Question about Acer Aspire 5500 5570-2609 Laptop
Boot manager My computer is telling me I don't have a boot manager.I need to know how to access my files so i can log in. tried to go to default factory settings and got no where
    Scholar:
  • 39 Answers
If this is a boot manager is missing on boot it could deal with either a bad Hard drive or system files/registry corruption on boot. An easy way to get your files is use a BDE program that can view your files off your computer without physically loggin into windows. Second way to do it is take your hard drive out and put it into an external enclosure and access your data that way. If you can get into DOS or command try to type in FIXMBR that fixes the master boot record and could sometimes fix the boot issues. After you get your Data I would recommend Running a program called DFT, its free and you can google it and burn it to a cd and boot off of it. This program will test your hard drive and if it passes a full advanced test then you have no hardware problems and should continue to perform an Operating system Install or Full system recovery with factory supplied disks. Hope this helps your question.
Posted on Aug 11, 2008
How can I restore a Dell laptop to the factory default settings?
Here are the main steps to restore your Dell laptop to its factory settings. Depending on the model you own, the procedure may vary slightly.
Before beginning, please note that by restoring your computer to its default factory configuration, all data on the C drive will be deleted. We highly recommend backing up any personal files before moving forward with the reset.
Hard Reset Dell Laptop Restart your computer by clicking Start > arrow next to the Lock button > Restart.
As the computer restarts, press the F8 key until the Advanced Boot Options menu appears on the screen.
Note: You must press F8 before the Windows logo appears on the screen. If you press F8 after the Windows logo appears, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
Press the Down arrow to select the Repair Your Computer option on the Advanced Boot Options menu, and then press Enter. Select your language settings and then click Next.
Log in as an administrative user, and click OK. Then click the Dell Factory Image Restore option.
In the Dell Factory Image Restore window, click on Next. Check the box that reads Yes, reformat the hard drive and restore system software to factory conditions, followed by Next.
The computer will now restore to its default factory settings. Once the restore operation is completed, click on Finish to restart your computer.
Feb 27, 2017 | Dell Computers & Internet
After replacing my hard drive my laptop hp compaq 6720 is asking for a power on password Ive never put one in
Using Computer Setup to Reset CMOS
To reset CMOS through Computer Setup, you must first access the
Computer Setup Utilities menu.
When the Computer Setup message appears in the lower-right corner
of the screen, press the F10 key. Press Enter to bypass the title
screen, if necessary.
-- If you do not press the F10 key while the message is displayed, you
must turn the computer off, then on again, to access the utility.
A choice of five headings appears in the Computer Setup Utilities
menu: File, Storage, Security, Power, and Advanced.
To reset CMOS to the factory default settings first set time and date,
then use the arrow keys or the Tab key to select File > Set Defaults
and Exit. This resets the soft settings that include boot sequence
order and other factory settings. It will not, however, force hardware
rediscovery.
See the Desktop Management Guide on the Documentation CD for
further instructions on reestablishing passwords. For instructions on
Computer Setup, see the Computer Setup (F10) Utility Guide on the
Documentation CD.
For more details and pictures see the help pdf:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00189283/c00189283.pdf
--under 2 B for the procedure to clear the BIOS password.
Mar 06, 2011 | HP Computers & Internet
I need to change the network name and password
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings. From the center screen, select your encryption type from under the Security Options heading If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router: Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings. if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
Hope this helps don
Feb 21, 2011 | NetGear Computers & Internet
Restore aspire 5610
Hi Fentylfc,
  • Click "Start" menu.
  • Click "Programs."
  • Click "Acer Recovery Management."
  • Click the "Restore" button on the bottom of the dialog box that opens.
  • Click "Restore System to Factory Default."
  • Click "Yes" in the warning dialog box which asks if you wish to continue the recovery process.
  • Click "Start" to restore the computer to the default factory settings
  • If you are unable to access the Start menu, use the recovery CDs that came with the computer and always make a back-up CD before restoring a computer to factory defaults. Good Luck...
