Question about Kodak Easyshare M753 Digital Camera
Dropped camera lens error 122,1,0,0
I need to get pictures to be able to download. Since i dropped it barely it has the len error 122,1,0,0 Am i out of luck
  • Anonymous Aug 10, 2008
    i dropped my camera on a bench,it barely hit before i caught it now it has a lens error122,1,0,0 and then shuts off.how can i fix this?
  • FABU4 Aug 10, 2008
    I DROPPED MY CAMERA ON A BENCH IT BARLEY HIT BEFORE I CAUGHT IT NOW IT HAS A LENS ERROR 122,1,0,0 HOW CAN I FIX THIS PROBLEM?
    Sergeant:
  • 359 Answers
Yes you are out of luck... be careful and don't drop your camera next time.
Posted on Aug 13, 2008
My camera wont take pictures. It will only turn on to let me view the pictures in the memory card. When I press the power on button, the lens comes out just barely, not all the way.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Sep 26, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Took a picture, then camera was in bag for a moment with lens open. when I tried to take another picture it was blurry, then the lens got stuck , "Lens error", kept making noises, had to take batteries...
What you're experiencing is called a lens error. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 18, 2010 | Nikon COOLPIX L3 Digital Camera
Our camera was dropped this morning--now it reads Lens Error
oh no! you need to get the camera checked. there might be a lens that got dislocated inside the camera. Nikon is pretty fragile. Get it fixed asap or moist will damage the lens and it won't work anymore.
Sep 03, 2009 | Nikon COOLPIX S10 Digital Camera
Canon powershot lens wont budge the covering gets stuck!!
Also, if you're just trying to get the photos off of its CF card (so many memories on it), you do realize that you don't need need to download them only from the camera? There is a better way to download them that doesn't involve the camera at all:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Jul 10, 2009 | Canon IXUS V2 Digital Camera
PowerShot SD630 lens stuck out, says lens error, restart camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens error 122
Hey blondgal12,
From your description you should most likely have your camera looked at by an authorized service technician and get and estimate on a repair done. The manufacturer usually has a list of authorized service technicians in your local area, or you could try looking in the yellow pages. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 05, 2008 | Cameras
KODAK LENS ERROR 122 1 0 0
if your looking where it says lens error 122 then when you turn it on it will say it i have the same problem but worse
May 11, 2008 | Kodak EasyShare M853 Digital Camera
Lens error 122
ok,white screen is LCDproblum or flex conecting pro,error 122 is ur lens barrel stuckup or mechanical gears problum this is repareable u try ur local repairer
Mar 03, 2008 | Kodak EasyShare M853 Digital Camera
Dropped my camera canon sd450
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 17, 2008 | Canon IXUS V2 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
81 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
