Goodman GMP075 Problem
I have a GMP075-3 that was installed in approximatly 1993. I recently bought the house with that unit.
My problem is that when using the A/C, the blower will not start periodically. It will work fine for a majority of the day but at times the inside unit will make a humming noise for approximately 20 seconds and the blower will fail to turn on. The humming noise will then stop.
A simple but not permanent solution that I found is to spin the blower turbine with my hand. Then when I turn the unit back on it will fire up fine, however it will eventually stop working again.
Any help? Possibly a Capacitor problem? If so what side capacitor does my unit use?
Thanks
  • 182 Answers
Check the mfds of the capacitor.if its ok you need a blower motor.
Posted on Aug 09, 2008
We have a Goodman AC Unit and the pipe continues to freeze.
either the inside coil is dirty or system is overcharged.
May 14, 2014 | Goodman CLQ36AR49 Air Conditioner
We installed a goodman heat pump in Nov 2004 to replace the goodman heat pump that was installed in the new house we bought in 1991. We looked the years of service we got out of the old unit which is why...
WELL THE TECH SHOULD HAVE A LEAK DECTOR AND CHECK THE COIL AND LINE SET FOR LEAKS THE REFRIGERANT IS LEAKING SOMEWHERE THAT DOES'N HAPPEN IF NO LEAK. A LEAK CAN CAUSE ALOT OF OTHER PROBLEMS
Aug 11, 2011 | Goodman Heating & Cooling
Where is the filter on my Goodman model capf3636c6ba ?
The main places that filters are located are:
Return Air Vent or Vents
Inside Coil Box
Underneath Furnace (Will have a small access door)
Filter Box Attached to Return Air System
A lot of people still look for their filters inside the coil box, but more recently installed units will have them in the return grills inside the house. Follow your return air from the vent inside the house back to the unit and it will be somewhere in between there. Hope this helps!
Aug 05, 2010 | Goodman CKL36AR36 Air Conditioner
Goodman Model # GPG15709041AA Gas pack just
depending on the brand and if he had to recharge and pulled oil oiut of compressor it can cause comp to be load. goodman is also a lower end unit and you pay for what you get. it is a very reliable unit howvere
Aug 17, 2009 | Goodman CKL60AR60 Air Conditioner
New Goodman condenser unit run almost contiously using too much e
I'm not sure of the kilowatts. The 10 min on and 5 off is telling me there is to much heat by the thermostat or you house needs more insulation. The new compressor is designed for more efficient run time. The other thing is the unit to big for your house? It should run 10 -15 min when low humidity is in the house. Otherwise longer if its pretty warm inside.
Jun 11, 2009 | Goodman Heating & Cooling
Goodman PHJK048 Heat Pump Package
ok...where to start.lol ....the thermostat is just a switch.It will tell the unit to run or not run.if you measure the temp with the heatpump running,the air is warmer than 68 but it feels cool to you because your body is 98.6.The unit will run more often and for longer periods when the temperature drops outside for a few reasons.First,your house has more of a load to heat,meaning you have more heat loss because of the difference in temperatures outside and inside.Second,your heat pump pulls heat from the outside air.The colder the air outside,the less btu's for it to pull.If you have anymore questions hillbuck29@aol.com Hope this helps,Dave
Nov 10, 2008 | Goodman PHKJ048-1 Air Conditioner
Goodman a/c unit
Look at this forum and others as well. You will see many issues with Goodman products. Believe the old saying "You get what you pay for!". Carrier, Trane / American Standard, Payne.
May 27, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
167 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
