Question about Acer Aspire 5100 Notebook
Cannot connect to wifi
For some reason my labtop will not connect to our house's wi-fi. To make sure it wasnt either the internet or computer, I checked to see if it could get a wired connection. It can. It is picking up our signal and that of my neighbors across the street, however ever time I click on "Connect" it says something of "renewing IP address". Then an error box with IP address could not be renewed. I feel like there is no end. Any help would be appreciated!
  • Wesley Gardner
    Wesley Gardner May 11, 2010
    1. what operating system are you running?
    2. laptop model?
    3. any other devices running off wifi currently?
    4. router name and model?
    5. have you configured your wireless setup on the router?
    Problem Solver:
  • 10 Answers
Do one thing go to www.acer.com and download the empowering technology it is free and then your com will be connected to the net easily and remember one thing remain as close as posible to the wireless connection after that
Posted on Aug 09, 2008
SOURCE:
1 laptop. 2 houses. 2 wifi accts w/different owners & different gmail accts. How do I set up both houses on the 1 laptop so it will automatically recognize which house I am in.I
All you need to do is successfully join each wi-fi network. Once you have joined a wi-fi network and connected to it the computer will remember the wi-fi profile and automatically connect to it the next time you are within range of it.
Aug 01, 2018 | The Computers & Internet
What is the network key
You mean you need to connect your cell phone with Wi-Fi...?
If so you should have internet at home and set it up then make sure turn on the Wi-Fi icon on your phone.
Good luck
Mai
May 16, 2017 | The Computers & Internet
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
My M800 won't cannot detect any wifi or network and i can't get online
try to connect via lan cable.if u get online then look for wifi switch !
Apr 09, 2015 | Computers & Internet
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP DeskJet 1220c InkJet Printer
I can't access internet through wifi
Hi spatra279,
what is the model of your laptop?
1. Before you conect to the Wi-Fi, make sure that your computer has installed drivers for Wi-Fi.
2. Make sure that Wireless is already open or st-up.
3. Look for the Wi-Fi spot area or zone, if there's no Wi-Fi access on that area you may not connect to Wi-Fi.
Hope this helps.
Thank you for using Fixya.
Sep 07, 2011 | Computers & Internet
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Jun 03, 2011 | Lands Phones
My Acer laptop wireless not working. It was
first network setup wizard then u try the internet through wireless
Nov 16, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5100 Notebook Logo
107 people viewed this question
Ekse
Alun Cox
