Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
My transmission/clutch 1999 883 sporster xl when i put it in gear it wont move if i accelerate but i can push it with engine off or running.
    Genius:
  • 2,028 Answers
The tranny on these are bullet proof. So, this is most likely going to be the clutch. I say most likely, because I thought my clutch had gone out here recently on my Softtail, but when I got the clutch assembly off, it turned out to be the front drive belt pulley. They're aluminum, and spun the splines out., so keep this in mind if the clutch is good. Since this is an 883 that makes it easier to inspect the clutch. You'll need to pull the primary cover, check the clutch cable mechanism inside the cover, and check the friction plates on the clutch. You should be able to see if the frictions have any pad left, and the cable mechanism will be easy to tell if there's anything wrong with it. Use new primary fluid, and get a new primary gasket, do not reuse the old, especially the gasket. Although it may look good, even the smallest separation in the gasket will cause a leak. Good luck, and let me know how it turns out.
Posted on Aug 09, 2008
SOURCE:
My2002 R1 won't start no green neutral light when I turn the key the yellow check engine light lights up
Hi, Kevin the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
neutral light wont come on when in neutral and wont start with kick stand.
No neutral light bike won start
Yamaha YZF R1P Service Manual
OEM parts for Yamaha
Yamaha YZF R1P Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 22, 2017 | 2002 Yamaha YZF-R1
I have a 2006 honda shadow aero. engine dies when put in gear. kickstand switch measuers good at plug...clutch switch measures good...clutch disengages properly...what else can it be?
Hi, Dan the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Dies when put it in gear 2003 Honda Spirit VT 750
Bike only starts in neutral and Dies when put in gear
Honda VT750C2 Shadow Spirit Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C 2005 Shadow Aero Owner Manual
Apr 29, 2017 | 2006 Honda Shadow Aero
1995 KLE500 Kawasaki: neutral blue light doesn't show and when clutch is released to engage in gear, engine cuts off
Hi, Ishmael the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
Kawasaki KLE 500 dies when clutch is released
http://www.kawasakimotorcycle.org/forum/kawasaki-cruisers/66113-gears-wont-engage.html
Kawasaki KLE500 Service Manual
OEM Parts for Kawasaki
http://www.kawasaki-techinfo.net/searchOM.php?view_lang=EN&spec=OC&
Apr 11, 2017 | kawasaki KLE 500 Motorcycles
1998 Honda Civic manual trans will not shift into gears. Car starts, push in clutch and it goes to the floor, release clutch and comes back up. Unable to put into gears. Brake fluid and clutch fluid seem...
Eric, how are you confirming whether or not the car goes into gear if you shift gears without the engine running? One way would be to put it in 1st and see if you can push the car. If you can't, it is in gear.
Another option is to roll the car slightly forward or backward (engine off) while trying to put the car in gear. Once it is in gear, then the car shouldn't move any further. However, if it goes into gear, DO NOT start the car without taking it back out of gear.
The clutch is much more likely to be the problem than the transmission.
If the clutch fluid ever ran dry, then the clutch hydraulics will need to be bled of air. Otherwise, the problem could be the clutch master cylinder, slave cylinder or throwout bearing. Since you didn't report the clutch slipping (e.g. engine revving without accelerating when in gear) it is likely not the clutch disks themselves.
Jun 11, 2014 | Cars & Trucks
Neutral safety switch problems 1992
Hi, Anonymous the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
1500 goldwing neutral light wont come on GL1500 Information Questions...
Neutral safety switch GL1500
Honda GL1500 Service Manual
Honda GOLDWING GL1500 Owner Manual
Apr 30, 2014 | 1992 Honda GL 1500 Interstate Gold Wing
My honda valkyrie stalls when shifting from neutral to first gear wile still holding down the clutch
1500 Dies putting it in gear GL1500 Information Questions goldwingdocs com
Honda 1997 GL1500C Valkirie Owner Manual
Apr 06, 2014 | Honda F6 C Valkyrie Motorcycles
2001 YAMAHA ROADSTAR will only start if kickstand is UP not DOWN and clutch handle pulled in for some reason it thinks bike is in gear but it is not. The neutral light is on bike drives good and shifts...
Hi, Layton_dille the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
Re only start neutral dilemma Road Star Forum Yamaha Road Star
neutral light wont come on when in neutral and wont start with kick stand...
Yamaha XV1700PCRC Service Manual
Yamaha XV1700PCR Road Star Warrior Owner Manual
May 07, 2012 | Yamaha Road Star Motorcycles
Yamaha Radian stalling
Re dies when put in gear Road Star Forum Yamaha Road Star
Bike dies when put it in gear plz help
Yamaha YX600 Service Manual
http://www.badrad600.com/Radian%20Manuals%20-%20Complete%20-%20Printable/Radian%20Owner's%20Manual%20Clean%20Complete%20Final.pdf
Mar 25, 2012 | 1987 Yamaha YX 600 Radian
The tranny on my 883xl will shift through the gears but it won't engage. It will go into neutral. I don't have to engage the clutch to get it to shift through but even with the clutch it wont...
Sounds like your final drive belt is broke. Put the transmission in low gear with the engine off and try pushing the bike. If you can push the bike with the transmission in gear and the belt is not broke, it could be the front belt pulley is stripped in splined area where it goes on the countershaft. to check that take the rear master cylinder loose and remove the front pulley cover. Put the transmission in low gear with the engine off and push the bike. If the front pulley turns and the countershaft does not, the pulley is stripped.
Good Luck
Steve
Jun 18, 2011 | 2004 Harley Davidson XL 883 Sportster
Some times when i change down from 3rd into 2nd i hit netraul and from 2nd into 1st i get netraul only happens when engine is hot. xl1200r 2006 model
The transmission "neutral" position is located between 2nd and 1st gear. You say you're also getting a "false neutral" between 3rd and 2nd. Since you say you're finding both, it leads me to suspect that you are not being aggressive enough when shifting the gears. The Sportster has the best shifting transmission of all the Harley motorcycles. Since it does shift so easily, riders sometimes "soft shift" the transmission and wind up missing gearshifts. This is the most likely problem, rider error.
Now, there is the possibility that the clutch is dragging but that usually effects the transmission when upshifting, not so much downshifting. With the engine off and switch on, put the transmission in gear, hold the clutch lever in, press the starter button. If the bike tries to move forward, you need to adjust the clutch.
Ride Safe
Steve
Mar 24, 2011 | 2004 Harley Davidson XL 1200 R Sporster...
Lands Phones Logo
154 people viewed this question
Top Harley Davidson Lands Phones Experts
Tom Diffin
Sheldon Dedek
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