    Feb 15, 2011 | Acer Aspire 5610 Notebook
    I have the "D" file with the information needed to
    Here is the primary way to restore your notebook to factory setting:
    1 Turn on the computer.
    2 As the computer starts, press on the keyboard until the Advanced Boot Options menu appears on the screen.
    new_note.jpg Note: You must press before the Windows logo appears on the screen. If you press after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
    3 Press the on the keyboard to select Repair Your Computer on the Advanced Boot Options menu, and then press .
    4 Specify the language settings that you want, and then click Next.
    5 Log in as a user who has administrative credentials, and then click OK.
    6 Click Dell Factory Image Restore.
    7 In the Dell Factory Image Restore window, click Next.
    8 Click to select the Yes, reformat hard drive and restore system software to factory condition check box.
    9 Click Next.
    The computer is restored to the default factory configuration.
    10 When the restore operation is completed, click Finish to restart the computer.
    The software is now installed as it was when the computer was first received.
    If you have tried this and you still can get your system to restore, your may restore partition may be corrupt, you may also have a virus that is preventing you access to the restore files. Run an AV agent and retry your retore. If you still have the system disc that came with your notebook, you should be able to use them to restore the unit back to factory setting. Good Luck C2Solutions
    Jan 24, 2011 | Dell Vostro A860 Notebook
    My friend gave me an HP G60 and told me that you can log in but it just shows a black screen. After I log in, the whole screen is black, not off, just black with the cursor in the middle. It happens even...
    Your friend probably tried to replace 3 .dll files so that you can use custom themes for whatever OS is installed on the computer. The only way to fix this is to recover the computer and restore to factory settings.
    When you boot the computer hit escape to access the boot menu. See if there is a recovery manager option, and in there, a restore to factory settings option. (Also, hitting F11 works). If you have no option like this (this is essentially booting without a disk) you'll need a copy of your system restore disks that came with the computer.
    Jan 17, 2011 | HP G60-120US Laptop
    Enter admin mode
    I have 10 unit that belonged to Chase back, and it tries to auto connects to there DNS. I tring to reset the unit to factory default with out any success. I have tried just about everything. The remote connect flash don't work because it boot into auto connect with CHASE logo, then fails finding DNS screen. I was able to access the bios, and get into the control panel. I still looking for a way to reset to factory default without success. G, Control+G, Fi report has been used to gain access, but can't change the boot process from logging as CHASE with the auto connect. If you have a solution......
    Nov 13, 2010 | WYSE Winterm S30 Network Terminal
    Acer Aspire 5920 problem
    Your best play is to restore the machine to the factory settings. To do this, power up the machine and immediately press ALT+F10. From there you will enter Acer eRecovery Management which will give you the option of returning the machine to the factory settings.
    WARNING:
    This will erase everything you had stored on the machine!! ie data files, pictures etc...
    Apr 12, 2009 | Computers & Internet
    Forgot password to acess< and or its still default setting. could you tell me what the wireless 700 routers default password is
    Restore Factory Default Settings When you restore factory default settings to the base station, you clear your Internet connection settings and any special base station configurations that you have established. After the restore is complete, you will need to reconfigure your base station settings or restore these settings from a backup file. You should restore the original factory default settings only under the following circumstances: O You are experiencing serious problems with your base station, and resetting the base station does not fix the problem. O You cannot remember your base station password. In this situation, you must restore the factory default settings by using the Restore button on the base station, and then use the default password admin to log on to the Base Station Management Tool. To restore factory default settings 1. Open the Base Station Management Tool, and then click Management. 2. On the Management menu, click Back Up and Restore Settings. 3. Under Restore factory default settings, click Restore Factory Default Settings. While the original factory default settings are being restored to the base station, the Power light on the base station turns orange. When the light is solid green, the settings have been restored. If you want to open the Base Station Management Tool after the settings have been restored, type admin as the password on the Logon page. Do not attempt to log on to the base station until the settings are restored and the Power light on the base station is solid green. After you restore the factory default settings to the base station, you should navigate to each page of the Base Station Management Tool and reestablish the network settings you want, or restore the base station settings by using a backup file. For information about creating a backup file of your settings, see the following section. Be sure to establish your unique base station password as soon as possible after restoring the factory default settings to prevent unauthorized users from logging on. For more information, see “Change the Base Station Password.” please rate this answer, thanks
    Jan 30, 2009 | Microsoft MN-700 Wireless Router
    Restore back to factory settings
    If the computer will boot into windows you can choose this option from the Acer E-Recovery management software.  If it will not then use alt+f10 during the boot.
    Dec 11, 2008 | Acer Aspire 5610-4648 Notebook
    Acer Aspire 5500 5570-2609 Laptop Logo
    54 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
