Question about JVC KD-G310 CD Player
Jvc cd power
My cd player turns on then it cuts off but the red source button is still lite up
    Problem Solver:
  • 8 Answers
Check connections behind dash, especially ground. Make sure no wires are crossed/touching, and make sure all connections are strong. If still a problem check grounding from battery to frame....maybe even consider running the "ground" wire from your CD player to your frame.
Posted on Aug 09, 2008
SOURCE:
Red accessory wire
The red accessory wire goes to ignition or a switched power source. There should be a blue wire that goes to power antenna.
Dec 26, 2012 | JVC KD-R200 Car CD/ MP3 Player
Newly installed in a camper from the leisure battery,power to the unit and will load the cd then the unit goes dead.Press the eject button and the unit illuminates and ejects and again goes dead
Do you have power going to both the red and yellow wires? The red wire generally goes to a switched power source and the yellow should be constant. Both wires need to have power going to them in order for the unit to work properly.
Nov 01, 2011 | JVC KD-S6060 CD Player
Have power--cd insertsand ejects but no sound on switch does nothing-source does nothing disp lites up time for few seconds only can you help
You should go back and check your wiring. It sounds like your memory and constant power wires are crossed. While back there, check ground to make sure it's good as well.
May 27, 2010 | JVC KD-G120 CD Player
How to set the displayed time in JVC KD-G110 car music system?
Turn your JVC source ON. Then press SEL -button continuously, until you see the function change mode. Then select desired function with rew/fwd -buttons, and change mode vith -/+ -buttons.
Apr 01, 2009 | JVC KD-G110 CD Player
I just bought a suburban that has a after market dvd and tv setup in it. It still has the orignal cd play with a dvd player under it the avd 400 ta. I can not get any sound out of it. went thru all the...
hi there
open up your dash get 1 short RCA cable (red and white) male ends on them
now place the red and white RCA into the back of DVD in-dash player next step the aftermarket CD player should have 2 rca plugs that say aux put the other end red and white RCA cable that you just put into DVD unit into the aux inputs on back of CD player when this is done reinstall both units back into the dash now on your CD player press the source button till aux appears once this is done you will hear the DVD player sound...........now if you press the source button and no aux appears......hold down the source button till the CD player powers off...........once CD player is off hold down the F (function) button till beep or unit turns on a display use the skip buttons or F (function) button to go threw features once you get to aux turn aux to on now hold the source button down again till unit powers on normally once this is done press source button again till you find aux........if you get sound and the TV doesn't work let me know and ill guide you to get that running too (if there are no aux RCA plugs on the back of CD player) let me know (sometimes there is a headphone looking plug on back of CD units) if what i told you doesn't work let me know the brand of CD player you have so i can give you correct setups I'm only going by your in-dash DVD player right now
hope i was able to help get you sound
Mar 04, 2009 | Audiovox AVD400TA Mobile DVD Player -...
JVC KD-G340 Power Problem
Try rewiring it. Yellow to a full time hot 12v and red to an ignition switched 12v
Feb 18, 2009 | JVC AM FM CD DET FACE CAR STEREO
Installation
We can help you.Welcome to contact www.playpower.com.cn
Aug 21, 2008 | Car Audio & Video
No power
why didnt you hook it up to your wiring harness and were is the red wire hooked up the yellow is the memory wire make sure you have a good ground
Feb 09, 2008 | JVC Sirius KD-G300 CD Player
JVC car radio/cd player wont switch on
As a sanity check run a temporary wire directly from the battery positive to the radio. Twist the red and yellow wires together and connect it to the wire from the battery. If this works either your red or yellow wire connection under the dash or to the harness is not hot like you think. Yellow usually goes to a constant 12 volt source (to keep radio memory) and the red wire to 12volts when the ignition is on. In some radios this is reversed. The test I mentioned will determin if the problem is in the wiring or the radio.
Jun 18, 2007 | JVC KD-S570 CD Player
JVC KD-LH300 problem
Any after-market CD player needs voltage on the yellow wire and on the red wire before it will turn on. The yellow wire is for a constant power source, and the red is for a key-switched power source. When you hook it up to your battery using only the yellow wire and the ground wire, it's similar to having it in your dash without turning the key on; ie, it will load and eject, but won't power up and play with the key off. Turning the key on sends voltage to the red wire.
Jun 05, 2007 | JVC Sirius KD-LH300 CD Player
JVC KD-G310 CD Player Logo
51 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Dalynn Turner
Marvin
Marvin
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
