My car wont start...the key turns all the way but the engine doesn't start nor makes any noise...the eletrical is good, radio, lights, windows all work. I can also shift gear from park to any other one. It was working fine, i got back home then when was leaving again 45 minutes later it didnt start. What can it be?? Fuse?? starter? please help me
Have you had the battery itself tested? Features like the lights and power windows do not use a lot of battery power. A starter motor will use at least 9 volts on a 12 volt battery. Batteries usually only last about 5 to 8 years before they start to fail, less if you have 'start-stop' fitted to your vehicle.
I can't look up wiring diagram w/o year--make--model? Usually if it cranks good but won't start, have a helper crank it while you visually check for spark at the plugs, where applicable. If spark everywhere, use a gage and check proper fuel pressure. Also, check fuel injector pulse.
My automotive database is a US database, it won't have vehicles sold only in other countries.
Bad ground. Check the battery terminals. The amount of juice required to turn over engine is not getting through, where as the radio draws much less juice. Also, once all connections are cleaned, positive & ground at the battery and fram and the hot at the starter (best to do prior to snow fall anyway), you should be good to go. If not, turn on the interior dome light and try to start it. If it doesn't start, have your battery tested. Finally, if all is good, you should have the alternator tested as well. Most auto parts stores will provide that for free! Please provide feedback ratings
Best regards
Ck
Sounds to me like the starter or starter relay, OR did you check all the fuses? When the starter doesn't click or turn over the engine it is likely a problem with it or the power supply to it. Start with the easy thing. check the fuses, then the relay.
The P0300 is usually caused by something other than the spark plugs or coils. A fuel/oxygen sensor can cause this code. I would say that doesn't have anything to do with not starting.
Good luck.
I don't know how old your car is but have you checked your starter and solenoid. Another thing to check is make sure that you have good connectivity by having a good ground for your engine. Good Luck
First, remove the battery terminals and clean them. Check that the ground wire on the block is tight and clean and the wire at the starter is also good. If you have 12v at the main starter cable and12v at the smaller (trigger) wire next to it with the key turned to the "start" position, it's likely the starter is bad (providing you can turn the engine by hand with key switch off) Make sure that the battery has 12v before starting diagnosis...radio etc. draw far less than the starter does. Even if relatively new, if the charging system isn't working, it will draw down the battery in less than an hour while driving..
This exact same thing happened to me, it can be a number of problems. You might not have enough battery charge to get the car going since the fuel pump in this car is electronic, my car did not start but when i took it to a mechanic thinking the battery was perfect because lights and all were on they jump started it and it started then immediately died, i also had a choke pull off failure, leaks in my carburetor, and the float was to heavy causing flooding. 185 dollars later and a rebuilt carburetor my car had a smooth idle and turned on immediately after turning ignition. but then to find out my alternator was bad hence the battery only having enough power for the radio and lights.so in short try jumping the car even though the battery seems good, check your carb or get it checked by a mechanic, then check if your alternator is ok. if i waited for two days without attempting to start car then trying it would start if i held the ignition and pushed the gas pedal down until it started. (see if thats the case for you) my guess is you carb, battery, and alternator.
