Question about Kenmore 64902 Electric Dryer
Thermal fuse keeps blowing
I have replaced the thermal fuse 4 times. Sometimes it lasts several months, but most recently I replace it and it blew the first time I turned the dryer back on. How can I check the heat element? I have a multimeter and would like to know what I can do
  • 481 Answers
You see the other switches next to the thermal fuse? you need to change these too if you have a problem with the themal fuse blowing out repeatedly.
Posted on Aug 09, 2008
SOURCE:
No power. Will not turn on
It may have tripped the internal breaker, and or the house circuit breaker. Go tot the house fuse box and check that first.
Mar 05, 2014 | Whirlpool Gold GU2275XTVy Dishwasher
Replaced 20A fuse - now have blinking lights
either the cutoff is open circuit or closed circuit if you get any reading at all it is good. I would look at the control panel look for overheating components. Tap any relays to release them if they arced inside. Whenever a microwave blows a fuse it is time to replace the huge capacitor at the back and possibly the magnetron. I resurrected my Sharp R9H66 Microwave Convection Oven easily. Had to replace the magnetron twice in the last 5 years
Nov 08, 2013 | Sharp R-9H84B Microwave Oven
The thermal fuse keeps blowing
If you pull it out of closet and replace fuse and it works even after turning off again etc for several times--something is happening when it gets put back---did you disconnect venting connection when you pulled it out?
Dec 17, 2012 | Estate EED4400WQ Dryer
Gaggenau EB 194 Double Oven fuse blowing
from your description, it seems the little fuse is overheating sometimes, a short is a short and an immidiate fuse blower. i would use a higher amperage fuse, 30 amps. any electronic tech can replace this, doesnt have to be your Gaggenau guy, as it seems to me hes made a regular income of this
Apr 17, 2009 | Gaggenau EB294/295 Electric Double Oven
Kenmore dryer won't start
your blowing that many thermal fuses, id replace all the thermostats. (2) come in one kit both on heater box 1 top and one bottom. id also look into your venting, a clogged fo kinked vent is going to overheat the unit and blow all sorts of stuff(not to mantion the potential fire hazard of a bad vent
Mar 19, 2008 | Dryers
Sony 62' blinking lamp light
you might want to have the thermal fuse checked... seems to be an issue... sony knows about it but doesn't want to share this info with many.
amazing how you can spend big bucks on a tv and the life of the tv isn't all that long.
kim
Jan 16, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Pioneer m-770 will not turn on
you probably have a short in the circuit some where. you need to replace the transistor and look at all the solder joints to make sure there not damaged or cracked. i have the same amplifier and i replaced the fuse several times and it blew every time up until the last time when the 4 of the power output transistors blew. what ever you do do not try and power it on till you do all the things i told you or you will have sparks and fire. my mistake cost me my amplifier. but might help you get yours repaired
Dec 24, 2007 | Audio Players & Recorders
Panasonic screen problems
Then recently, these additional problems: 1. The picture cannot be restored by turning off then on. 2. Sometimes, several channels will have the same picture. 3. Sometimes several channels will have the same ghost-like picture. the above all problems are due to one that is weak signal. 1 check for antena or cable or satellite input is ok or wire might be defective due to old. 2 input socket is loose some where. 3 loose contact near tuner or some print break. 4 at last & final its tuner might be defective. hope this will help.
Oct 03, 2007 | Panasonic CT-36D32 36" TV
Kenmore 64902 Electric Dryer Logo
389 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
