Question about Cobra 29 LTD CB Radio
Calbration I have done the calbration then I got a new truck with bulit cowex cable and my antenna light comes on and I don't get the distanes I used to
  • Anonymous Aug 12, 2008
    The antenna light comes on on only a hand full of channels also on more channels when the truck is running. if I turn the truck off the light goes out on some of the channels. However the swr on most channels is good. I have never seen this before???
    Problem Solver:
  • 12 Answers
Recalibrate your SWR's. They can change if you swap from one Vehicle to another.
Posted on Aug 14, 2008
Hhr t/c warning light
I think you have a sensor problem It's easy enough to check even if you don't have access to a computer scan tool which would make it simple.Check the ABS sensor connectors at the wheels where the brakes were removed. If the connection seems good yo can do a continuity check on the sensor itself (that's measuring the Resistance of it) if you come up[ with a abnormally high reading or infinite on one someone got awful rough with it and it will have to replace it.
Now if you have access to a O'Reily parts store they will be happy to put their scan tool on your car and they wont even charge you for it Their good people Good Luck my friend and if I can help you any further e-mail me at jamisilver@yahoo.com
Jun 11, 2012 | Chevrolet HHR Cars & Trucks
PS3 works great just won't connect to internet - have checked internet connections out, they all work, just PS3 won't connect. Is there a fix for that?
Try replacing the wi-fi antenna - only a few dollars. And also you could try replacing the bluetooth board - the antenna connects to that.They are your hardware fixes.
You could use an ethernet cable, if the problem persists, then it's probably a router problem.
Nov 30, 2011 | Sony Playstation 3 (PS3) Console
What is gap setting for spark plugs on vw polo genesis 1043cc with cat converter petrol
the spark plugs must be change at 30 000 k/m if you use gasoline (octan 95) the gaps are already fix distan. 1.5mm . for new spark plugs , it will come up by use and consumptions , check the distan. for the metal on the meddle par must be 2.5 mm for new spark plugs by consumption it will go down to the meddle white cover.
Jul 19, 2011 | Volkswagen Polo Cars & Trucks
I m unable to watch live tv on my cell phone nokia c2-01 3g
I believe you did not follow the right setting that was why you were unable to watch live television on your phone please follow the setting given below and you will be to watch the live tv on your phone.
The Hauppauge Digital Broadway Box can be a small stand on your own gadget that connects to any Television signal and streams live Television wirelessly to your cell system.
Television signals could be connected to the box via: cable Television, satellite set top box, antenna or TV coax cable. Once the Television source is attached connect the box in your Wi-Fi network and then open a browser on your device to begin viewing from http://distan.tv
Regards
Jul 08, 2011 | Lands Phones
If i feel a grinding of my brakes after having my lower control arm and hub bearing replaced why am I steal feeling a grinding when I mash the brakes and it was from a rod connecter broke on the truck and...
I have a 2005 Nissan Pathfinder, the VDC light and the "Slip" light came on the dash, and the slip light was coming on while i was driving at the speed of 20 mph
Jun 24, 2011 | 2005 Nissan Pathfinder
How do I replace the power antenna a step by step proceedure
- remove screws (bolts) of the cover located between right front wheel & vehicle body.. supposed to be 6 or 8
- ON the Antenna itself, you'll see 2 grooves, use flat Screwddriver to unlock it ... Anti-Clock wise all the way until you get the whole Antenna body dropped down
- Just Unplug the cable and replace the new Antenna
- Reverse what you've done to put the new one ON
- Good luck
Nov 15, 2010 | 2003 Toyota Sequoia
My proscan 32LB30QD won't power up. It worked
try this first:
Setup and Connection
The TV won't turn on Check your power cable connection.
• t can't view the Basic channels. Check the connection of the antenna cable
• t want to view cable channels. Register with your local cable company then connect their receiver to your TV.
• t want to view satellite channels. Setup your Satellite parabola antenna then connect your satellite receiver to the TV.
• Digital broadcasting is not functioning Check your antenna cable connection. Check if the digital channel selection is correctly
connected to your antenna cable.
Jun 15, 2010 | Proscan 32LB30QD 32 in. LCD TV
Red RX/TX and red ANT light on my CB
Well,first hand ,some cobra radio,s have red some have green RX/TX lights, but are you modulating? Some green lights turn red. What is your standing Wave on the antenna,s? You need to check it and the output of the radio. To do this you need a watt or field strenth meter. Can get one at Radio Shack. Your standing Wave is ok as long as it is below a 2. That has to be done on the antenna. ..hope this helps...
Mar 11, 2010 | Cobra 29 LTD CB Radio
How do you replace an antenae on a 1965 mustang.
Disconnect the cable at the radio. Then unscrew the hardware holding the antenna to the fender. Then pull the antenna base out of the fender, disconnect the cable from the antenna base turning it back and forth with pliers or you can cut it. Do not let the cable fall back into the fender. Now take the cable from the new antenna and duct tape it to new antenna cable. Now inside the car pull on the old cable until the new cable reaches the radio. Plug cable into radio then hook up the hardware on the fender for the new antenna and you're done. Good luck.
Feb 27, 2010 | 1965 Ford Mustang
Ac starts blowing cold then in a short time quits blowing cold air
Hi! Volvo have some problems with compressor you must put in new distans chims so you get right distans between beltwheel and compressor.
Go to an AC work shop.
They could help you.
We have this problem on our S70.
BR
Tomas
Jul 13, 2009 | 1999 Volvo S70
Cobra 29 LTD CB Radio Logo
125 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
