Question about Admiral AAV7000A
Parts: What is its name? or how do I find it?
I located the following comment in your forum:
The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Can you tell what the gear is officially titled and where I can find it. I also cannot locate a manual for this model do you have any suggestions?
Thanks,
Paula (pdwillie2@live.com)
  • 750 Answers
Hello Pdwillie,
you said,
The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teeth and is making the noise.
Thanks,
Paula
Sounds like you need to replace the transmission!
How old is the washer?
admiral is a low end washer and may not be worth investing good money into bad!
The trans goes, so dose the washer ! To the scrape yard.
the new ones will pay for them selves in a few years in water and energy savings.
Never heard of anyone replacing parts in the trans. We replace the trans or advise the customer to replace the washer if its older than 5 years!The trans should last for at least 10 years!
Posted on Sep 19, 2008
Craftsman 19.2v drill. What is process remove the chuck. The back side of it has 17mm dual flat spot. I tried 17mm open end thin bike wrench but I cannot get the chuck to unscrew. I need it off in order to...
Hi Charles! The chuck is fixed to the spindle by a bolt (with Ph2 or hex head), you can find the bolt head if you look directly into the chuck (with its jaws completely opened). You'll just need to fix the chuck (with your hand most probably), and unscrew that fixing bolt (might be with left-hand thread! - don't use excessive moment, first try it gently both ways). After removing the bolt you'll just need to gently tap the bottom of the chuck - through a piece of wood - with a hammer, to remove the chuck from the spindle. Gently is the key word - in order not to damage the chuck and ball bearings/gear set of the drill.
Below are 2 reference links from Craftsman and Sears Parts catalogue - may help you as well.
Good luck! Craftsman C3 19 2 Volt Lithium Ion 3 8 in Drill Driver Kit Craftsman Drill Parts Repair Parts
Mar 28, 2015 | Craftsman Drills
Ninja blender motor part is wore out
-I don't think they carry any replacement parts for Ninja Blender.
-Possibly not the spline plastic.
-Inside on top of the motor there is a planetary gear there. Possibly worn out or lose screws as well that not hold it in place to mesh together.
-But before you can reach to these parts you have to take the bottom cover off, remove the plastic spindle. IT's very tight.
Good luck
Mai
Jan 11, 2018 | Euro-Pro Ninja 1000 Watt Prof Blender 3...
Is there a gear kit for the Fellowes MS-450CS Micro Shredder?
Hello Jay
I have the same problem. I found a place that sells nylon gears. They are not to good in responding back though.
This is the email address and the lady's name is Delores
sdp-sisupport@sdp-si.com
The cog below is shattered on the spindle and the bottom one, the skew spindle has chewed a hole in the cog in one place. I would like them all replaced with bronze.
Here are all the Cogs, tantalisingly close. Tell her I sent you!
http://www.sdp-si.com/eStore/CoverPg/Gears.htm
SDP SI ON LINE eStore offers Spur Gears Helical Gears Miter Gears Worm...
Dec 19, 2011 | Fellowes Manufacturing Powershred ...
One of the spindles that drive shaver head has snapped, can this be easily repaired?
For model HQ8150, the item you reqire to replace the broken gear is found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-8100-series-motordrivegear-assembly-p-608.html
You will find generaal disassembly instructional video also at shaveroutlet.com. See link below (it's the second video)
http://shaveroutlet.com/video_tutorials
Follow the instuctions in the video, then remove the wires from the motor by pulling on the wires as you puch in on the metal release tab next to them. Remove the two screws near the broken 'spindle' to remove the plastic gear plate. The motor assembly will then come out
Oct 15, 2010 | Philips Philishave HQ8150 Electric Shaver
How do you lock spindle on Delta Osillating sander to change sand rolls?
The spindle screw is reverse tread and you need to turn it clockwise to loosen and counter clockwise to tighten the screw. You can usually hold the spindle with your hand then turn the screw clockwise to loosen the screw. Worst case scenario, carefully turn the machine upside down. Place it on a clean supporting surface. Use a flat-head screwdriver or similar device to remove the plastic gear cover to gain access to socket-head screw. Carefully place the machine on its side. Attach the spindle adapter to the motor shaft turning the spindle adapter counter-clockwise on the shaft.
