Question about Kenwood Car Audio & Video
KENWOOD KDC-MP4036AX ONLY SHOWS PROTECT - Kenwood Car Audio & Video
  • 78 Answers
SOURCE: Kenwood car stereo KDC-W3534 : warning message PROTECT
This is a safety feature and it usually suggest that there is a problem with the internal amplifier, it could also be a trapped speaker wire. Remove the radio and check if any of the cables have been damaged and if you power up the radio with the speaker plug disconnected that will tell you if the fault is in the car or the radio
Posted on Dec 23, 2007
netrecov
  • 52 Answers
SOURCE: my kenwood kdc mp332 car
if the power is not turned on (or it is on, but will be off immediately,) the speaker wire may have a short-circuit or touched the chasis of the vehicle and the protection function may have been activated. therefore the speaker wire should be checked. the press the reset button. also it will do that if it gets hotter than 60 degrees celsius or 140 f
Posted on Apr 20, 2008
SOURCE: protect mode
Press reset button (small circular button need something with a point) to the left of the 1 channel
Posted on Feb 28, 2009
etirbynnor
  • 655 Answers
SOURCE: kenwood kdc-w3041 protect mode
Hello ia737,
The "protect" display is probably being caused by a shorted or grounded (touching vehicle chassis or other ground) speaker wire. Check the speaker wires for bare spots, etc and insulate or replace as necessary.
You do not need to remove the fuses to force a "cold reset" of the W-3041. You can simply press the "reset" button on the front of the unit. It's the little recessed button at the lower left of the volume control. Use the straightened end of a paper clip or ballpoint pen to momentarily hold the button in.
Hope this helps.
Posted on Jul 24, 2009
smarthome2
  • 1114 Answers
SOURCE: kenwood kdc-438u stuck in protect mode what do i
Disconnect all speaker wires at the receiver and turn it back on. If it does not go into protection, your receiver is ok. Re connect speakers one at a time and test until your receiver goes into protection, then trace the speaker wire to the speaker for cuts or shorts. If you have a multimeter, switch it to ohms and check the speaker for a dead short, you may have a blown speaker. Hope this helps.
Posted on Sep 27, 2009
My Kenwood KDC-MP142 in protect mode. is there a reset button??
My kenwood is stuck completely in protect mode. I ve everything listed and it wont come out of it. So should i assume the unit has gone bad?
Oct 20, 2011 | Kenwood KDC-MP142 Car CD/ MP3 Player
Kenwood kdc-mp442u protect mode came
First of all , your Kenwood shows only Protect on the display when your speakerwires are conflicting with each other , but when you cannot find the problem there....
disconnect them one by one to see wich speaker in your car is conflicting (shortcuts).
Replace that speaker and your kenwood will work just fine.
I had the same problem here with a brand new Clarion speaker .
Oct 08, 2010 | Kenwood KDC-MP442U
Kenwood KDC-MP732 CD Player in protect mode how do i get it off had a blown speaker fixed it and still in protect mode
Protect Mode (Blink): The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated.
Solution: Wire or insulate the speaker cable properly and press the reset button.
Here is a copy of the Instruction Manual for the Kenwood KDC-X790 and KDC-MP732.
Jul 25, 2010 | Kenwood KDC-MP732 CD Player
I have a Kenwood car stereo model # KDC-MP342U. Protect mode has been activated on it. I found I had a frayed wire on a speaker from window movement and have replaced the wire. When I reset the radio and...
hold down preset 3 & 6 + reset
press preset 1 - shows dc err
press preset 1 - shows dc ok
press preset 2 - shows dc 2-4
press preset 2 - shows dc 2-0
then unit should be ok with eeprom reset
Jul 18, 2010 | Kenwood KDC-MP342U Car CD Player
My kenwood kdc-mp53u flashes PROTECT whats wrong with it?
Protect indicates that there is a short or a grounding problem usually within the speakers2_bing.gif or the speaker wiring. Locate and press the reset button (pinhole). If protect comes back then disconnect all speakers, reset and connect them back one at a time until protect shows up again. This will help you find out where the unwanted DC signal is coming from. If protect shows up when all speakers are disconnected, then it may need service.
Apr 11, 2010 | Kenwood KDC-MP538U Car CD/ MP3 Player
Kenwood kdc-mp208 stuck in ''protect'' mode....
Apr 10, 2010 | Kenwood KDC-MP208 Car CD/ MP3 Player
Protect message on screen
When 'Protect' shows up when you turn on a kenwood deck it means there is a speaker short somewhere that it is detecting. Make sure all connections are insulated and that none are accidentally touching the chassis of the vehicle.
Jul 06, 2009 | Kenwood KDC-MP638U Car CD/ MP3 Player
I have receive from my brother kenwood
You will need to call Kenwood and they will have a master code that they can give you.
Jun 16, 2009 | Car Audio & Video
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Security
"Protect" isn't for security on a Kenwood; it's caused by a problem with the speaker output. There may be a defect in the CD player, or you may have a blown speaker or a shorted speaker wire in the vehicle. Try disconnecting all the speakers and see if the unit still shows "protect" when you turn it on. If it still shows the "protect" message with no speakers connected, the unit needs to be serviced; if not, re-connect the speakers one at a time until you find out which one is causing the problem.
Aug 10, 2007 | Kenwood KDC-MP232 CD Player
Car Audio & Video Logo
186 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
