Question about RCA D61W20 61" Rear Projection Television
Tv help tv will not turn on power light will go out and clicking sound starts from lower left rear
  • RCA Master
  • 8,617 Answers
Your Chassis is famous for the flyback taking out the Horizontal output transistor which can cause that symptom. HOT is a 2SC5588 and the flyback is part 259296
Posted on Aug 09, 2008
  • RCA Master
  • 6,487 Answers
The problem can be the following and should be handle by a tech you can take it to a repair center near you and have it fix..
1. Bad flyback transformer.
2. Fluid leak from one of the tubes has gotten into a yoke or onto a CRT drive board and is creating a short circuit.
3. One of the CRT's itself is arcing internally.
Good luck...........
    Genius:
  • 1,665 Answers
It s power supply board may be faulty.
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Aug 09, 2008
    In many cases replacing bad a bad electrolytic capacitor at power supply area resolves the problem. But some experience in DIY electronics troublshooting - repairing is neded. Otherwise take it to an authorized service shop to find and replace.
  • 4,472 Answers
How long have you owned the set and how long have you been having this problem? How long does the light turn on for? It sounds like its shutting down because of a malfunction could be the power board. with some more info I can assist you further.
Thanks,
Lee
  • Lee A.
    Lee A. Aug 09, 2008
    Does the power light blink at all?
    Thanks,
    Lee
  • Lee A.
    Lee A. Aug 09, 2008
    If you felt so inclined you can remove the back to look for bad capacitors though I would recommend having it serviced there are a few ways to have it serviced. You can contact RCA directly for the nearest authorized service center by going here:
    http://tv.rca.com/en-us/servicelocator.h...
    If you would like to find someone local to you I can assist you with that as well. If you need any other assistance let me know and if you found this helpful at all I would greatly appreciate it if you could accept and rate the solution accordingly.
    Thanks,
    Lee
WELL IT MAY SEEM LIKE THE END BUT ITS NOT. YOUR TV HAS BAD CAPACITORS ON THE POWER SUPPLY.. THESE CAPACITORS ARE PREVENTING THE RELAY TO STAY OPEN AND GIVE POWER TO THE REST OF YOUR TELEVISION.. THAT CLICKING SOUND YOU HEAR IS THE RELAY OPENING AND SHUTTING DOWN.. THOSE CAPACITORS NEED TO BE REPLACED.. IF YOU OPEN YOUR TV AND FOLLOW THE ELECTRICAL CORD.. IT FIRST CONNECTS TO YOUR POWER SUPPLY... LOOK FOR BAD CAPACITORS THAT ARE BULGY ON TOP.. OR BLOWN.. REPLACE WITH SAME VALUE... THE VOLTAGE COULD BE A LITTLE HIRE.. BUT TRY TO KEEP THE SAME.. BEFORE YOU TOUCH ANY OF THEM.. MAKE SURE YOUR TV HAS BEEN DISCONNECTED FOR 3 DAYS.. THOSE CAPACITORS HOLD ALOT OF POWER EVEN AFTER DISCONECTED... MORE ADVICE AT WWW.BESTDIRECTORYSOLUTIONS.COM FOR FREE.
Mar 16, 2012 | Philips 50PFP5332D 50 in. Plasma...
I have just re-installed my pdp5071 after it being in storage for a few years.. the unit will not power up . at plug-in several clicks at upper left rear of unit ( click - stand by red light on-off, pause...
There are two power buttons on this TV. One on the lower left front and one on the right side. make sure they are both on. During storage it may have deactivated both of them.
Apr 18, 2011 | Pioneer PDP-5071HD 50 in. Plasma HDTV
Tv won't turn on. blinking red light in lower left corner
unplug the television...wait 10 seconds and then plug back in....if you listen carefully after 5-10 seconds you will hear a click sound (the same sound that you hear when you turn on or off) ...once you have heard it, turn the TV on again using the remote. Do not turn on until you hear the click. If this does not work, try again but turn the TV on again before you hear the click. I dont know why it happens but it is as if the TV gets confused as to whether its supposed to be on or off. Most of the time, the solution is to turn it on after the click so I would always try that first.
Feb 14, 2010 | Panasonic TC-32LX700 Television
My RCA projection model P46726BA made a popping
Check the horizontal output transister. It's known to go bad.
Dec 16, 2009 | RCA Televison & Video
TV takes several attempts to turn on. Light will flash a couple of times and then turn off. After 6 or 7 times, the set will turn on and work fine until shut off again.
THIS SOUNDS CRAZY BUT I JUST DID IT ON MINE AND IT WORKS!!!! REMOVE THE LOWER REAR CASE ( ITS THE LARGE BLACK PLASTIC COVER WITH THE VENTS ON SIDE ABOUT 15 SCREWS IT WRAPS AROUND THE LOWER BACK OF TV) USE A HAIRDRYER AND HEAT UP THE LOWER LEFT CORNER OF THE GUTS(AS LOOKING FROM REAR) FOR 5 MINS OR SO THEN TURN IT ON. MAKE SURE YOU UNPLUG UNTILL READY TO TURN ON
Nov 29, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
I have a rca tv model d52w17 chassis # D416c30WC.
sounds like the flyback if your talking about the lower left when looking at the rear of the set.
Apr 12, 2009 | RCA HD52W59 HDTV Projection Television
Sharp LC-32DA5U
sounds like youve had a pic tube go out,,probly just one and the other 2 are still good,,thats why it came bck on,,take it to a tv shop ,know ,,want be that much if its just one pic tube,,good luck
Oct 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
No picture or sound
Remove the rear panel. With the TV on you should see a red LED near the center of the PCB. There should also be 5 green leds, 3 to the left a 2 behind. If there is no red leds, check the fuses. If there are no green leds or maybe 1 or 2, disconect PSD5. It's a connector on the left side of the power board that connects to the audio board. It's the 3rd on fro the back. It's labled. With that disconected, turn on the set and look for the green leds. If all 5 light, the power supply is OK and you have a problem beyond that. If they don't all light you have a bad power supply.
Jul 21, 2008 | Hitachi 50EX20B 50" Rear Projection...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
RCA D61W20 61" Rear Projection Television Logo
20 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
