If your car has an electric fan its not cutting on when its suppose to.Check fuse,relay and power at fan.Try turning on A/C this should cut fan on. This will tell you if you got power to it or not.
Check the electric cooling fan. There will be a sensor on the engine to tell it to turn on. The electric motor itself may be defective, and lastly, there will be a fuse to power the motor. Also, if the engine has been running hot, it may have damaged the thermostat. But from your description, that doesn't seem likely. Hope this helps.
