Question about Frigidaire GLTF2940ES Front Load Washer
Crosby washing machine has lint issue,,,my cloths gets linted,,,how to fix this,,,this machine is upward loader,,,has no window for lint remove
  • 639 Answers
Hi khan,
Happy to be of assistance for you!
sounds like this time you need to,
call Service and have them come out.
If it's new your our under warranty for 1 year!
If it's 10 years or older then do not waste the money .
The newer ones are more efficient!
Good work done here.
A&E Factory Service
Nation Wide
7days/24 hours
They do Frigidaire warranty work.
Thank You for asking!
Please rate my, solution solved in this fixya site!
Neil
Posted on Aug 24, 2008
My door is locked and wiill not unlock on a crosbey front load washer
Posted on Nov 23, 2008
Why are there two cold/cold cycles on my new Crosby front loader?
Posted on Nov 13, 2008
My clothes come out of washer with lint on them does my roper top loader have a lint screen
Never knew of a washing machine that had lint screens , but all dryers do
Sep 15, 2017 | Roper Washing Machines
The clothes are full of hair and lint when the wash cycle is finished, how do you fix that?
On a top loader, check the filter inside the agitator.
On a front loader, check the filter under the panel at the front.
Get the lint and hair off before you wash.
Use a tumble dryer and an anti-static softener sheet.
Apr 05, 2017 | Washing Machines
DRYER HAS NO HEAT. TUMBLER TURNS OK. LINT FILTER CLEAN.
Make sure the dryer exhaust tube is clear of lint and not kinked. Next thing I would check are the thermal fuse and thermostat. Check this out: http://removeandreplace.com/2013/09/21/fix-clothes-dryer-heating-drying-clothing/
May 05, 2015 | Washing Machines
My washing machine type 580 is not washing clean. Leaving the cloths with lot of lint
clean the lint filter
you forgot to mention if it is a top loader ( inside the top of the agitator ) or if it is a front loader
Apr 14, 2015 | Washing Machines
After every wash the lent stays on the clothes
here are a few suggestions Two things that come to mind...1) Your wash time is too long. Unlike front loaders, top loaders clean quickly. No need to use the longest wash setting unless the item is really dirty.
2) You are overloading the machine. Items should move freely and circulate from top-to-bottom several times during the wash.
3) try using more detergent, One of the things good detergent does is keep lint (and dirt) suspended in the water and off your clothes. 4)http://www.ehow.com/how_2083872_clean-washing-machine-lint-trap.html
check that link for lint traps in washers
Jul 21, 2011 | Washing Machines
Excessive lint on washed clothes
Your washer does not have a lint filter, so it's very important to sort lint givers from the lint takers. Washers today to not have lint filters because we rely on the dryer to remove lint that does not get pump out with the wash water.
Below are tips taken directly out of the user's manual:
  • Did you sort properly? Sort lint givers (towels, chenille) from lint takers (corduroy, synthetics). Also sort by color.
  • Did you overload the washer? The wash load must be balanced and not overloaded. Clothes should move freely. Lint or powdered detergent can be trapped in the load if overloaded. Wash smaller loads.
  • Did you select the correct water level? The water level should be correct for the load size. The load should be under water.
  • Did you use enough detergent? Follow manufacturer's directions. Use enough detergent to hold the lint in the water.
  • Did you line dry your clothing? If so, you can expect some lint on the clothing. The air movement and tumbling of a dryer removes lint from the load.
  • Was paper or tissue left in the pockets?
  • Is your water colder than 60°F (15.6°C)? Wash water colder than 60°F (15.6°C) may not completely dissolve the detergent.
  • Did you use the proper cycle time and agitation speed for the load? Reducing wash time (duration) and agitation speed are ways to reduce lint.
Jan 10, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Black lint on white clothes after wash. have cleaned filter. is a front loader.
Check both the apron, located in front of the drum for lint residue, as well as the drum itself for sharp points (gouges) which may have snagged clothes and collected the lint to the inner side of the drum. Also try running a full cycle with no load to clear any lint which may remain in the outer (non visible) drum.
Mar 05, 2010 | Washing Machines
Lint on dark clothes
no product i know of , try running machine without cloths with hot water and a lot of extra soap the unrestricted water movement and extra soap lubricates and helps to flush machine out, let machine dishcharge into bucket and if poor flow or lots of debris run again and see if this clears up you issue
Jul 07, 2009 | Washing Machines
Duet front loader dryer
Check the lint trap and the vent. If the vent is clogged or crushed in anyway then replace it with a new dryer vent.
There reasons why a dryer will not dry clothes:
Clogged Lint Trap
Crushed or clogged vent
Last but not your issue, not getting and heat to the unit due to glow ignitor bad or no gas supply or bad gas valve.
So check what I told you and this should fix the problem right away
Feb 09, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Top loader washing machine leaves lint on cloths
my whirlpool washing machine leaves a lot of lints, how can i fix it
Jun 04, 2008 | Washing Machines
Frigidaire GLTF2940ES Front Load Washer Logo
670 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
