Question about Cameras
When i try to turn on my camera it makes a clicking noise and shuts off and yes it has good batteries
  • Anonymous Oct 21, 2008
    I have the same problem, my camera dropped about 1 or 2 feet to a carpetted floor a few days ago. Also, when I try to take a picture it will turn itself off. I've tried many times and it keeps clicking noisily and turning itself off.
Hi
It sounds like the lens or the lens cover is getting caught. Has the camera been dropped or had liquid spilt on it? If it's been near the beech and has got sand in it this could be another problem.
It'll probably have to go back to a repairer but you could try gently helping the lens out of the camera body as you try to turn it on, this may free it.
If the camera in more than a year old don't bother getting it repaired, the cost will be more than buying a new camera.
Cheers
Posted on Aug 09, 2008
2008 explorer starts with jump, shut off will not restart, clicking noise
clean battery posts and cable ends and make sure to tighten securely when done
Aug 31, 2014 | Ford Explorer Cars & Trucks
The camera starts up and shows the blue sanyo screen. Then the screen turns black then shuts off. The lens doesn't even open. I've tried charging the battery and that is not the problem. What's...
Hello ..Yes please make sure your batteries are fully charged..If battery is charged and still shuts down..There is a good chance lens was hit or bumped.When lenses are bumped the camera will try to extend lens upon power up as part of cycle.If camera detect problem with lens not opening..Then it will shut down...
Sep 23, 2011 | Cameras
My camera wont turn on.
If the lens is stuck inside the camera and you hear a motor noise - changing batteries will not help. This has happened because the lens barrel is jammed inside the camera. Unfortunately, you will not be able to repair that issue. If the lens is stuck outside the camera, slightly tilted, and you hear a motor noise; you might be able to save camera. First, only use good batteries (stay away from alkaline batteries - waste of money), go with Energizer Lithium or Duracell Power Pix (you will get your moneys worth and have less problems with the camera). Second, very GENTLY, pull the lens barrel up and in the opposite direction of the tilt (to make the lens barrel straight), you will hear a slight click sound - DO NOT PUSH ON THE LENS BARREL!!!. Put in the new batteries and the lens should retract.
Oct 06, 2009 | Polaroid i733LP Digital Camera
Camera won't turn on. It just makes clicking noise.
After i replace standard alkalines with rechargeable NiMH batteries Sony 2700 Ni-MH or Varta 2700 Ni-MH it's was working!
My camera it's working now!
Jul 18, 2009 | Fuji FinePix A850 Digital Camera
The car refused to start, made clicking sounds @ the solenoid and the starter, still had current, the radio was working etc...So I bought a new solenoid which had an extra screw at the bottom where the old...
First, put the old solenoid back on and see if you get the original clicking noise. If yes, you either wired the new one wrong or got a wrong and/or defective part. Your clicking noise can come from several places. First, make sure the battery is good and charged up. Dirty/corroded battery cable ends (yes, even if the lights and radio work), bad connection at the starter, bad solenoid, bad battery cables. A dead starter may engage but not turn, making a kind of click noise too. Take the starter out and get it checked. Remote possibility that it is the ignition switch in the steering column is adjusted wrong or bad. A jump from the positive battery cable to the small post on the solenoid should engage the starter.
Jul 08, 2009 | 1993 Mercury Topaz
On the lens makes a clicking noise shutter goes in and out turns.
Did you drop it? if you did you have damaged the gear drive motor for it. Are the batteris good?
Jul 06, 2009 | Olympus FE-210 Digital Camera
Makes clicking noise when turned on than says error and shuts off
your lens are jammed there could be dirt trapped inside try to tap the sides lightly and then turn on.
Mar 08, 2009 | Casio Exilim EX-S600 Digital Camera
Sony start up and shut down
Problem seems in Loading Motor of Lens Mechanism. Its quite complicated Lens Mechanism. If you dont know about Camera Lens repair, please contact nearest Sony Service Center for proper repair.
Aug 15, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Cameras Logo
143 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