NOTE: Motor shaft has a left-hand thread.
Place a 7/16" open-end wrench on the flats of spindle adapter. Insert a 3/16" hex
wrench into the socket-head screw located where the plastic gear cover was removed.
Hold the hex wrench to prevent the motor shaft from turning. Turn the wrench counter -clock wise to
fasten the spindle adapter on the motor shaft.
Reinstall the plastic gear cover that was removed above.
Jul 10, 2010 | Garden
Fitted tiagra triple to cannondale caad9 frame. bottom bracket creaking
There are many possible causes for the noise you're hearing, but the most common source of creaks is loose crank arms.
You might be able to eliminate the sound by tightening the crank arms on the bottom bracket spindle. However, I would recommend removing both crank arms from the spindle and reinstalling them after lubricating the surfaces where the spindle and crank arm meet as well as the crank arm bolts. Use a high quality grease (not oil, such as Triflow) or anti-seize compound.
Torque the crank arm bolts to the factory spec. Crank arms bolts can take a lot of torque -- about 300 ft/lbs. Most people don't have a torque wrench, so you can "guesstimate" this by applying about 50 lbs of force on the end of a 6" long wrench.
Other possibilities are loose chainrings (check each bolt where they are attached to the crank), pedals (lubricate/service bearings), bottom bracket (check it is properly torqued), chain (look for tight links), derailleur idler gear, crack in frame.
Sep 16, 2009 | Shimano Cycling
Agitator has top and bottom section. Bottom working fine, top stationary no longer works. Works as a one way gear as bottom agitates. No longer catches.
If this is a Whirlpool manufactured washing machine (which includes Kenmore, Estate, Roper, and Kitchenaid to name a few) you may just need to replace the agitator dogs. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The dogs are part of the agitator cam assembly under the auger (top portion). These little plastic pieces do wear out with age, causing the slippage you are talking about. Replacements are available at appliancepartspros.com for about $5. For a little bit more, you can purchase the entire cam replacement kit (which includes the dogs, cam and seals) for around $11 or $12. Use your model number to begin your search criteria and locate these parts under the "Agitator Parts" section.
If this is not a Whirpool manufactured washer, or if you don't know, please post back with your model number so that I may assist you better. For future reference, always include a brand name and model number when posting questions, so we can determine a possible cause and locate parts sources. All washers are not designed the same and without this information, it makes it difficult to determine a solution for you.
If you have questions, or require additional assistance, please let me know. I hope you find this information helpful.
Aug 19, 2009 | Washing Machines
2000 daewoo lanos head torque
the 2000 daewoo lanos 1.6L dohc head torque is as follows , step 1 = 18 ft. lbs. , step 2 = 70 degrees , step 3 = 70 degrees , step 4 = 30 degrees . sequence is as pictured .
there ya go , gears to the left , looking at the front of engine .
Jan 09, 2009 | 2000 Daewoo Lanos
Amana ARB8057C upper fridge not working
On further inspection, I noticed that the fan in the freezer was not spinning. I was going to check the voltage on the fan motor but then I noticed that the spindle on the fan motor as actually spinning but the blade was not. The blade is made of plastic and had come detached from the spindle. Therefore no cold air was been pushed up into the fridge compartment. I pushed the blade into the spindle (after power was turned off) and everything was back to normal. Unfortunately this is probably going to happen again because there are no bolts holding the blade on the spindle (an engineering flaw) but at least I'll be able to locate the problem much faster next time.
BTW: The fan assembly is usually hidden behind plastic shrouds. You need to remove shelves and take off a few screws to see it. Hope this helps others .... I suspect this fan assembly is used in millions of fridges and is a major revenue generator for fridge repair folks.
Jun 30, 2008 | Amana ARB8057C Bottom Freezer Refrigerator
Admiral AAV7000A Logo
42 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
