free fridge/freezer
Try these solutions in these order:
1. Switch off the fridge and leave the door open overnight. Switch it back on in the morning.
Explanation: The sensor inside the fridge gets frozen and cannot control the temperature properly.
2. Switch off the fridge. Unplug it. At the back of the fridge (behind the unit, not inside) there is a large grid. Clean it with a hoover thoroughly. Open the fridge. Dry the back of the fridge if wet (inside the fridge). If frosted wait for it to defrost and then dry it. Plug in the fridge. Switch the fridge back on. This one worked for me.
Explanation: The dust in the grid deprives the fridge from cooling down and the unit can't control the temperature in the fridge section.
3. Switch off the fridge. -Unplug it. Empty it. Turn it upside down. Plug it in. Switch it on for 24 hours. Switch it off. Unplug, return to normal and switch on.
Explanation: This has to do with the pressure of the gas inside the compressor. I have not tried it but this advice as given to me by a qualified electrician when I commented the (in)famous F2 problem in Liebherr fridge/freezers.
Hope it helps. Regards. Albert
Posted on Jan 04, 2009
My whirlpool frost free fridge freezer's alarm keeps going off, ice-cream doesn't freeze?
Check condenser is clean, fans working, thermostat set correctly, try to check internal temp with digital thermometer
May 17, 2012 | Refrigerators
I have the top mount refrigerator - 4years old. Ice maker was installed then removed because it broke about 2 years ago. Suddenly I am getting a huge amount of water in the crisper drawer but no other...
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Mar 14, 2009 | Bosch Refrigerators
I have the same problem .i took apart the inside of
Most/many times this is a clogged up or restricted defrost drain system, but once in a while the drain system has been cleaned and everything appears to be good but you still get ice in the defrost drip tray and such and the drain freezes over. Some manufacture designed kits to help and some home made remedies. http://www.applianceaid.com/defrost_drain_freezes.html
click the link given above
Mar 02, 2009 | GE GTS12BBPLCC Top Freezer Refrigerator
Freezer side works fridge side doesnt
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
Dec 30, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
209 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
