Question about Intel D101GGC Motherboard
Unable to boot
Boot settings are disabled in bios
and unable to enter into bios
I have intel D101 motherboard and 2.8GHz processor, 512MB Ram but boot settings are disabled in bios
and unable to enter into bios.
Posted on Aug 22, 2008
  • Intel Master
  • 3,051 Answers
What kind of computer is this
Posted on Aug 09, 2008
Enable keyboard
First, make sure it is plugged in. If it is a USB type, try the other USB ports on the computer to see if one or more ports have failed.
Still no luck? Try differen USB ports each time you boot up. During the boot, enter the computer's BIOS or Set Up area (usually pressing DEL, F1 or some other key). Check for setting regarding keyboard and keyboard type. Make sure they are enabled. If nothing works, the keyboard may be broken - not disabled. Try with another keyboard instead.
Apr 09, 2014 | Computers & Internet
Unable to enter Asus 6850 BIOS
I would start by resetting your bios settings to default; turn off your system, remove the side cover and gently pry out the board battery (round "button battery" such as cr2032). Leave it out for about one minute, and reinstall. Then see if you get a post screen.
Dec 29, 2013 | ASUS Computers & Internet
Why my intel motherboard Bios not detect my external ASUS SDRW DVD drive . Any help please ?
Disable Fast boot in bios setting...
To Disable Fast Boot:
  1. During boot, enter the BIOS setup by pressing F2.
  2. Go to the Boot menu.
  3. Disable the Fast Boot setting.
  4. Press F10 to Save and Exit
Oct 16, 2013 | Intel Desktop Board D845GLAD Motherboard
P4c800-e gives error bios not loaded
this motherboard is supposed to have crash free BIOS an overclocking ability and power loss restart
is it happening on boot up the drivers have not been loaded or might not be detecting a bootable device the first things to check are the leads motherboard to your hard drive make sure they are securely seated with no dust built up also the same with computer ram and cmos battery and make sure the sockets are cleanThis message is generated by computers with SCSI / RAID controllers when no bootable drive is detected on the controller. This is not an error message unless you have a bootable drive on the SCSI / RAID or you are wanting to use a SCSI or RAID drive. If you are not using a SCSI or RAID drive and your computer has onboard a SCSI or RAID controller, this message can be disabled by entering the computer CMOS Set up and disabling the onboard SCSI or RAID During the boot process you will see on the screen to press delete to enter setup Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart If your computer is unable to boot or you wish to restore the BIOS back to bootable settings and your computer uses an ACER BIOS, press and hold the F10 key as you turn on the computer. While continuing to hold the F10 key, you should hear two beeps indicating that the settings have been restored. AMI BIOS Older AMI BIOS could be restored back to bootable settings by pressing and holding the Insert key as the computer is booting.
BIOS / CMOS diskettes
Early 486, 386, and 286 computers may have required a floppy disk in order to enter the BIOS setup. These diskettes are known as ICU, BBU, and SCU disks. Because these diskettes are unique to your computer manufacturer, you must obtain the diskettes from them. See the computer manufacturers list for contact information. Early IBM computers Some models of early IBM computers required that the user press and hold both mouse buttons as the computer was booting in order to enter the BIOS setup.
Other suggestions
Finally, if none of the above suggestions help get you into your CMOS setup you can cause a stuck key error, which will usually cause the CMOS setup prompt to appear and remain until you press a key to continue. To do this press and hold any key on the keyboard and do not let go (you may get several beeps as you're doing this). Keep holding the key until the computer stops booting and you're prompted with an option to enter setup or to press another key to continue booting.
hope this helps
Jul 28, 2011 | Intel ASUS P4C800-E Deluxe 875P Socket 478...
How to disable sata in bios in compaq presario cq40
If you mean "how do you boot from DVD rom" then enter BIOS and set boot device to DVD rom on all counts. That will disable the hard drive.
Mar 23, 2011 | Compaq Presario Notebook
How disable boot from ethernet on ms 6368
You can set the boot priority from the bios. Restart your computer and hold down the delete key as it's starting up to enter the bios set up screen. Once you have changed the boot device priority done press 'escape' and then 'save&exit'.
Sep 03, 2010 | Computers & Internet
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
Unable to boot compaq presario v3000
First when you power up press F2 or "del" key to enter in bios then load optimal defaults.
Then go to advanced and set "SATA disabled"
then save all settings then check .
Also check your harddisk is detected or not.
Let me know sir.
Jul 16, 2009 | HP Compaq Presario v3000z Notebook
Tower change
1. Restart your machine
2. Enter BIOS by pressing F2
3. Scroll down to 'System Security'
4. Press Enter
5. Scroll down to Chassis Detection
6. Arrow over to 'Disabled'
7. Press Escape
8. Save changes and exit.
In some bios is in bios in the section BOOT and BOOT SETTING CONFIGURATION and disable CASE CHASSIS WARNING.
Your bios may be slightly different from the above. check inside the settings and find the case chassis warning option.
Regards
Mar 29, 2008 | ASUS NVIDIA nForce Chipset A7N266-VM...
Intel D101GGC Motherboard Logo
167 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
