Question about Whirlpool GS6NBEXR Side by Side Refrigerator
GE ice maker model #THH30PRTBAA
At first I have hollow cubes. Next came that the water over flows into the ice cube bin. What do I need to correct this problem?
Gayle
Could have a sticking water solonoid valve.if not,it gets more complex.(Dip settings on the board.)
Posted on Aug 18, 2008
Frigidaire side by side with ice maker .. ice maker jams and quits making ice
Hollow ice cubes are a result of lack of water to ice maker. This can be caused by lack of water pressure (clogged filter, bad water valve, obstructed fill tube, etc..) you will need to find the cause to correct this hollow ice cube issue. The ice maker should take on 5.5 oz of water when it cycles (2/3 cup). Mot of the time its a water supply issue and the line could be kinked behind the unit as it was rolled back into place.
Good Luck
Dec 30, 2013 | Frigidaire FRS23H7CS Side by Side...
Ice cubes are hollow shells
Check around the hot gas valve for leaks/oil.
Aug 03, 2010 | Scotsman DCE33PA1BC 15in Built-in...
Icemaker dispenses crushed ice when you select cubed ice
GE has a problem with the flap on the door which lets the ice out , not closing due to a rusted solenoid behind the panel . If this flap does not close , frost will get inside the ice bin , not letting the bin flap open to let cubed use come thru, only crushed . You can defrost the ice bin front and replace the door flap solenoid easily . If this is the problem , repost about replaceing the flap solenoid for further instructions if needed .
Jul 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Slow ice cycle
Are you having any temperature related symptoms, i.e., soft ice cream that appears to have melted slightly and refrozen, soft breads in the freezer, warm or hot outer surfaces anywhere? If cooling is not a problem whatsoever, are any of your ice cubes smaller than normal, or do you have hollow ice cubes; you would be able to crush the cubes in your hand? If either of these pertains to you, you have not enough water coming to the ice maker, due to a faulty water valve not opening completely, or your water source pressure is low. disconnect your water line from the fridge, test pressure of the water line by placing end in a bucket, turning water on. It will be obvious how the pressure is. if pressure is good to really good, you have a bad water valve on the fridge. If pressure is so-so to bad, change source water valve.
If cubes are not small nor hollow, but rather normal full size cubes, just not enough, you probably have an intermittent problem with your icemaker, replace that.
Mar 31, 2010 | Avanti Freezer Compact Ice Maker - 12 lbs....
My GE Profile refrig ice maker makes hollow ice cubes. Why would this happen?
Not enough water is being pumped into the icemaker. The water pressure in the water line coming into the refrigerator may be too low, perhaps due to a blockage somewhere.
Move the refrigerator enough to get behind it. Turn off the water at the small valve which connects the water line from the house plumbing to the tube going into the refrigerator. Get a bucket. Remove the refrigerator water line from the on-off valve (there should be a compresson nut holding it on). Point the incoming water line into the bucket and open the valve. Do you have a good flow of water? If so, either there is a blockage in the tubing within the refrigerator or the water valve at the bottom of the back of the refrigerator is malfunctioning.
Oct 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
Can't make ice cubes only crushed ice
This happened to me. If you pull the ice bin out you will see a metal bar that extends from the front to back on the bottom of the bin. Find the square hole in the back of the freezer. Stick you finger in and slide the white plastic square up or down.
The switch you are moving is the toggle from crush to cube.
Jun 02, 2009 | Frigidaire FRS3R5EMB Side by Side...
GE model GSH25JFTACC ice maker not working
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Mar 24, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
550 Ice Maker Making Hollow cubes or Small Cubes
Hollow cubes are usually a result of lack of water supply
Jul 12, 2008 | Sub-Zero Bottom Freezer Refrigerator
Fridgeidare freezer
how old is it ??? it only makes 8 ice cubes every 2.5 hrs or so when running correctly.some times 5 cubes depending on model. try reaching into the ice maker and feel the ice being made is the tray full or is there empty slots in the ice mold(asif not enough water). are the cubes hollow??( a sign of low water pressure)). have you replaed the waterfilterrecently (if applicable) old filterwill restrict water flow.
Mar 16, 2008 | Refrigerators
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
55 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
