Question about Canon EOS Elan IIE 35mm SLR Camera
Auto rewind problem
I have an elan IIe and it keeps auto rewinding after just a couple of shots are taken. Sometimes it makes it all the way thru a whole roll of film. I have two cameras doing the same thing. I bought the second one in hope that it would not do this. Any idea what's causing this and can it be fixed?
  • onyrsix Aug 11, 2008
    Thank you, that is the best answer I've gotten so far after seeking answers from stores such as Ritz. I will look into both solutions!
    Thank you again!
  • 60 Answers
There are 2 things that can cause that problem. Many times it is caused by the user pulling too much film out of the film cartridge and laying it across the film plane, causing it to bunch up on the take-up roller when the camera back is closed.
Make sure the film tip extends no further than the orange indicator in the back of the camera.
If that is not the cause, there is probably a defect in the clutch that flips back and forth each time the camera winds the film. Sometimes they bind up and cause the camera to go into the rewind mode early. It would need to be looked at by a qualified camera technician to determine if that is the problem.
CameraRepairs
Posted on Aug 11, 2008
My 35mm film won't load. It keeps rewinding
Solution: Repair or replace auto-rewind system.
Cause: The built in auto-rewind system that supposed to work when film is finished but because it is faulty it receives wrong signal when film is lloaded. So the camera thinks the film is at the end of the roll.
Possible cost: $65-$75
Oct 26, 2012 | Photography
The Film advance lever is stuck, how can I fix this?
This camera is 42 years old. Sounds like a mechanical problem, but I doubt you are going to find any company or individual who knows how to fix it, or can find parts for it, if needed.
Suggest you keep this museum piece as a conversation starter, and invest in a newer model.
If you want to stay with Canon, the Elan 7N and Rebel T2 film cameras are 'only' about 13 years old. I see Elans on eBay starting at $70 (body only).
Jul 04, 2017 | Photography
The camera back button requires power to operate and as the electronics seem to be fried button pushing doesn't open the door. So is there a manual access way? thanks
I had a Canon Elan IIe and I don't recall having to have electronics to open the camera back.
Make sure you have a battery in it, turn it on look at the LCD panel and see if it has film in it.
If so you should be able to push the "mid roll" film rewind button located on the back left side it shows a film canister icon. Once the film has rewound into the canister release the back with the mechanical latch found on the left side (while facing the back of the camera) just push it down and the back will pop open. Those cameras are pretty darn good and the only thing I've seen friy the electronics is using an "old" type flash on the hot shoe and that takes the flash circuit board and melts the thing. I'd expect the camera battery is dead and you can't rewind the film back into the canister.
Nov 08, 2010 | Canon EOS Elan IIE 35mm SLR Camera
EOS 30 how to remove film from camera, as camera is dead no reaction to new batteries
The easy way is to use a film changing bag, if you don't have one follow the instructions below:
You need to get the film out manually. In a darkened room, just a very small/dim lamp, or door open where the light is in the next room.
First check where the lever/switch is for opening the camera, remember where it is. Then put the camera under some jackets/blankets to protect it form any light. Put your arms under the covering keeping them flat with the surface so no light can seep in.
Open the camera by feel then pull out the film canister and start winding the film back into the canister manually by turning the canister spindle, always keeping the camera and film and hands/arms protected from light under the covers. You might have to tug a bit on the film to get it from the take-up spool inside the camera.
Some cameras have a button on the outside underneath the take-up spool, which you press to release the spool, I doubt that your camera has this because it is auto winding & rewinding?
Oct 27, 2010 | Canon EOS Elan IIE 35mm SLR Camera
Camera does not rewind after end of film it spins, but does not engage the film. Joe M.
it is likely that this model of camera spins the entire roll onto the take-up spool, and then slowly rewinds one frame at a time until the last picture is taken. Then it has already almost rewound,
This shows up when you load the film. The cameras digital counter counts up to the number of pictures available, and counts downward each picture taken.
Sep 08, 2010 | Canon Sure Shot 80U 35mm Point and Shoot...
My Canon AE-1 Program will not rewind. I shot the whole roll, rewound a little, and then accidentally opened the back cover. The counter reset to S, and the rewind crank just unscrews when I try to...
I think you have already ruined the film except the frames that are rewind back to the film cartridge.
You can take the film out from the camera, push in the rewind button at the bottom, pull out the film from the film take up reel.
On the film cartridge, turn on the long tube in the middle clockwise to wind all the film back into the cartridge.
If you had the back opened briefly, do manual film rewinding in the dark room.
May 21, 2010 | Canon EOS-AE-1 35mm SLR Camera
I have a TROY-BILT model 566 Smart Touch mulching mower. The starter pull cord (for lack of a better term) did not rewind when I tried to start the mower last weekend. I rewound the cord once by hand and...
sometimes these are shot dogs; these are what come and grap the engine and the cord is loose for about an inch or two and then you feel restance from the engine commpresion to start these DOGS are plastic and cheap
Apr 10, 2010 | Troy Garden
How to you re tension the starter spring
What has to be done is the BLOWER Housing must be removed from the engine. Then pull the rope all the way out, NOTE which way it is turning. Then stick a screw driver thru the spokes on the wheel and straight thru the housing, this will keep the rewinder from rewinding.
Then cut the knot from the cord. Remove the cord. Engage the rewinder wheel with your fingers pull the screwdriver and wind the spring as tight as you can. Re-install the screw driver thru the wheel so it can not rewind and reinstall the cord. When tying the knot ,make sure to use a light to melt the cord a little so the knot will not untie.
Hold the handle tight and pull the screwdriver and slowly let the spring wind in the cord.
Done
Oct 20, 2009 | Garden
I have mounted a M42 adapter to my Elan IIe. It only locks up. It worked fine on my Rebel Ti. What is the problem ?
i have some problem with elan 7 when i mounted m42 adapter and manual lens the expouser mode is gonig crazy i have very wrong exposer not one or two step its more one eos 300 canon its allright whats a problem? thanks evryone
Oct 18, 2009 | Canon EOS Elan IIE 35mm SLR Camera
I just bought a second hand Contax RX but the film rewinding stars automaticaly after 5 or 6 shots, even in a 36 exposures roll. Is it a set mistake? Thanks. Julio
The auto-rewind is triggered when the film advance mechanism detects tension on the film, indicating the end of the roll.
It could be a couple of things causing the problem...
1) The particular roll of film you were using was wound too tight, or has got some moisture in it causing it to stick.
2) If it has done this with various rolls of film, it is likely that the clutch mechanism that detects the film tension is out of adjustment. This is something that a professional camera repair shop will be about to fix for you.
I'm not familiar with this particular model of camera, but there may be a facility to turn off the auto-rewind as a short-term fix.
Hope this helps!
Jun 27, 2009 | Contax RX 35mm SLR Camera
Canon EOS Elan IIE 35mm SLR Camera Logo
95 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
