Question about Sony Playstation 3 (PS3) Console
Help please :)
Hi would you be able to possibly assist me in troubleshooting my ps3 i have some questions and thought since you stated you have done tons of research you may be able to help and give suggestion on what i could do, my e mail is ohiomulchboy4  at (msn) dot com
  • ohiomulchboy Aug 12, 2008
    Well I purchased the unit on ebay it was an as-is and I'm pretty savvy so I figured I may be able to fix it. Unable to really find out what is wrong with it though. I had purchased a brand new power supply for it and that wasn't the problem. It is a 60 gb model when i got it it had a sticker saying it was a "display unit" I'm assuming like the ones to play and use while in the stores. When I power it on it sounds like fans start up and then shut off and it beeps. If able I would like to be able to repair it on my own for two reasons, one just being able to and the satisfaction and two it obviously is not under warranty being purchased on ebay. If you were able to help in any way I would greatly appreciate it or if you would tell me what my options would be if I could not repair it. And if I am unable does sony offer anything ? Thanks in advance.
    -Kyle
  • Wes Sydenstricker
    Wes Sydenstricker May 11, 2010
    Hello! I would be glad to try and help you. Please specify the problems you are having with your PS3.
  • 344 Answers
Hey Kyle,
Well, I'm sorry to say that the display models are garbage. You can input a code to "unlock" the unit so that you can play games and movies, but you have to do it every time you power it on.
Also, I am still doing a ton of circuitry research to find out the cause of the immediate shut down. So far I have found one chip that has a 50 on it that is at the front of the motherboard that has no resistance through it but the chips along each side of the chip have resistance. So I'm thinking that it may be some sort of fuse chip that can blow when exposed to a drasstic shock, as in a drop. I have a unit that does the same thing and I am going to try and bypass that circuit tomorrow and see if it works. I'll let you know.
As for your options...
1. Resell it on eBay As-Is
2. Try and repair it yourself.
3.Contact seller you purchased it from and ask what the return policy is. Return to seller for a refund if it was not stated as a demo model in the auction description. (refer to "item not as described" on ebay) You can even file a dispute within 90 days if it was not as described, even though it was listed as-is!
I hope this helps you. I wish you much luck. If you have any more questions, please contact me!!
Posted on Aug 12, 2008
SOURCE:
Hi can someone recommend to me a free software that i can use to help me troubleshoot my hp notebook and find errors,problems then install the missing programs or drivers eg drivertoolkit please
HP Customer Support Software and Driver Downloads
Go to the HP customer support page above. There is a video to show you how to find drivers but there is also software you can download to search for the proper drivers to your machine one you identify which HP machine you own.
Semper Fi,
Z
Jan 02, 2018 | HP Computers & Internet
Hi I've just got my son a relisys tv model
I thought they only made computer monitors, but you are right they make televisions as well.
relisys tv model Google Search
Apr 01, 2017 | Video Game Consoles & Games
I reset ps3 because i thought it would be fixed then and i could log on ps nework but it didnt. i lost al the saved games and my trophys. is it possible to get it back?
There is no way to get back your saved data after reformatting the PS3's HDD. In the future it is highly suggested that you create a backup of your data before reformatting, this can be done through the settings on your PS3.
Sorry for the bed news...
hopefully I was of some help
May 16, 2011 | Sony Playstation 3 (PS3) Console
Can not log onto the PSN. error message 8002AD3D. I have relocated my PS3 to a different state and I'm using a NET40 wireless signal. The strength of the signal is stating 100% in the network settings....
Hi kdfrance
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
Try turning off media server on ps3 Go into the PS3?s Settings menu and navigate to Network Settings - Media Server Connection disable it thats my first idea which could be causing the issue..Secondly unplug your modem/router for 15 sec then plug back in...THEN FOLLOW STEPS
  1. Select "Network Settings" under "Settings" in the home menu, and then press the "X" button.
  2. Select "Internet Connection Settings", and then press the "X" button. When a message stating that the Internet connection will be terminated is displayed, select "Yes", and then press the "X" button.
  3. Select "Wired Connection" or "Wireless Connection", and then press the "X" button.
  4. Select "Easy" or "Custom" and adjust settings as necessary. Follow the on-screen instructions to adjust the required settings.
Note: You should always choose Easy before going onto to adjusting the Custom settings. In most cases, the Easy settings will work and are set automatically so you won't have to search for information that could have been gathered automatically.
Hope this info was helpful cheers nikki
Jan 20, 2011 | Sony Playstation 3 (PS3) Console
Trying to load netflix instant streaming disk for online movies. ps3 states there is a handshake interfereing or it states can not connect with netflix is this a ps problem or netflix i have turned the ps...
hi its not a problem your end sony are having some problems with their network just give them time to sort it out and then you should have no problems click on the link below for more details
CLICK HERE
this problem affects ps2 ps3 psp and the problem is world wide
this problem will be sorted as soon as possible you could try contacting sony direct to find out how long the downtime is going to be please dont change ant settings on your console as the problem is with them and not your console.
give them time this will be sorted out soon
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
Would like live chat now please. Problem posted twice before.
Hi there Vicky,
Can you re-state the problem so that we can assist you better? We can't see any description of your problem from your user profile. However, if you want to initiate a chat, just go to Fixya's homepage, state your problem and tick the Get Immediate Assistance box and then submit your question.
Dec 21, 2009 | Computers & Internet
When I click HP Solution Center, it says no printers connected.
Go here and use the solve a problem troubleshooter to find the solution.(possibly here?)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 19, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP DeskJet 1220C
Hp has an excellent online support site, which will usually offer the best sequence of troubleshooting solutions for your problem, provided you can locate them. Take a look here and here, for a couple of possible options. Also try clearing the print spooler by following these instructions.
If none of that works, try resetting the printer. This can be done by turning it off, disconnecting the electrical and data cables from the printer, wait a minute or so, then restarting it with only the electrical cable connected, then turn off and reconnect the usb or data cable and restart...frequently this will sort it all out...
May 15, 2009 | HP DeskJet 1220c/ps InkJet Printer
Problem Accessing Network
Well Have You Studied The OSI Model Yet ?
Physical Connection is the first Layer , So I would say the physical connection.
when troubleshooting Network Problems don't complicate things from the start work from the bottom up
So Physical Connection is Step 1
Goodluck
Aug 20, 2008 | Computers & Internet
USA 40GB PS3 - no wireless option on XMB ?
have you checked its manual?
http://manuals.playstation.net/document/en/ps3/current/settings/connectwireless.html
Jun 24, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
