Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Hello &
Welcome to FixYa
When the unit
is unable to drain it will not even work in spin cycle, the problem is with
blocked drain/drain pump filter which should be cleaned. If after cleaning the
problem comes back then the drain pump needs replacement. Please get back to me
if you have any other questions.
Kevin
