Question about Microsoft Windows Vista Ultimate Edition
Closing the inactive application
Please tell me how to close automatically the inactive application or command windows. Infact I using foxpro applicaiton, in which RUN command excutive but Command windows doenot close automatically. It show inactive Command window after excuting the command.
  • 983 Answers
Press ctrl+alt+delete and choose the application need to be closed & press end now ...
that s all it will be closed ...
thank you
bye
any doubts you can reply me
i am always here to assist you
rate my solution ...
Posted on Aug 09, 2008
I am using dos based foxpro application in widows xp. when ever i take print from epson Fx 2175. the print job is paused at last line until i close the application. please rectify.clarify,...
Many DOS programs were designed to write directly to the printer's buffer, rather than to a spooler like more modern applications. It sounds like FoxPro is doing exactly that - and isn't designed to release the job until being completely closed.
Mar 06, 2011 | Epson FX 2170 Matrix Printer
How to add a picture in a field in Visual foxpro. I could do it earlier in Foxpro for Windows with the APPEND GENERAL command but now it only saves the filename and not the actual picture. Please help.
The type of the field should be GENERAL.
Try this command: APPEND GENERAL <fld_name> FROM <url_file>
For example: APPEND GENERAL my_gral_fld FROM 'c:\my_file.jpg'
Jan 11, 2011 | Microsoft Visual FoxPro Professional...
I have a samsung wf316law\xaa washer.I started a load of clothes and went out later and it had stopped early in first few cycles.I got the door open by pulling real hard took clothes to finish them.Now the...
hello,
solution bellow.
There is disclosed a method of controlling an automatic door opening/closing apparatus
for a washing machine that includes the steps of determining whether or not there is an error in
an automatic door opening or closing operation carried out in response to a command to open or
close the washing machine's door; determining if the erroneous operation has been
repeated more than a predetermined number of times according to consecutive incoming commands to open or close the door; and when erroneous operation has repeated more than the predetermined number of times, ignoring a subsequent command to open or close the door.
1. A method of controlling an automatic door opening/closing apparatus for a washing machine door, the method comprising the steps of: determining whether or not there is an error in an automatic door opening or closing operation which operation is carried out in response to a command to open or close the washing machine door;
determining if the erroneous operation is repeated more than a predetermined number of times according to consecutive incoming commands to open or close the washing machine door; and
in the event that the erroneous operation is repeated more than the predetermined number of times, ignoring a subsequent command to open or close the washing machine door.
2. A method as set forth in claim 1, further comprising the step of: returning the door to the washing machine to an original position in the event that the error occurs.
3. A method as set forth in claim 1, wherein the step of determining if there is an error in an automatic door opening or closing operation is performed on the basis of whether or not an inversion occurs in an open/closed state of the door within a prescribed period of time after an automatic door opening or closing operation is initiated.
4. A method as set forth in claim 1, further comprising the step of: clearing the number of errors in the case where the door of the washing machine has been opened or closed manually at the time of occurrence of the errors.
5. A method as set forth in claim 1, wherein said predetermined number is 3.
6. A method for controlling the operation of an automatic door mechanism in a washing machine, said method comprising the steps of: sensing a command to automatically open or close a washing machine door;
sensing whether a failure occurs in opening or closing the door in response to the command to automatically open or close the door;
incrementing a counter indicating the failure;
determining whether the counter is equal to a predetermined number; and
failing to engage the automatic door mechanism in response to a subsequent a command to automatically open or close the door if the counter exceeds the predetermined number.
7. The method claimed in claim 6, further comprising the step of: returning the door to an original position if a failure is detected.
8. The method claimed in claim 6, wherein failure is indicated by a lack of a transition between a door open state and a door closed state within a predetermined time period following entry of the command to automatically open or close the door.
9. The method claimed in claim 6, further comprising the step of: clearing the counter if the door is opened or closed manually following a failure indication.
Thanks for using fixya.
Nov 02, 2010 | Samsung Washing Machines
How to install foxpro
You can install this version of Visual FoxPro from a CD-ROM or anetwork to a local hard drive. You must install Visual FoxPro on alocal drive, not a mapped drive. There is no other preparation requiredbefore installing Visual FoxPro. You must have administrator privilegesto install Visual FoxPro. It is recommended that you run withpower-user privileges to use all the provided tools effectively.
