Question about Singer 7462 Mechanical Sewing Machine
I have an old Singer Sewing Machine Model 786, there seems to be a problems with cobbling underneath, causing looping on the underside I presume its the bobbin but have been unable to fix, I do not have the booklet anymore, so cant look up.
  • 139 Answers
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Posted on Apr 08, 2010
SOURCE:
Where do I find the serial number or model number for an old treadle type singer sewing machine
Sometimes it is on a metal plate or on older machines it is sometimes stamped into the metal on the underside of the machine. FWIW, older machines there is usually only one number--the serial number. That serial number is associated with a model number:
Singer Sewing Machine Company Serial Numbers
Aug 06, 2017 | Singer Sewing Machines
Sewing bobbin
Found several answers at this site, mostly addressing the tensioner.
Singer Sewing Machine Bobbin thread is bunching up Yahoo Answers
Jan 14, 2015 | Singer Sewing Machines
How do I thread an old singer 786 top bobbin machine
Difficult to describe. I guess without a manual it's trial and error if you are used to sewing.
Jan 07, 2015 | Singer Sewing Machines
My singer sewing machine model # 774 will not produce a lower stich that is not all jumbled on the underside of the fabric. The upper stich is fine, it's the bobbin stich that comes out all jumbled. ...
Looping thread underneath is a top thread tension issue...
I have written a 5 page illustrated Tutorial on overcoming this problem....HERE
Nov 08, 2011 | Sewing Machines
I teach sewing. A student had a problem with bunched threads on the underside of the fabric. I have tried figuring it out and every so often the thread stops looping. While sewing on the cg550 singer...
Make sure you have the correct bobbin, 66 class. Check the bobbin case. These machines use the apollo bobbin case that tend to get broken and then the thread hangs up.
Apr 27, 2011 | Singer CG550 Mechanical Sewing Machine
My bobbin housing seems to be messed up. I follow all the directions in the manual, but nothing helps. My bobbin stitches are looping on the underside, my machine keeps breaking needles. I'm just trying to...
Ok, if the bottom thread is looping (bottom of fabric) try adjusting your UPPER tension.
Make sure that your thread isn't catching on anything before it reaches your needle, a small snag can cause needles to break.
Jan 12, 2010 | Singer 118 Mechanical Sewing Machine
When making a straight stitch or Zigzag stitch, makes loops underneath the fabric This is for a Singer sewing machine model 5817c
Your top tensioner is too loose.make sure the thread runs through all the relevant eyes and then tighten the top tension little by little as you do a sample few stitches.
Feb 21, 2009 | Singer 5050 Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
251 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
