Question about Frigidaire FRS26R4A Side by Side Refrigerator
Water line install
Is there only 1 in-valve to install the water line for the ice maker?
  • Anonymous Feb 13, 2009
    how do you install a water line that has been cut from the freezer door?
  • Anonymous May 11, 2010
    Hello Guest...where exactly is the line cut at the freezer door? You can usually use an RO connector to fix it, if there is enough room on the line that have been cut. I hope this helps you out. Just trying to help. :)
  • 706 Answers
You should have one inlet fitting on your fridge for your ice maker / water dispenser on your fridge.
Posted on Aug 14, 2008
SOURCE:
Trouble shoot ice maker
Good day,
If the ice maker isn't producing. Follow this guide. It should solve your problem.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Sep 15, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Not making ice. no water in the ice-maker
Good day,
There are a lot of reasons the ice maker can fail to mae ice.
If you take the following steps it will resolve the proble. However, the freezer must be at normal temeratures for the ice maker to function.
If the freezer rises above 14 degrees the ice maker will lock out. That is by design.
Jul 13, 2010 | Whirlpool ED7FHGXK Side by Side...
Ice maker just quit making ice
Good day,
There are many reasons an ice maker will not produce ice. If the freezer compartment is at it's normal temperature, then just follow this guide.
Jun 03, 2010 | Whirlpool GD2SHGX Refrigerator
My ice maker has stopped making ice. We had to shut down the main water valve to the house and after returning the water to the house is when the ice maker stopped working. We have established that water...
Good day,
For all reasons it is best to do a step by step procedure to get the ice maker up and running.
Apr 07, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
NOT MAKING ICE , INSTALLED NEW ICE MAKER,STILL NO ICE , I'm getting water from ft door dispenser, but no water to or in ice maker ANY HELP WOULD BE GREATLY APPRECIATED Thank you Ed
Good day,
The best way is to do a step by step proceedure to get you there. Skip any steps you've covered but I've had more than one new ice maker out of the box that never worked.
Freezer temp must be below 15 degrees for ice maker to cycle.
Mar 04, 2010 | Whirlpool Refrigerators
We left the ice maker on without having water line hooked up. Now water is hooked to ice maker but it doesn't seem to be getting any water.
Good day,
The best way to isolate the problem, is go step by step. The following will get you there.
P.S. Ice makers left on extended periods without water connected can ruin the ice maker. The reason, is there is a calrod heater molded to the bottom of the ice maker to loosen the cubes.
With no water, it will cycle these heaters every 10 minutes or so eventually burning out the heater, which is non-replaceable.
Feb 14, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker does not work. doesn't sound like it calls for water. but the water in the door works.
Good day,
It's a dual water valve, water can work without the ice maker, and visa versa.
Use these steps. Should iron out the problem for you.
Feb 03, 2010 | Kenmore Refrigerators
BCM-95 Icemaker Was working fine until we moved Water does not go in..we have changed the water value and it still does not work.
fi you are using a percing valve you need to change it to a regular 1/2 by 1/4 compression vlve,, go to a half inch cold water line cut a tee in the line install a 1/2 out let pipe fot the ice maker, then install your valve run a 1/4in line to the ice maker, you shoud have no rblems,, it has to have volume with water supply in order to work, a percing valve is just that, it has a needle on the end you clamp it to the pi[e scre in the "t" handle till it perces the pipe, then back it off to open the water suply alot of times this is not enough to supply the water for the ice maker,,
Jun 30, 2009 | U-Line Icemaker
Side by side refrigerator
The ice maker is not producing ice or not enough ice
 Refrigerator connected to a water supply and the supply
shutoff valve turned on?
Connect refrigerator to water
supply and turn water shutoff valve fully open.
 Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
 Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
 New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
 Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
 Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
 Reverse osmosis water filtration system connected to
your cold water supply?
This can decrease water pressure
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
clogged or incorrectly installed.
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
222 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
