Question about AEG Washing Machines
Fuse blowing following new motor being fitted
Our 10 yr old AEG washing machine needed to have the motor replaced. Since the new motor was installed I have tried to use the washer, it's fuse in the splitter box blows (not sure of it's correct name). Both the washer and drier are plugged into this box, each unit having it's own 15amp fuse in the box, before being connected to our 220V connection. The drier has not been affected. This happens about 10 minutes approx into the cycle. When the fuse was replaced the first time, the machine succesfully span, drained etc, but something is happening at the front end of the cycle to cause this fuse to blow. It's now happened twice. The repair man just wants to put a bigger fuse in the "splitter box", but I'm concerned that there is more to be addressed in the actual machine. Can anyone help.
Regards
Gailey in Calgary, Alberta, Canada
(whose running out of clean clothes)
  • Gaileymk2 Aug 09, 2008
    Thanks for such a speedy response. How do I investigate the potentially differing amperages of the two motors? Your comments about simply replacing the fuse with a bigger one without further investigation alludes to my concerns.
    Good morning Todd
    There is a green paper label on the old motor, it reads as follows:
    AEG
    UZ 112 G 63
    4J 083653 129 F3 1298
    220-240V 50Hz Iskl.B/F
    S,-Nr 645 256 280
    SBP 645 260 820/17
    The only bit of that information that I can interpret is the 220-240V!
    I can't get to the new motor as it is already installed. I will have to ask someone to move it for me and when I get in from work I will unscrew the back panel and see if I can find a similar label.
    If you can tell me how to interpret the amperage from the above information, I might be able to find the same on the new label (assuming it's visible).
    Regards
    Joanna
    Scholar:
  • 83 Answers
Hello Joanna,
Unfortunately the motor data does not give the current rating, only the voltage.
The circuit breaker would trip if the current is too high or overloaded. The voltage is not the issue.
I have checked the AEG and Electrolux sites who made this motor but to no avail.
Can I ask, whether your washing machine has a water pre-heat function, and are you using that function? I am thinking that maybe the new motor consumes higher current than the old motor, so it may be tripping the circuit breaker on its own. But the water pre-heat only operates in the first cycle.
I hope I haven't confused you.
One resort would be to ring the repairer and ask them the current ratings of both motors, explaining the problem you have.
Let me know your thoughts.
Regards,
Richard
Posted on Sep 14, 2008
I have a 14 yr old AEG 3200 dryer. The drum has stopped turning.Could this just need a simple belt replacement or wld you recommed a new dryer. Thanks
If you can hear the motor run when activated replace the belt. You should check or have checked the rollers that the drum is supported by. Check the belt tension-er replace if worn. While the unit is disassembled the rollers are easy to replace.
Vacuum all loose lint out from around the motor while disassembled.
These simple older machines are reliable and very durable and only have a few moving parts.
Hope this helps?
AEG LAVATHERM 60750225500 Tumble Dryer Section Spare Parts Diagram
Jun 21, 2017 | AEG Dryers
I have an AEG Lavamat 74810 washing machine which is 10 years old. On any cycle , the drum does not spin, on pressing the two left hand buttons, you get error code E52.
The E52 code indicates that the motor is not moving. This could mean the the carbon brushes have worn out, the entire motor is bad or that the wiring or control units have damage so that the message to spin is not getting to the motor.
Take off the back of the washer (after unplugging it). Inspect the motor plug and wiring to that plug. If those look okay, take out the motor and inspect the carbon brushes. If those are worn or broken, then you need to replace them. If the brushes are okay, then the entire motor or the control board are more likely to have a fault. See http://shop.aeg.co.uk/search?prpp=20&ppn=1&psfo=A&filter=category%3ALaundry%3AWashing%2BMachines and use the full product number to find out the part numbers you may need. Other sites will have these parts.
I hope this helps. Please add the product number of your AEG Lavamat 74810 if you need assistance finding parts.
Feb 15, 2017 | AEG Washing Machines
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
How do you fit a door seal to a AEG LAVAMAT 66600
Thank you for contacting fixya.com.
Please check this video along with the tutorial to install the door seal in your washing machine:-
http://www.apart4u.co.uk/video-tutorials/washing-machine-repair-videos/how-to-fit-door-seals-gaskets/aeg-how-to-change-or-fit-a-washing-machine-door-seal-or-gasket.html
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | AEG Washing Machines
On my AEG Lavamat 62810 washing machine, when I start a wash cycle the motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message and no water having entered the machine....
inside the waasher there is a fill level valve i think its blocked up with "gunk" if you look inside the washer you should see a small pipe from the bottom of the drum going up to a round type of valve with lots of wires fitted to it at the top of the washer,,,pull the pipe off this valve and "blow hard" down through it,,any "gunk" should be pushed out and the washer should wook ok after that,,,if it dont change the valve!!!
Aug 12, 2010 | AEG Washing Machines
AEG Lavamat 76400 during spin cycle blows a fuse
its not the heat element its the water pump i would say it has gone to ground try disconnecting the water pump if the fuse does not trip then replace the water pump
Jul 03, 2010 | Washing Machines
Have Aeg 72630 stopping problem
When it sticks, is the tub empty of water? If so then you may need to change the cold water solonoid just inside machine where fill vaulves are fitted. good luck hope this works
Feb 12, 2010 | AEG Lavamat 72640 Front Load Washer
Spin cycle stopped on 10 yr old Amana washer
its the brushes on your motor or your pump is blocked or defective
Jun 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
AEG Lavamat 16830 washer dryer
can anyone tell me how to remove the rear panel of a AEG lavamat dryer. regards Roy
Jul 20, 2008 | Washing Machines
AEG washing machine stops without heating
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Check out yr user's manual.
Rate me pl.....if helped.
Jan 21, 2008 | Washing Machines
Washing Machines Logo
70 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
