Sound goes loud and then soft on my harman kardon receiver connected to B&W speakers.
5 Suggested Answers
im4um2
  • 77 Answers
SOURCE: When I go to power
Depending on your ablilities there might be a quick fix. It sounds like the contacts in your on/off switch are either corroded or worn out due to heat. Ensure the unit is unplugged from any electrical source. By opening up the unit you will have to detach the on/off switch, and by bending the prongs carefully, open the casing up. Clean all internal part using contact cleaner. If the contacts are worn or corroded, you can try replacing or what I did was added some solder to the contacts and put the unit back together reversing my steps.
Good Luck.
Posted on Jun 27, 2008
SOURCE: Harman Kardon DPR 2005 7.1 back speakers out
Upgraded unit at local electronic store for discount. wanted something with more power anyways. Thank You for
Posted on Oct 08, 2008
  • 4 Answers
SOURCE: I have a Harman Kardon AVR 235 Receiver that go's into Protect
To avoid making the avr go into protect mode when you power up your Hafler 4000 that is connected in the avr's pre-out, you must power up the set up in the correct sequence.
1. Turn off your avr
2. Connect Hafler 4000 to the avr's pre-out it it is not yet connected
3. Turn on your Hafler 4000. The avr will not go into protect mode becasue of the transients from the Hafler because it is still not powered on.
4. Turn on you avr. There should be no more transients from the Hafler at this stage unless it is not functioning correctly, so the avr shouldno longer go into protect mode.
Posted on Dec 16, 2008
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
Not getting any sound out of speakers help please :(
You need to set the device on the aux mode. Connect the cable at aux. Sign at the back of the device
good luck
May 07, 2015 | Harmon Kardon Harman Kardon Harman/kardon...
Harmon kardon hk3270 shuts off after only being on about 10 sec
Disconnect speakers and wires. Bad wiring or defective speakers may be loading the amp down and causing the protection circuits inside to disconnect (no sound). If the HK is heating up (beyond what you perceive as normal) with no wires or speakers connected then you have a problem requiring expert repair.
Oct 31, 2012 | Harmon Kardon Harman Kardon HK 3270 65W/CH...
I have a Harman Kardon AVR 130 and JBL 5.1 Speakers. Bought 5 years back. I have not got the best sound quality as I feel I may not have configured the system correctly. I like to hear crisp Treble and...
if you like this is the manual http://www.google.jo/imgres?q=Harman+Kardon+AVR+130&hl=ar&safe=active&biw=1280&bih=699&tbm=isch&tbnid=LhNyGu_apsEUEM:&imgrefurl=http://fastservicemanuals.com/index.php%253Fmain_page%253Dproduct_info%2526products_id%253D1290&docid=E0j9_Qp_R6GiaM&w=298&h=382&ei=VuRHTuqxD8Kl8QOmg8CVBg&zoom=1
Aug 14, 2011 | Harman Kardon AVR 130 Receiver
My Harmon Kardon AVR 500 sound doesn't work, I disconnected speakers, re connected & reset protection. Nos ound not even on test mode
Hi it is seem there is no output from your device. Please check the circuit components and wires for malfunction in your Kardon then. Regards
Feb 09, 2011 | Harman Kardon AVR 500 Receiver
I am getting no sound from sub. The turns on, but so sound. I have connected to two different receivers to verify it isn't the receiver sub output.
Bear with me on this.
Just because two systems don't light this sub up doesn't prove the amps are faultless unless they work with other subs. Can you assert that?
See page 14:
http://www.retrevo.com/support/Harman-Kardon-HKTS-14-Speaker-Systems-manual/id/386ci056/t/2/
How are you driving the sub - Speaker or Line Level?
Jan 30, 2011 | Harman Kardon HKTS 14 System
Harman kardon avr 7200.1 no volume left front speater
could be a few different things. if you have tried another speaker that you know is in working condition then it might be a connection on the amp itself or the terminal could be bad. does it look coroded or is there anything obstructing its connectivity?
Feb 18, 2009 | Harman Kardon AVR 7200 Receiver
Fuzzy (unclear) sound
UNPLUG YOUR SPEAKER AND REPLACE IT WITH A HEADPHONE, IF THE SOUND IS THE SAME THEN UNINSTALL THE DEVICE [SOUND] AND REINSTALL, IF YOUR HEADPHONE SOUNDS RIGHT, THEN THE PROBLEM IS IN YOUR SPEAKER... PLEASE VOTE FOR MY POSTING
Oct 28, 2008 | Harman Kardon SoundSticks Computer...
Oct 05, 2008 | Harman Kardon DPR 2005 Receiver
Speakers Make a Very Loud Noise that Increases
speaker amplifier chip may leaky or damage
you are using improper sound driver
check driver status in your computer device manager or just typing dxdiag on run in start menu, check status of sound driver installation
Jan 15, 2008 | Harman Kardon HK19.5 Computer Speakers
47 people viewed this question
 Grubhead
Grubhead
