Question about Boating
Radar not working
Get message: hd sig miss also sort of clicking noises from the antenna unit
  • 157 Answers
Hello dvdcoote. You have lost your magnatron. Your HiVoltage connection or the magnatron has gone bad. Disconnect the power to the unit. Disassemble housing and remove the rotor or disconnect the power to the rotor motor. Check for a burn on the insulation of high voltage wiring. This could be the clicking noise. In this case use high voltage gloves and repair the connection or replace the magnatron assembly. Please be careful of HIGH voltage. Note; hd sig miss could be decoded stating High Defined Signal Missing.
Posted on Sep 29, 2008
How to fix "BRG SIG MISSING" error on an old FE-1505 MARK-2. ?
Make sure the antenna/scanner is turning in tx mode. The bearing signal is generated inside the scanner drive motor. This problem usually requires replacing the motor.
Jun 26, 2014 | Furuno 1832 Radar 36nm
Brg sig missing
That usually means the antenna is not rotating. Verify that first then check for physical obstructions. More than likely it's a defective motor assembly.
Jun 24, 2013 | Furuno 1832 Radar 36nm
I have a rather old Whistler 3300 radar detector with the antannae unit in front of the radiator and the suction cup unit on the front windshield for rear detection. I've had it forever and love it. ...
Here are the steps from Whistler's FAQ page on their website:
When the display shows an "R1" type error on the display or the unit clicks (flashing either the Green power LED or the Yellow city LED), it means that the link between the inside and outside unit has failed. Generally this is caused by the receiver's (outside unit) cable becoming unplugged from behind the console (inside unit).
NOTE: The receiver cable is the straight one plugged into the "Radar 1" jack. The laser receiver (LRM-5) cable is angled and plugged into the "Laser" jack. This error will also occur if these two cables are reversed.
Follow the below steps to correct R1/Clicking error message:
  • Make sure the correct cable is connected to the correct jack and that it is fully engaged.
    Make sure there is sufficient slack in the cables to prevent them from "walking out" of the jacks.
  • Follow the Factory Reset procedure.
  • If the above suggestions does not cure the problem, email our Customer Service dept for more information.
Follow the below steps to correct R2/Clicking (Not available on Pro-3450) with "R" Yellow LED flashing error message:
  • If the rear antenna was not installed, go to the Factory Reset procedure. If a rear antenna was installed, continue to the next step.
  • If the rear antenna is installed, it must be programmed.
    For models 2270 and 2290
    1. Remove power from unit
    2. Press and hold the Dark button
    3. While holding the dark button, apply power to unit and hold the Dark button for 5 seconds. The "R"LED and either the Green (highway) or Yellow (City) will illuminate.
    For model 3300 and 3400
    1. Unit will display "R2 ON ?"
    2. Press the Dark button for Yes or City for No.
  • To temporarily cancel the "R2"error message on a 3300 or 3400 model, press and hold either the Dark/City/Quiet button.
  • Follow the Factory Reset procedure and see if the "R2" error goes away. If so, go to next step.
May 29, 2011 | 3300 Radar Detector
Furuno MK 1942. The antenna does not spin. There is a message on the screen "HDG SIG MISSING". Though the magnetron is fairly new one. I can´t access the Instalation Setup at MENU > OTHER...
Either you have a bad cable, or the motor has given up. Sometimes it can be the mod. board but the bearing pulse generator is located on the motor itself. Also check to see if theres a switch on the back.
Oct 14, 2010 | Furuno 1942 Mk2 Radar
Furuno 1942Mk2 Problem
it cannot determine a heading, have you also damaged an internal antenna or positioning / gps device inside it? It is unsure which direction it is pointing in but uses triangulation to determine this.
That requires either an electronic compass unit, or gps to achieve correct heading and hence correct orientation of the radar image
Nov 14, 2009 | Furuno 1942 Mk2 Radar
Error SB SIG MISS on FURUNO CRT radar?
Either your reed switch is bad or your antenna is not rotating. You may hear the motor spinning but that does not mean the array is. If the array is not spinning make sure the belt did not come off the motor. Start there.
Jul 05, 2009 | Furuno 1715 LCD Radar System GPS Receiver
Furuno radar antenna not rotating
yes, this is a common failure after hours and hours of use
Apr 06, 2009 | Furuno 2.2kw 18" Radome
Error message on screen "No heading pulse"
Your belt on the inside of the dome has come off. Take a small allen wrench with you when you go to check on it.
Mar 14, 2009 | Furuno 1715 7" Monochrome Lcd 2.2kw Radar...
Raytheon rl70
I've had the same problem. before replacing the antenna, try to reset the antenna by removing power to the Raystar 120. Disconnect power by either turning off all batteries or disconnecting the red wire from the antenna at the point where it enters the junction box for the chartplotter. This action effectively removes all memory from the antenna and resets it to factory settings. There is a lithianium battery in GPS antenna that holds memory data in the antenna. Disconnecting the power to the antenna for a few seconds clears the memory.
This is exactly what I did and when I turned the chartplotter back on, my Raystar 120 immediately began working again.
May 05, 2008 | Raymarine RL70CRC GPS Receiver
Boating Logo
260 people viewed this question
Top Boating Experts
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