Youcan safely install or uninstall using Visual FoxPro Setup. If you areupgrading Visual FoxPro, you must first uninstall the previous versionof of the program. Though both versions of Visual FoxPro can exist onthe same computer, you cannot install the current version of VisualFoxPro in the same directory as the previous version.
If you planto publish XML Web services using Visual FoxPro, you might want to setup Internet Information Services (IIS) on a Windows 2000, Windows XP orWindows Server 2003 computer. Refer to your operating systemdocumentation for instructions on how to set up and configure IIS.
030c41d9079671d09a62d8e2c1db6973.gifNote VisualFoxPro setup no longer installs any Windows operating system ServicePacks or versions of Internet Explorer. It is highly recommended thatyou install the latest versions of these components before installingVisual FoxPro. Additionally, Visual FoxPro 9.0 is supported only onWindows 2000 Service Pack 3 or later. For details about installing thelatest Service Pack, visit the following Microsoft Web page at http://www.microsoft.com/windows2000/.
Full installation includes all Visual FoxPro program files, online help, and samples files.
To install Visual FoxPro
  1. Quit all open applications.
    030c41d9079671d09a62d8e2c1db6973.gifNote Ifyou use a virus protection program on your computer, override it orturn it off before running the Installation wizard. The Installationwizard might not run properly with virus protection turned on. Afterinstallation, be sure to restart your virus protection program.
  2. Insert the Visual FoxPro CD.
    The Visual FoxPro Setup start page appears automatically.
  3. Click Install Visual FoxPro to launch Visual FoxPro Setup.
  4. To determine if you need additional components, click Prerequisites to display any necessary components.
  5. Click Install Now! to install any new components. If Visual FoxPro Prerequisites needs to only update components, click Update Now!
  6. You might need to restart your computer. When finished, click Done.
    Visual FoxPro Setup reappears.
  7. To continue installation, click Visual FoxPro.
  8. After accepting the End User License Agreement and entering the Product Key and your name, click Continue.
    030c41d9079671d09a62d8e2c1db6973.gifNote Visual FoxPro cannot be installed on a mapped drive. You must install Visual FoxPro on a local drive. Do not attempt to use the Map Network Drive functionality in Setup.
  9. On the Options page, select the features you want to install and click Install Now! to continue.
  10. When finished, click Done to return to Visual FoxPro Setup. Click Exit to return to the Visual FoxPro Setup start page.
Ifyou uninstall Visual FoxPro while the previous version of Visual FoxProexists on your computer, certain shared registry keys used by theprevious version of Visual FoxPro are removed. You must reinstall thesecritical shared registry keys.
If you run Visual FoxPro fromthe Start menu, Visual FoxPro Setup automatically reinstalls thesekeys. If you start Visual FoxPro using other means, such as running theapplication executable directly, the setup program does not startautomatically. You should use Add/Remove Programs in the Control Paneland the following steps to reinstall the registry keys manually:
To manually reinstall Visual FoxPro 9.0 registry keys
  1. From the Start menu, click Control Panel.
  2. Click Add/Remove Programs.
  3. Click Change/Remove for Microsoft Visual FoxPro 9.0.
  4. Click Visual FoxPro and Repair/Reinstall.
Good Luck
Jun 26, 2010 | Microsoft Visual FoxPro Professional...
Foxpro 2.5 Application can't direct print in xp cause in my print Dot Matrix with Epson LQ-2180 using USB to Pararel Port...
share the printer then search for your own computer and you should be able to open it and see the shared printer like. \\server\printer
then use net use command...
net use lpt2: \\server\printer /Persistent:yes
then tell foxpro to print out lpt2 and it will act like dos
you can add net use command to autoexec.bat or windows startup if you will do this often
Nov 08, 2009 | Electronics - Others
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Foxpro dos application exe obfuscation
you need the re-fox or fox shell
is works good
an from mexico
Jan 02, 2009 | Microsoft Visual FoxPro Professional...
Registry editor not opening need help
Go to command prompt and type Sfc/scannow.You may need your xp installation disc since this command tries to verify your windows installation by comparing the files to the one on the cd.Also this might be due to a virus,go to this link and use this tool to scan your computer.The tool can let you know if you have a virus or not.
Aug 16, 2008 | Microsoft Windows XP Professional for PC
Microsoft Windows Vista Ultimate Edition Logo
148 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
